SOURCE: Cursor is frozen and can;t move on my laptop
Plug in a USB mouse, and go to Contol Panel>system>device manager and click on the +sign next to pointing devices. Right click touchpad and uninstall the touchpad, then reboot the computer, remove the usb mouse. Windows will pick up the touchpad as new hardware and re-install the drivers for it etc..
I hope this helps
SOURCE: i forgot my login password
when booting up your laptop right after post (the beep) press F8 key and select safe mode. from there at the login screen you should get the welcome screen, select Administrator. inside there goto control panel, user accounts
inside here you should be able to change/remove your password.
SOURCE: moving cursor
Hi, sheila_sharp.
Please make sure you remove any dirt and/or fluid found on your touchpad. Even the tiniest grain of dirt may result in this. If you are using an external mouse, poor quality mice may cause this type of behavior.
Your responses are intended to improve the level of service provided. Please rate your experience.
SOURCE: My laptop is a Toshiba satellite and after i login a black screen
Hi there. If you've had the laptop under a year, then you can take it back to the place where you bought it, and they can take a look. If anything's wrong, then it can be fixed under the manufacturer's warranty, which is normally for 12 months from purchase.
One thing I'd like to ask, can you see anything behind the black screen? I ask this, as I had a friend who had similar problem, but it was a faint black, with the cursor flashing, and he could faintly see the desktop in the background. I was wondering if this was the same for you.
SOURCE: cursor jumps around and inserts letters in words I have typed
Run a spyware, Malware program, SpyBot- 1.62 or Malware Remover, LAVASOFT, and more... clean out the machine.
Testimonial: "thanks I should have thought of that."
Correction Acer Aspire 7551 series
