Question about ASUS EN6200LE/TC256/TD GeForce® 6200LE, PCI Express Graphic Card
I have purchased a Asus en6200le card for dual monitors at work. I have also purchased the correct DVI-I to VGA adapter so i can run 2 vga monitors, but i still cannot get the second monitor to show how can i overcome this
  • james155 Jul 17, 2009
    I do not have the option to select my external monitor (im using XP btw), so does this suggest the hardware doesnt support?
    The card i purchased specifically says dual view is supported.
    What is maxivista?
    thanks
    What is maxivista?
    thanks
    President:
  • 627 Answers
Right-click the desktop, and then click Properties.
In the DisplayProperties dialog box, click the Settings tab.
Click the Display list and select your external monitor. If you do not see multiple monitors listed, your computer hardware may not support Dualview. You can still use MaxiVista to configure a second computer as an additional display, however.
Select the Extend my Windows desktop onto this monitor option. Click Apply or OK
Posted on Jul 17, 2009
  • Robert Nyilas
    Robert Nyilas Jul 17, 2009
    at the display properties are two monitors
    click on the second monitor and check Extend my Windows desktop onto this monitor option
    by the way, did you installed the drivers for your videocard?
2nd monitor does not work with DVI to VGA converter cable. My video card has VGA and DVi ouputs.
The problem could be in the adapter to the video card. There are different types of DVI connections. If the adapter does not have the proper set of pins then the card will not recognize that a monitor is connected at that port. Monitors themselves have no bearing on whether a single or dual monitor set up will work or not. Digital Visual Interface Follow this link, it may help you determine if the adapter you are using is correct for the graphics card.
Apr 22, 2014 | Acer ET.CV3WP.E05 LCD Monitor - V193WEJb...
Dual monitors t3516
Is it just like this with NO graphics card installed?
http://products.pacificgeek.com/emachines_t3516_celeron_d_3_20ghz_512mb_120gb_cdrw_dvd_xp_1013070674.php
If so, Not happening.
The I/O area is to the left side. (Input/Output area)
In this rectangular area you see;
1) PS/2 mouse port, and PS/2 keyboard port, at the top.
2) Orange port below them.
3) Black port below it.
4) Down below all of the above is the blue VGA port.
If you do not have a graphics card, your monitor is plugged into this blue VGA port.
If so you are using Integrated Graphics. Another term used is OnBoard graphics. ON the motherBOARD.
Do Not try to use a splitter cable, and run two monitors off of this VGA port. Ain't happening.
See the four long slots at the bottom of the computer? The bottom one has the Ethernet adapter card in it?
A graphics card, (Video card. Same/same), is installed on the motherboard, and the end of it sticks out one of those 3 unoccupied slots.
Each of those slots are known as Expansion Bay Slots.
When you choose what slot you want, you remove the Expansion Slot cover, for that slot.
My sources indicate the motherboard is an Intel D101GGC motherboard,
http://www.e4allupgraders.info/dir1/motherboards/socket775/D101GGC.shtml
There are 2 white PCI slots at the bottom.
There is 1 black PCI-Express x1 slot above them.
There is a longer black PCI-Express x16 slot above it.
The PCI-Express x16 slot is for a graphics card. It is the best graphics card slot on your motherboard.
(The white PCI slots are lame. The PCI-Express x1 slot, is NOT used for a graphics card)
Suggest you use a PCI Express graphics card for your computer, and run two monitors at the same time.
From here it depends on what the two monitors are. Do you have two monitors that use a VGA cable?
Example of a VGA cable, and a VGA connector,
http://en.wikipedia.org/wiki/VGA_connector
Or do you have a monitor that uses a VGA cable, and a monitor that uses a DVI cable?
Example of DVI connectors,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
Or do you have one monitor with a VGA cable, and a monitor that has a DVI cable?
Post in a Comment as to the monitor manufacturer name, and model number.
[ For example I am using an HP 2009m (20 inch widescreen), and a 26 inch RCA EN-V HDTV, as dual monitors ]
This is an example of a very economical PCI Express graphics card, that will run dual monitors,
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130755
You can use a monitor with a VGA cable (Blue port), and a monitor with a DVI cable.
You can use two VGA monitors, with using a VGA to DVI adapter, for one of the monitors.
You can use two DVI monitors, with using a DVI to VGA adapter, for one of the monitors.
Already have a graphics card, and two monitors connected to it?
1) Right-click on an empty area of your desktop screen.
2) At the bottom of the list left-click on Properties.
3) In the Display Properties window, left-click on the Settings tab.
4) Left-click on the rectangular monitor icon, that has the 2 in it.
5) Go below to the left, and left-click on the empty square next to-
6) Go below to the right, and left-click on Apply.
7) Go below to the left, and left-click on OK.
Your desktop screen is on your second monitor.
Need guidance past this post in a Comment.
Regards,
joecoolvette
Jun 09, 2012 | Computers & Internet
I run a PC with the newest sandy bridge hardware and a Msi GTx 560 Twin Frozr II video card (dual Dvi-I input and a mini-hdmi input). I also have a BenQ G2222 monitor (one VGA input and one DVI-D input),...
The problem might be with your ram. Try taking it out and putting it back in. You might also have a problem with the video card. Make sure it is secure and screwed in.
Mar 19, 2011 | Computers & Internet
Dual Screens with a VGA connection
The easiest way would be to purchase a video card that has 2 vga ports on it, allowing dual monitor support. Here is an example.
http://www.amazon.com/Matrox-G450-16MB-Dual-Video/dp/B00194CT5A
Dec 29, 2009 | Samsung 2333SW 23" Widescreen DVI LCD...
How to add second monitor to asus cg5270?
The Asus Essentio CG5270 is a desktop computer, so I see it was placed in the wrong category. No prob!
Certain selected models of the Essentio CG5270 come with a graphics card. If you have this graphics card, you can use two monitors at the same time. (Dual monitors)
If you do Not have one of the selected models with a graphics card, you have to purchase, and install a graphics card.
You can purchase a decent graphics card that has dual DVI ports, and is relatively inexpensive.
Looking at the back of your computer,
1) View the purple PS/2 port. The port where you can plug in either a Keyboard, or a Mouse.
Come straight down to the blue VGA connector. This port is to connect a VGA monitor, (Looks like a small TV), or an PCD monitor that has a VGA cable.
(Flat screen monitor)
Look to the immediate right of the blue VGA connector. This white port is a DVI connector.
You can connect an LCD monitor to it that has a DVI cable.
This two ports are Onboard graphics ports. (On the motherBoard)
You Cannot connect a monitor at the same time to these ports.
BIOS will only recognize one port.
You have to have a graphics card also.
You can connect two monitors to a graphics card,
IF, it has two graphics ports. For this model it looks like the best they are offering, for connecting two monitors is a DVI port, and a VGA port.
You Cannot hook a monitor up to the Onboard graphics port, and to the graphics card port.
BIOS will only recognize Onboard, or a graphics card. It won't do both.
IF, you have a graphics card.
There are four horizontal slots, on the bottom of the computer tower. IF, you have a graphics card it is usually in the second slot down.
It - Should have a white DVI port on the left, and a blue VGA port on the right.
Again as stated above, you can purchase a graphics card that has two, (Dual) DVI ports on it. Then connect two monitors to the graphics card.
(Digital Visual Interface:
A DVI-I female port is White in color, and has 3 rows of 8 holes. To the right of the holes is a metal bar, shaped like a Plus Sign.
There is a hole in each of the four corners, of the Plus Sign.
Four holes in total.
VGA:
The VGA female port is usually Blue in color.
There are 3 rows of 5 holes. They are staggered.
If you wish you can plug 1 monitor into the VGA port on a graphics card, and the 2nd monitor into the DVI port on the graphics card.
They also make a Male DVI to Female VGA adapter plug. Has Male DVI pins, and female VGA socket holes.
This is for a monitor that has a VGA cable, and you are adapting it to plug into a DVI port on the graphics card.
Useful if you have two monitors with a VGA cable.
(They also make a Female DVI to Male VGA adapter. Make sure what you want, and what you are purchasing)
NOW, (Not shouting),
The following applied to Windows XP. I see the Essentio CG5270 comes with Windows Vista.
See if the following will crossover to Vista.
1) You have two monitors plugged into your graphics card. Monitors are On.
2) Computer is turned on next. Windows loads up.
3) Right-click on an empty area of your desktop screen.
4) In the small menu that comes up, go to the bottom, and left-click on Properties.
5) In the small Display Properties window that comes up, left-click on the Settings tab.
6) You will see a large blue rectangle with the number 1 in it. This is your Primary monitor icon.
This is your main monitor.
You will see a smaller rectangle in the background, and it will be 'ghosted' out. This is your Secondary monitor icon. This is the second monitor you hooked up.
Left-click on the Secondary monitor icon.
7) The Secondary monitor icon will 'light up'.
NOW,
IF, your Primary monitor is sitting in front of you, and your Secondary monitor is sitting on the Right, it's okay.
IF, your Secondary monitor is on the Left, you need to make a change.
Left-click on the Secondary monitor icon, hold the mouse button down, and drag it over to the Left side of the Primary monitor icon.
Why?
Because you need to have those icons sitting the same way, as your two monitors are sitting on your computer desk.
More will be revealed as you read on.
8) Go to the bottom of this window. You will see -
Extend my Windows desktop onto this monitor,
and a square box to the left of it.
Left-click in the middle of that square box.
Go to the bottom right, and left-click on Apply.
Go to the left of Apply, and left-click on OK.
Bling! Your second monitor has your desktop on it!
When you go online with your computer using dual monitors. Your Primary monitor will have the what you see online. Your Secondary monitor won't.
Go all the way to the Left side of your monitor screen, with your mouse cursor.
Left-click, and hold the mouse button down. Drag your mouse to the Left.
You should see what you're seeing on the Primary monitor, being dragged over to your Secondary monitor.
No?
Then go to the Right side of your Primary monitor screen, and drag it the other way.
Questions?
Dec 29, 2009 | ASUS Eee PC 1000H Laptop
What dual video card is compatible with the M52?
The 256MB ATI Radeon HD 2400 XT Dual-VGA or Dual-DVI, TV-Out Graphics Card (43R1962)
The 128MB ATI RADEON X300 VGA, VGA PCI-e Dual Head Graphics Adapter (40Y8405)
The 64MB NVIDIA GeForce 6200 VGA PCI-e Dual Head ThinkCentre Graphics Adapter (73P2517)
The 256MB ATI Radeon X1300 Dual-VGA or Dual-DVI, TV-out PCI-Express Graphics Adapter (41U5028)
The 128MB ATI RADEON X300SE Dual-VGA or Dual-DVI Dual Head ThinkCentre and Lenovo PCI-e graphics adapter (41U4813)
The 128MB ATI RADEON X700 VGA, DVI-I, TV-Out PCI-e Dual Head ThinkCentre Graphics Adapter (73P2518)
All above are compatible with the ThinkCentre M52. Hope this helps, Best Regards, - md
Nov 10, 2009 | IBM ThinkCentre M52 8113 - P4 551 3.4 GHz...
Running two external monitors
Okay. Thanks for the info too...
I looked at the user's guide for this laptop and see exactly what you're saying.
I found it here: http://manuals.info.apple.com/en/MacBook_Pro_Users_Guide.pdf
So, the laptop comes with a DVI to VGA adapter because the only port on this system that will allow you to connect an external display is one that connects to a DVI port (in short, you don't have a VGA port).
moz-screenshot-3.jpgmoz-screenshot-4.jpgOkay, you have a couple of options here:
  1. You can purchase a docking station which, depending on where you buy it from, will be more expensive than the other options. If you decide to purchase one, first make sure that it will provide the ports that you need. For example, my docking station has one DVI port and one VGA port. If and when I connect a second monitor, I will connect it to the DVI port using a single DVI to VGA adapter (as I don't have any flat panels that connect directly to a DVI port). 63efdf2.jpg If you purchase the docking station, make sure it has both the DVI and VGA or you're stilling floating up the same creek without a paddle.
2. You can't use the cable that came with the laptop because it only connects to the DVI port
of your laptop with one VGA connector on the other end, therefore, supporting only one
external monitor. You need either a DVI to DVI and VGA adapter or a DVI to VGA and VGA
adapter
This is a DVI to DVI and VGA adapter
This is a DVI to VGA and VGA adapter
Okay, now that we covered that information, let's get down to business...
Since you already have your monitors and probably don't want to spend $200-300 on a docking station, this is the best and quickest solution:
You have two monitors both with VGA connectors. Your laptop has 1 DVI port on its side (correct?).
Look at the image of the DVI to VGA and VGA adapter. You need to purchase one of these. It will allow you to connect one end to the DVI port on the laptop and connect your monitors to the two VGA ports on the other end...viola!!
You can use the DVI to VGA and DVI adapter but it would complicate your situation unless you were trying to connect a VGA and DVI monitor so we can eliminate that option unless you are desparate and that's the only adapter you find to purchase.
These adapters are very inexpensive (probably anywhere from $9 to $19. You should be able to purchase them at a store that sells computers, hardware, software, etc. You may even find them at Wal-Mart or RadioShack. If need be, you can purchase one online. However, if you go out and search a couple of stores or computer places, you should find one and be able to connect your monitors when you get home.
Feel free to leave any comments if you need further information.
Thanks for using Fixya and don't forget to rate this solution.
Apr 03, 2009 | Apple MacBook Pro Notebook
Radeon R9600/XT GRAPHICS CARD
Yes, they both will act independently if you choose to use it that way or they will show the same picture, one is a DVI output and the other is VGA. Use the ATI’s CATALYST software suite provides the ultimate software required to enjoy the full acceleration of your ATI Graphics Accelerator card. You can use it to separate your Primary video from your Secondary video.
Jan 03, 2009 | Abit R9600XT-VIO RADEON 9600 XT, (256 Mb)...
Monitor Problem
Well assuming you used the same video cable when you tested the monitor on the Asus PC you?re left with: - Physical problem with the Asus video card. - Asus video card configuration problem. - BIOS configuration problem - Possibly a problem with the DVI/VGA adaptor depending on the answer below. A couple of questions about the Asus before we start: - I?m not sure I understand how the DVI/VGA converter figures into this. Is your cable coming off the monitor DVI thus you need it to plug into the Asus VGA connector? If yes who is the manufacturer of the device and what model do you have? - Has the Asus worked in the past with another monitor or is this new? - What is its history/configuration?
Mar 11, 2007 | ASUS T2-AH1 Barebone
ASUS EN6200LE/TC256/TD GeForce® 6200LE, PCI Express Graphic Card Logo
167 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
