Question about Maytag Neptune MAH5500B Front Load Washer
Both washer and dryer (MDG5500A) dead except for drum lights.
While both machines were operating a loose connection in the breaker panel caused an over voltage. The ceiling light on the same circuit would go alternately normal then bright then back again. At one point the control panels on each machine flashed PF before they went dead. The wiring has since been repaired, is there a reset procedure, fuse, circuit breaker, something I can do in the machine to restore operation?
Thanks,
Mike
  • 1 more comment
  • calmike Nov 18, 2007
    Except for the interior light
  • calmike Nov 19, 2007
    Great. thanks. I can't do it right now but probably can in the next few days.
  • calmike Dec 04, 2007
    Sorry, I meant to update you on this. I found the tech sheets and, since the boards were dead , couldn't get into the service mode. I replaced the control boards and that fixed both machines. One final thing, the washer squeaks like an old bedspring when the tub is rocking in normal operation. In fact I can just push on it and it will squeak. Any lube points and what lubricant do I use? Thanks for your help.
    Mike
  • 290 Answers
I am afraid there is no breaker or fuse inside the machines that will cause the control panels to go dead. You can check your power to the boards at L1 and neutral. If you have the proper voltage here but controls are dead, you will have to replace the control boards.
I notice in your problem heading it stops at the word except. Except what?
Thanks/mike
Posted on Nov 18, 2007
  • 1 more comment
  • Michael  Lindley
    Michael Lindley Nov 18, 2007
    That makes sense. The light is powered by a different input than the display.
    If you remove the console, there should be a tech sheet and wiring diagram inside to show you where to check for voltage. If you want to try to diagnose it, I will try to walk through the checks with you.
    Thanks/Mike
  • Michael  Lindley
    Michael Lindley Dec 03, 2007
    Thanks for using fixya.com.
    Mike
  • Michael  Lindley
    Michael Lindley Dec 04, 2007
    There are no lube points put in by the manufacturer. You will have to find the source of the squeek to know what can be done.
    The tub hangs from springs at the top and has shocks at the bottom. If you find it is something that can be oiled, you can use general purpose grease, light machine oil, or the old faithful WD40 most anywhere on the washer.
    Most likely it is coming from the points where the springs hook or it is some sheetmetal somewhere that is slightly loose and rubbing. You can use grease on the spring hooks.
    You want to make sure it is not the bearing in the rear of the tub squeeking as it turns, this is a major repair.
    Thanks/Mike
Maytag neptune drying center has no power mcg8000aww
Could be a bad thermal fuse, a bad drum belt, a door switch a loose wire , one of the computer boards or the user interphase. Time to call a qualified technician. This machine is a complex machine to disassemble and diagnose and if reassembled wrong could prove to be dangerous to operate.
Aug 31, 2014 | Maytag Neptune MCG8000AW Gas Dryer
Final high speed spin very noisey
Something is causing the drum to be way out of balance. Does it bang and make noise when it's spinning empty? Probably not. Is something stuck on the side (inside of course) of the drum, causing it to shake when spinning? If not, a spring or shock absorber (connecting drum to sides, bottom or top of machine) has broken or come loose.
Nov 23, 2013 | Malber WD1000 Front Load Washer/Dryer
I replaced heating element and thermostat dryer worked for 2 months now i dont get hot anymore
Hello George Schultz - Squeaking noise is usually caused by a problem with the belt, front and/or rear bearing, or a loose connection with the motor/drum. Since you have previously replaced the heating element and thermostat, but the issue continues try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. If it proves to be ineffective, I recommend contacting a professional to accurately diagnose the unit, the part(s) may have to be replace depending if they are worn, damaged, or loose.
Jan 03, 2013 | Frigidaire GLET1041A Top Load Stacked...
I have Kenmore 110.76932691 dryer & 110.28912790 washer in my rental. One of them is putting gray curved marks on my clothes. They resemble pencil marks. Would those be coming from the washer or the...
most probably the dryer is causing this.  the felt that holds the drum in alignment on the front panel is worn or has come loose allowing a gap to form between drum and front and so clothes can become wedged in the and taken for a spin around the drum and causing marks.
Jul 20, 2010 | Kenmore Washing Machines
I have a Kenmore elite dryer, and the signal cycle keeps beeping and the light switches from on to off with every beep...it does it about 6-8 times then may wait 20 seconds to 5 mins b4 it does it again. ...
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 09, 2010 | Kenmore 67082 Electric Dryer
Hoover 0910dryer not heating. element replaced not long ago
Hi, the possible causes are: Possible Causes: The wall receptacle, power cord (plug) and electrical supply must be in good condition and wired correctly for the dryer to heat.
  • Supply Issue - Loose or missing connection on supply wire from circuit breaker.
  • Plug Issue - Loose or missing connection in the wall. Defective, worn or damaged wall plug.
  • Cord Issue - Loose, missing or incorrect connection of the power cord to the dryer terminals.
If gas dryer and does not heat, Gas Dryer heats with a gas burner, make sure the gas supply line valve is open.
Also, for electric dryer,
Electric dryers require two 30 amp breakers or fuses in the house electrical box to run and heat. If one breaker is tripped or one fuse is blown, the motor, the timer and lights can work but the dryer will not heat.
May 01, 2010 | Washing Machines
Spark came out of the wall receptacle after moving
loose connection on the 220 plug in the wall ....go to electrical panel in your home and turn off both breakers to the dryer...this could cause a fire...call an electrician for repair
Jan 03, 2010 | Kenmore 93862 Top Load Stacked Washer /...
My Kenmore Elite HE5 Dryer beeps while running
Aug 14, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Washer dryer won't power up
Worn brushes on motor can cause machine to seem dead. No voltage trough motor.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Beeping dryer & broken hinge on the washer
Jan 20, 2009 | Kenmore 24032\24036 Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
125 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
