Question about ASUS A8N-SLI Deluxe Motherboard
No PS/2 keyboard response on boot.
I have an Asus A8N-SLI Deluxe system that I built that's been working flawlessly for over 2 years, and today (after routine summer cleaning), will not boot past splash screen. I tried clearing CMOS, however I can get as far as the big Asus AI splash screen where you can press 'del' to enter bios, and I get no response from keyboard. I checked all cables connection and connections, but can find no problems. I don't have a USB keyboard to try, but don't know if that would work before entering OS anyway. Any ideas would help.
  • 1 more comment
  • painterh Jul 17, 2009
    For clarification, I installed 2 additional sticks of RAM (matched pair same brand, model, speed and timing) so all slots were filled with 512 meg modules. Then I booted up and it ran great for several days. Then I noticed (Using Everest home edition), that only 2 of the modules were showing the correct timings that I had set up in the bios. So while I had it shut down for maintenance, I reset the CMOS to see if that would allow all 4 sticks to to share the same timing. After checking everything (as stated in original post, I restarted and no keyboard response. So now I cant even get into the bios to re-configure settings, and it wont boot past the LOGO screen. I tried using my wife's PS/2 keyboard, but same result. I hope this info helps
    If I inadvertently had the PS/2 mouse and keyboard switched during boot, could that cause this kind of problem?
  • Fabio May 11, 2010
    Try without any devices connected to the motherboard ,only keep memory ,cpu and motherboard and see if it goes past the logo.
  • 2,404 Answers
Try a different keyboard and then try a different mouse. Try unhooking the hard drive and see if it goes past the logo, if it still doesn't then go ahead and disonnect the keyboard and mouse and see if it goes past the logo screen. If it doens't go past the logo then take the memory and cpu out and blow so air onto it to make sure specs of dirt or dust are no affectng it.
you can also try different memory as well to see if it stops locking up. Otherwise if you go thru these steps and you still have the lockups, its not going to be the keyboard are mouse causing the problems, its the motheboard.
You can try a usb keyboard and it might work but that would mean you have a bad ps2 port on the motherboard and as long as that doesn't bother you then the computet will be fine.
Posted on Jul 17, 2009
I don't know how to plug in the wires for the ASUS a8n sli deluxe motherboard
Here is the manual for your motherboard (since describing a diagram probably isn't very useful...)
http://dlcdnet.asus.com/pub/ASUS/mb/socket939/A8N-SLI/e2024_a8n-sli.pdf
You want to look at pages 27-35, they describe what you need to plug into the motherboard. Basically make sure you have connected:
1) 24-pin power cable (from power supply)
2) 4-pin power cable (for CPU from power supply)
3) Any case fans with 3/4 pin connectors.
3) hard drives (SATA or IDE)
4) USB front panel ports
5) Audio front panel ports
6) Case plugs (power LED, hdd LED, power switch, and reset switch).
Apr 19, 2011 | ASUS A8N-SLI Deluxe Motherboard
Boot usb cdrom a8n sli deluxe
Press Deleate key at boot enter bios goto boot settings set 1st boot devise as usb press F10 and enter to save changes
Nov 14, 2009 | ASUS A8N-SLI Deluxe Motherboard
ASUS A8N-SLI Deluxe Its sudenly shut down and not coming back again only fan is working
Try resetting the CMOS, to get the procedures on how it's done on your PC's motherboard, please refer to the image below.
Please reply if this has helped you. Thanks.
Oct 24, 2009 | ASUS A8N-SLI Deluxe Motherboard
Coolmaster cm690 asus a8n-sli deluxe
the boards today have real fine typeset near the connection pins but they are there
Jul 31, 2009 | ASUS A8N-SLI Deluxe Motherboard
Problem adding Additional Ram to my Asus A8N SLI DELUXE system
Just because BIOS is recognizing the RAM doesn't necessarily mean it is usable. Also, ASUS recommends that you have the same amount of RAM in each bank. Another point they make is that your motherboard does not support double-sided DIMM chips.
I would refer to the manual for their specific instructions on proper RAM configuration:
http://dlcdnet.asus.com/pub/ASUS/mb/socket939/A8N-SLI%20Premium/e2435_a8n-sli_premium.pdf
If you are concerned that the memory stick might be bad, swap it out with one of your older ones, and see if your system boots and performs as it should. If not, then you know it is bad. My guess is that if you populate the memory slots with 4 gb, the system will recognize and make all of it available to you.
Cheers
Nick
Jan 08, 2009 | ASUS A8N-SLI Deluxe Motherboard
ASUS EZ-PLUG not plugged in?
ASUS EZ_PLUG is optional for SLI mode...this model of your motherboard has an SLI that connect 2 video card using pci express...if this is only you problem for bugging the EZ_plug not connected,you can disable that in BIOS setup...
Oct 28, 2008 | ASUS A8N-SLI Deluxe Motherboard
Memory problem.
Check your manual pg. 2-12. Qualified Vendors List. The QVL is tested memory for your board. There was a small fix to memory with bios version 1015. Go to Asus web site for information regarding this update & others. http://support.asus.com/download/download.aspx?SLanguage=en-us
Feb 01, 2008 | ASUS A8N-SLI Deluxe Motherboard
Describe your ASUS A8N-SLI Deluxe nVidia video card
Yes, you do. Your board was built with the idea to use 2 graphic boards to get great video
NVIDIA® SLI™technology revolutionizes PC performance by combining multiple PCI Express GPUs in a single and scalable system! Gamers and hardcore enthusiasts know that dual GPUs mean increased, supercharged 3D graphics and performance
Dec 09, 2007 | ASUS A8N-SLI Deluxe nVidia nForce4 SLI...
System wouldn't Boot
If your CPU or memory were an issue your Asus board would sound off with BIOS beeps. Asus uses the Award BIOS & you can see what these beeps mean at the link below. Regaurding your PC not able to boot is an issue with your PCIE/PEG video card-in relationship with BIOS setting & the SLI switch card mode that came with your board. When running 1PEG video card you must set this in the BIOS to Auto & you need your SLI switch card connected in its slot. By default, the EZ Selector card is set for a single graphic card. When you install dual PCIE graphic cards on A8N-SLI series motherboards, please make sure EZ Selector card set to the Dual Video Card side and properly inserted. Link to Award Bios beep codes: http://www.bioscentral.com/beepcodes/awardbeep.htm
Will come in handy.
Reading the FAQ's at Asus site will help you better understand your A8N-SLI Deluxe. You'll need to fill in the, "Please Select the Product" first: http://support.asus.com/faq/faq.aspx?SLanguage=en-us
Dec 05, 2007 | ASUS A8N-SLI Deluxe Motherboard
Usb problems
Though this motherboard is not fully VISTA capable, you may still be able to try it out using either VISTA built in drivers or their native Windows XP device drivers.
Please kindly refer to the page below for a list of "VISTA installable" non-VISTA compatible motherboard:
http://support.asus.com/technicaldocuments/technicaldocuments.aspx?no=897&SLanguage=en-us
Nov 25, 2007 | ASUS A8N-SLI Deluxe Motherboard
ASUS A8N-SLI Deluxe Motherboard Logo
349 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
