Question about Logitech ChillStream Game Pad
Unable to get the controller to work properly
I tried using the Logitech Chill Stream controller for Bloodrayne on the PC but when i tried calibrating the joysticks Axis 3 which is the Left/Right movement on the right joystick wouldn't work is there any loadout or diagnostic program i can use to fix it?
  • 3 more comments
  • shady69 Dec 20, 2007
    tried calibrating the paddle
  • Anonymous May 28, 2008
    Unable to get the controller to work properly (by 2 users)
  • echillag1 Jul 02, 2008
    i bought a logitech chillstream gamepad and gta san andreas. for some reason i cant get the right joystick, the D-Pad, or the L and R buttons to work.
  • Anonymous Feb 17, 2009
    my dad threw out the disk for my controller after he didnt need it so now im screwed
  • tommy patrick Feb 22, 2009
    got the chillstream too. Wont work for COD4 the only thing I bought it for in the 1st place.
    went to switchblade and downloaded the drivers they had for xbox360 controller but nojoy when turn game on.
I found out that the driver needed is from the microsoft webpage and you can't evern really botyher installing the drivers form the CD becuase you have to delete them first on themicrosoft site the Chillstream drivers are actually XBox360 drivers
Posted on Dec 22, 2007
I can't even get mine to install, the auto load from the CD just crashes immediately, I can't even view the menu. Than when I got to to download the drivers it send me to microsoft. I download the drivers, click them to install, it shows me a couple install bars, and then it says "instaltion not complete." and it goes away.
So what now?
I can't update my controller from the internet
Posted on Jul 23, 2009
You extract the files with winrar from Microsoft Common Controller 32bit.exe and you update the drivers manually from Device Manager, when you are propted to choose the directory, you check the "Don't search. I will choose the driver to install" option. then you install the driver that you have had extracted. then it works !
Posted on Sep 20, 2008
My throttle does not respont properly. i can not
Unplug joystick from pc.Power off pc.
Restart pc.
After pc starts plug joystick back in.Should reinstall itself.
Once done recalibrate.
Sep 19, 2011 | Logitech Extreme 3D Pro Joystick
Steering not recognised by the PC
In windows controllers have you selected the device in question and "Calibrated" it? Also Logitech includes a driver and utility to help you calibrate and set up the wheel In Windows Control panel\game controllers. Try to use it in sequential mode also. All else fails contact Logitec directly.
Sep 23, 2009 | Logitech G25 Wheel And Pedals Set
Logitech zero calibration reset method
Have you tried using the Logitech calibration uninstall tool that erasers all joystick calibration from windows.
Download and run the Logitech Clear calibration (LWS_CLRC.EXE).
The Clear calibration Utility was developed by Logitech to resolve calibration problems with Logitech digital gaming devices.
NOTE: This utility strips all calibration information in the Windows Registry for all gaming devices. This includes any non-Logitech gaming devices that have been installed.
You may also want to uninstall and reinstall the Joystick Software as well. In some cases, if the calibration issue is within a game, you could try uninstalling and reinstall the game.
Please refer to your game manufacturer for instructions on uninstalling or configuring the game.
This calibration tool specifically mentions the Wingman Joystick, However, it works for ALL Logitech and NON logitech Gaming Joysticks and Gamepads.
Jun 06, 2009 | Apple Logitech Freedom 2.4 Cordless...
Too senitive can't control fx9 or fsx
First try the usual suspects. Uninstall *all* game controller software, reboot and install the latest Logitech drivers for your stick. Make sure you've got the latest Vista SP1 + updates. Make sure you're running the latest update of DirectX. Check for patches for your game. Plug the stick into a different port.
Check the physical movement of the stick - any springs feel broken/missing? Tension settings too high or too low? If all those are done, go in to the game controller calibration in Windows and calibrate. Test it - does the stick control the cursor properly? If so, but in-game you have problems, the problem is most likely related to the game code and unless they've released a fix, there's not much you can do.
If the stick has problems with calibration and you've installed any/all updates - likely a defective stick, contact your seller.
Apr 22, 2009 | Logitech Wingman Extreme 3D Pro Twist...
Logitech Wingman Extreme Digital Calibration
Hello there
Usually these JS automatically calibrate when intalled, but...some like olders models, have problems, with sensors, or bad calibrations inside the rotor ans sensors area. for those fixes, you have to open carefully the JS and look for the sensors that usually are two optical sensors, and clean good, with computer air spray, sometimes that did the trick, but others, its a sensors, problem. you have to RMS the product, or use your warranty.
hope these helps!
Mar 02, 2017 | Logitech WingMan Extreme Digital 3D...
Unplugged my Extreme 3d Pro/When plugged back in, can't calibrate
have you choosen to use the stick in the game controlls options in your games? if not you just choose using joy-stick and customize the buttons and Y-X-axis to what you preffer
Dec 31, 2008 | Logitech EXTREME 3D PRO TWIST HANDLE...
How do you know it's not doing anything? Have you run the calibration software? If not run that software. If its not working specifically in a game you need to go the settings in the game and set up the controller to be used.
Good luck,
Jun 10, 2008 | Logitech Precision USB Gamepad PC Game...
No QB vison with chill stream game pad on new maddens HELP
you need a new controller this one does not work well with any madden game. I returned mine good luck
Jan 04, 2008 | Logitech ChillStream Game Pad
Mono racing wheel
recalibrate it on the windows program, or download the logitech calibration program from their website, also make sure the pedals are properly connected to the wheel, if the connector is loose it might not work properly.
to recalibrate on windows - start - control panel - game controllers - logitech momo - properties - calibrate.
Nov 27, 2007 | Logitech Momo Force Racing Wheel PC
Logitech ChillStream Game Pad Logo
5,216 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
