Question about GE GSS25SGMBS Side by Side Refrigerator
Evap fan wont run can it be tested for bad board
  • GE Master
  • 1,606 Answers
Using a little 9 volt square battery , unplug the fan motor and connect the battery to the motor . ( fan runs on low voltage dc ) . If the fan runs , board is bad , if not , then motor is bad .
Posted on Jul 17, 2009
Does not goes to the recommanded temp.
If you have a 12 dc power source like a battery charger you should be able to direct test the motor. It should run for you on that voltage--watch polarity. Usually the problem is the mother board (main board) but fan motors go bad also. Main board number is WR55X10942 at about $!50 retail.
May 07, 2015 | GE Profile PDS22SBSRSS
I have an amana ASD2626hes side by side refer/freezer unti. REcently it soppted colling in the refer and the freezer was cold on the bottom only - top warm. I pulled the freezer inside coer - found the...
It could be either....
It is best to check and see if you are getting power to the fan...power to fan, the fan is bad...no power the board is bad...
heatman101
Apr 23, 2011 | Amana Refrigerators
MY GOODMAN HEAT PUMP GPH1336H21AE EVAP FAN MOTOR DOES NOT WORK. THE MOTOR HAS BEEN REPLACED AND THE FUSE IS GOOD. I SUSPECT THE CIRCUIT BOARD BUT DON'T KNOW HOW TO TEST IT HELP.
Have you checked the capacitor on the unit. You will need a capacitor meter in or to check it. nI would check it first then the board. You check the board by running the one lead to the fan terminal and the other lead to the common and see if you have voltage. If you do not have voltage then the board is bad.
Mar 06, 2011 | Amana Heating & Cooling
Compressor works, fans not working, ice maker not filling with water. what is wrong
several things could cause this 1 not coolind evap caused by freon leak evap needs to get cold before fans run most modles 2 bad fans 3 im wont fill untill it reaches about 10 degrees you may need service tech sorry
Jan 29, 2010 | Freezers
Fan in freezer not working
It runs when the compressor runs except when it's in the defrost cycle. If you have an electronic control instead of a defrost timer the control could be the problem since it runs the fans. You can test the evaporator fan. See how here> How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 21, 2009 | Arctic Air 22 cu. ft. Commercial Freezer...
Refrigerator has a clicking sound and does not run
Replace the motherboard (part # WR55X10942) but be careful to check that the evaporator fan (inside the freezer) turns on when you power up the refrig again. A bad evaporator fan motor can take out the motherboard. If compressor starts with new board but not evap fan, unplug immeadiatelly and replace the evap fan motor to save new board.
Sep 11, 2009 | Refrigerators
Evap. fan motor stays on
Sounds like the control board is bad. Does the fan try to run when the tstat is off. Did you check the tstat. What kind of voltage are you getting at the fan motor. Did you check the capacitor. If you are getting voltage to the motor with no call for fan then the control board is bad. Let me know if you need any more.
Aug 19, 2009 | Carrier Heating & Cooling
Not cooling freezer/frig.
starts to work but then stops again? Yes that could be the motherboard but I would test the fan with direct voltage to see if it will run a long time.
Aug 14, 2009 | GE Profile PSS26NSTSS 25.5 Cu. Ft....
Evap fan does not run
please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
May 14, 2009 | GE GTS22KBP Top Freezer Refrigerator
GE GSS25SGMBS Side by Side Refrigerator Logo
136 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
