Senville 24000 BTU Energy Star Ductless Mini-Split Logo
t
tom henderson Posted on May 13, 2016
Display shows ec and then flashes 7 times - Senville 24000 BTU Energy Star Ductless Mini-Split
Philip
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 26, 2016
Philip
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
446
Points
Don't have a answer but my 12000 btu is doing the same thing
What is wrong when the display shows EC and the run light flashes 7 times , then stops flashing for 4 seconds , then starts flashing 7 times over and over ?
THE "EC" CODE IS A LEAK DETECTION CODE,, SHOWING THAT THE FREON LEVEL IS LOW, AND YOU COULD HAVE A LEAK,,
? 7 times X EC Refrigerant leakage detection It is time for a service tech
My midea ac showing EC error why it will apperas?
How Do I program the hpm digital time switch hl 03705 Eco Rex d11
How to Program HL 03705 EcoRex D11 Timer
The "switch" is a small rod which can be moved 5 ways - left, right, up, down and IN.
Before programming check that time and date are correct.
Time - push switch IN, then down once until TIME flashes on display. Push switch IN, then up or down continually to select hour, then switch IN, then up or down continually to select minute. Push switch IN to save.
Date - push switch IN, then down twice until DATE flashes on display. Push switch IN, then up or down continually to select year, then push switch IN, then up or down continually to select month, push switch IN, then up or down continually to select day. Push switch IN to save.
Programming - for the sake of this exercise the timer will be set to come ON at 7am and OFF at 10pm, 7 days of the week.
Note the numbers 1234567 printed just above the display window. These represent the days of the week, starting with Monday.
1. Push switch IN, then down four times until PROG flashes on display. Push switch IN. The display shows a vertical line with numbers, at the bottom of which is a digital time which should show 0:00. This is midnight, Sunday to Monday.
2. Push switch up once, this advances the time 1 hour. Continue to push switch up, one hour at a time until the digital display shows 7:00. This is 7am Monday and will be the first ON time. (Push switch to the left to change minutes, each push advances time by 1 minute).
3. Now push switch to the right and HOLD there. BE PATIENT! It takes several seconds before the time changes, firstly a minute at a time, then in 15 minute blocks. Still holding the switch to the right watch the digital time display advance (don't look at the vertical line which has another thick line develop beside it as the time changes!) until it reaches 22:00, then release switch. This is the OFF time, 10pm Monday.
4. Push switch up once, this advances the time 1 hour. Continue to push switch up, one hour at a time until the digital display shows 7:00. This is 7am Tuesday and will be the next ON time. (Push switch to the left to change minutes, each push advances time by 1 minute). Note that there is a small dot under the number 2 at the top of the display to indicate it is Tuesday.
5. Now push switch to the right and HOLD there. Still holding the switch to the right watch the digital time display advance until it reaches 22:00, then release switch. This is the next OFF time, 10pm Tuesday.
6. Continue the steps #2 and #3 through Wednesday to Sunday. You will know when you are back to Monday by looking at the dot at the top of the screen returning to be under the number 1, OR when you return to 7am Monday there will be a thickening of the vertical line starting at 7:00.
7. PUSH THE SWITCH IN TO SAVE THE PROGRAM.
Testing - To check the program settings - push switch IN, then down five times until TEST flashes on display. Push switch IN.
Each upward push of the switch moves the display through each subsequent ON and OFF change. Check the day for each ON and OFF by viewing the dot under the numbers 1234567. After the last ON/OFF change the display shows PROG END.
Operating the Program
Push switch IN, then down six times until AUTO flashes on display. Push switch IN. The device now operates on the times that were programmed. The display returns to the "home" view, showing the current time, also vertical strips lined up under the numbers 1234567, representing the times of operation each day.
Outside the display window, at the bottom of it, the words OFF and ON are printed to the left and right respectively. A cursor points to one of these to show the current status of the device.
To bypass the program - push switch IN, then down past AUTO until ON or the next one, OFF, flashes on display. Push switch IN - at ON to have device permanently switched on or at OFF for device permanently switched off.
Hot tub in EC with light flashing
Ecn or Ec Message
Ecn or Ec Message
If the Ecn or Ec Message is Alternating with the Water Temperature on the Display, the Spa is Operating in the Economy Heating Mode.
If the Ecn or Ec Message is ON Solid (Not Flashing) on the Display, the Spa is Operating in the Economy Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
Ecn or Ec is Alternating with Temp:
The Spa is Operating in the "Economy" (Ecn or Ec) Heating Mode.
The Water Temperature is Sampled Only during Programmed Filter Cycles. The Heater will Only operate and Heat up to Set Temperature during the Filter Cycles. The Water Temperature will probably drop Below Set Temperature between Filter Cycles. Other Heating Modes are Standard, Standard in Economy, and Sleep Modes.
Ecn or Ec is ON Solid (Not Flashing):
The Current Water Temperature is "Unknown" (- - - or - -) while in Economy or Sleep Mode.
Between Filter Cycles, while in the Economy or Sleep Heating Modes, the Pump has not turned ON and the Last Water Temperature is not Current. To read the Current Water Temperature, either Change to Standard Heating Mode or turn On the Heating Related Pump, and wait at least 2 Minutes.
2answers
The link on FixYa to the HB65R Intermatic timer Manual seems to be broken. Do you still have it?
Fixya does not have HB65 manual posted.
Open following link to identify timer and download manual in English.
If this is not your timer, add a comment with clear description of timer, or in-focus photo of timer posted on flicker, so I can locate possible manual.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#HB65R
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1506
Jul 19, 2011 • Garden
2helpful
How do you set the clock on the delonghi DO400 toaster oven
  1. Press for 5 seconds the TEMP./SELECT/CLOCK but- ton (7) (the hours flash on the display).
  2. Press the TIME/TOAST COLOR buttons (8) to the desired time (hours). The time set will begin blinking on the display.
  3. Press the TEMP./SELECT/CLOCK but- ton (7) (the minutes flash on the display).
  4. Press the TIME/TOAST COLOR buttons (8) to the desired time (minutes). The time set will begin blinking on the display.
  5. Press the TEMP./SELECT/CLOCK but- ton (7) to confirm. It is pos- sible to press the button at any time during cooking to display the current time (the display shows the time set).
  • If you wish to change the hour on the display once it has been set, press the TEMP./SELECT/CLOCK but- ton (7) before proceeding to set the new time as described above.
  • It is possible to display the current time even after starting a function, by pressing the TEMP./SELECT/CLOCK button (7) (the time is displayed for 2 seconds).
Changing the alarm code on the gaurdtec 500 series alarm
For a guardtec 593
Programming User Codes
(Master code only)
system.
1) With the display showing ' Un ' enter a Master code
2) The display will show ' SE '
3) Press NO five times, the display will show ' Uc ' (flashing).
4) Press YES, the display will show ' U- '
5) Enter the User number you wish to program (1 to 7) followed by YES
6) The display will show ' Co ' Enter the required code (4, 5 or 6 digits) followed
by YES. (Entering 000000 will delete an existing code).
7) The display will show ' t- ' enter the code type from the following list
1 = Set Only 2 = Main User 3 = User 4 = Master followed
by YES. A full description of code types is given on page 3.
8) The display will show ' Uc ' (flashing)
If you wish to program other User codes return to step 4
Or
To return to the Unset condition press 0
this is for the led version.
1helpful
The control panel flashes "EC" where the fridge temp is displayed. The word "service" is also flashing.
"EC 50" means excessive refrigerator compressor run time. What is the serial number? Is the condenser fan running? Can you feel airflow from the left side up top? Is the strip between the fridge and freezer hot to the touch?
5helpful
2answers
Intermatic hb65r residual outdoor timer
Here is the instruction manual for your model:
HB65R Timer
Hope this helps!
Also consult this website for sunrise, sunset information for your area:
Sunrise sunset calendar
20helpful
Date and Time Setting
You can download the manual for the 1260-3 which I guess is very similar from the link below: http://www.victortech.com/admin/images/products/1260-3%20manual.pdf Here are examples of the date & time setting: Set DATE to September 14, 2004 (09-14-04) 1. Depress the C or C/CE key.Your display with show 0. and the tape will read 0.C. 2. Depress the TIME/DATE key and hold until the display is flashing. 3. Enter the month, in our example, 09. Your display will show 9. 4. Enter the day, in our example, 14. Your display will show 914. 5. Enter the year, in our example 2004, as 04. Your display will show 91404. 6. Tap the TIME/DATE key to set the DATE. Your display will now show 09-14-2004. 7. To PRINT the DATE, depress the (#/S) key, your tape will show # 9.14.2004. Set TIME to 4:37 PM 1. Depress the C or C/CE key. Your display with show 0. and the tape will read 0.C. 2. Depress the TIME/DATE key and hold until the display is flashing. 3. Tap the TIME/DATE key to go to Time Mode. 4. Enter the hour, in our example 16 in military time. Your display will show 16. 5. Enter the minutes, in our example 37. Your display will show 1637. 6. Tap the TIME/DATE key to set the TIME. Your display will now show P 04-37-00 and the seconds will begin counting. 7. To PRINT the TIME, depress the (#/S) key, your tape will show #?04?37. Please update the question & let us know if the information given was useful to you - Good Luck!
Top Senville Heating & Cooling Experts
Paul Carew
john h
Are you a Senville Heating and Cooling Expert? Answer questions, earn points and help others
