Question about RCA D52W19 52" Rear Projection Television
RCA 52 in HDTV red, green and blue colors not alligned - concave
Picture is concaved with the red green and blue lines like a ribbon across the screen.
one solution mentions a fuse for a transformer... where is it located and where can I buy one?
RCA model HD52W59
  • RCA Master
  • 8,617 Answers
That repair only repairs the issue of the convergence option missing from the on screen menu. If thats what your problem is then the ITC222A convergence option missing repair kit at the following link should repair the issue. The kit contains the fl231, DL231, CL230 and the CD with detailed instructions.
http://www.tvrepairworld.com/
Posted on Jul 17, 2009
Red, Blue and Green Ribbon on Tv
converence power supply board is the most likely problem
Jul 18, 2009 | RCA D52W19 52" Rear Projection Television
Screen lookes like colores separating
Here's all I find regarding bad convergence from the techrepairCD:
RCA ~ITC222 D52W20~Convergence bad~~~ITC222~Replace leaky DL032 on
deflection board~~~~~~
RCA~D52W20Y ATC221~Convergence goes out/bowed after on for a few
minutes~~~ATC221~Problem may be on the deflection board. Was unable to
pinpoint where in this case.~~~~~~
RCA~D52W20BYX1 ITC222~Convergence way off after replacing small signal
board~EEPROMS were transferred over to new board~~~IK210 was
defective..transfer the new EEPROM back over.~Remember on these
sets*when replacing the SSB* if there is a small P on corner of
screen*hold volume on remote for 8 seconds after it reaches minimum.~~~~~
RCA~D52W20BYX1 ITC222~Can not align blue convergence* bottom really
bowed* possibly either color after replacing SSB.(Or no auto
convergence.~(Service menu: turn power off for 30 seconds* press vol dn
and ch dn* simultaneously for 8 seconds* set turns on with service menu
options)~~ITC222~In service menu* select convergence. If sensor
calibration was performed when convergence was too far off* it will not
alighn.~Get crosshatch with straight lines* perform sensor calibration*
then attempt convergence alignment again. Be sure to store settings*
then do sensor calibration again.~You must get a green flash of the
screen after sensor cal and a check in the box. RED flash indicated
convergence settings are too far off~~~~
RCA~D52W20BYX1 ITC222~no convergence correction~~~ITC222~LP650
(259271) DP670 (259246) & RP632 (259564) 4.7 3W on convergence power
supply board~~~~~~
Oct 28, 2008 | RCA R52WM24 52" HDTV Projection Television
The colors are distorted and it seems like the only colors that really show are blue, green, and red. When you turn the TV on you can see blue, green, and red lines across the screen. The picture also...
Hi there, this is what we call in the industry convergence board failure. this board regulate the rgb and keeps everything in order so the picture looks nice and clean. when this board starts to malfunction, what you are witnessing is usually the result. I suggest repairing this convergence board. this will fix the 3-d effect.
Mar 08, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
Posted by RSDHDTV on Dec 16, 2008 My RCA has a Concave 3D look to the picture and the red blue and green colors are out of convergence
YOU HAVE A CONVERGENCE PROBLEM. THE CONVERGENCE IC'S NEED TO BE REPLACED AND POSSIBLE RESISTORS AND IC PROTECTORS. EST $300- $400. IF TAKEN INTO A SHOP.
Jan 16, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
This is what is known as convergence. a projection tube ussally has three picture tubes.. red green blue. they all have to align. the concave picture indicates complete loss of convergence or convegence power supply. First question on these sets Do you have the convergence option in the customer menu under setup. if you do not this is a indication of the common "FL231 fuse problem" and inexpensive simple repair. I have wrote and artilcle on this under my tips and trick section. If you do have the option then next does autoconvergence work. in you case i would not think it work. under blue and red manual convergence does the crosshairs move. if not then this is indication of convergence power supply board. if they move at all this may indicate a convergence amplifer problem.
Sep 10, 2008 | RCA HD52W56 52" Rear Projection HDTV
Red Blue and Green colors are not aligned and looks concave
replace fuse looks like cap next to flyback transfomer FL231 it will be the one in the middle.there are 3 of them next to FBT.
May 28, 2008 | RCA D52W19 52" Rear Projection Television
Double image - colors out of sync, concave image
bad converage ic's, check reisters around them and fuses for -&+VCC
Apr 09, 2008 | Mitsubishi WD-52725 52". Rear Projection...
My RCA Tv has a concave picture!!!
Convergence problems. FIrst try going into customer setup and seeing if convergence options are there and if adjustments can be made. unfortunately when the picture is bowed like that it idicates a complete loss of convergence which idicates one of three boards have gone bad.
Dec 21, 2007 | RCA HD52W56 52" Rear Projection HDTV
52 rca concave pic and bad colors
concave and colors off indicate the convergence cuircit is bad. which can be one of three boards. sorry
Dec 08, 2007 | RCA HD52W56 52" Rear Projection HDTV
RCA D52W19 52" Rear Projection Television Logo
675 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
