Question about Western Digital Computers & Internet
Plug and play manager states drive disappeared without first being prepared. Drive is still there but is "ghost" . This is a data drive only, (D) not the C drive.
It is not fixed yet, I'm taking it to a computer repair place, as other problems have cropped up. Thanks anyway
Posted on Jul 18, 2009
My iqon hard drive will power up but i cant access it
Clicking sound on an external hard drive is an indication that it's quiting to work. You mentioned that it's just stopped working, you may need to check the Disk Management of your computer to see if you could still reformat it. To do this, please follow the steps below:
FOR WINDOWS XP AND VISTA:
1. Make sure that the HD is properly connected to the computer.
2. Right-click 'My Computer' or 'Computer' folder and then go to "Manage".
3. Locate and click Disk Management.
4. Then, take note of the drive letters that will appear on the screen.
5. While the Disk Management window is opened, unplug the HD and check which drive letter will disappear.
6. If a drive letter disappears, then that is your external 250GB HD. You may reformat it to make it work again.
NOTE: Reformatting the HD will erase all the files saved in it. You may want to bring your HD in any data recovery center to retrieve the important files. If the HD didn't show up under your Disk Management, then there's nothing that we could do but to bring your HD in to the Data Recovery to save the files.
FOR MACINTOSH OSX:
1. Connect your HD to the computer.
2. Click 'Go' (located near the Apple icon, Finder, File, Edit and View).
3. Select Utilities and then click the Disk Utility Icon.
4. Take note the drive letters and then unplug the HD.
If a drive letter disappears, that's your HD. If nothing disappears, then the computer no longer detecting the HD.
Source
Nov 26, 2012 | Computers & Internet
Dane elec portable hard drive not recognised by win 7 pc
External hard drives are plug-and-play devices used to store music, video and data files. Once the drive is connected, the computer checks its systems for the appropriate drivers, loads them, and the external drive is ready to use.
If the computer does not recognize the external drive, plug it into another computer to ensure the drive is not corrupted.
If the drive is good, a few simple steps should help re-enable the drive for use.
Switch the power button to "off."
Disconnect the power cord from any extension cords or power strip, then re-seat the power cord into the hard drive.
Connect the cord directly into an outlet and power up the drive.
If the drive is powered and still not working, check the data cable.
Power down the hard drive and disconnect the data cable from the computer.
Wait 30 seconds to one minute.
Reconnect the data cable and power up the drive.
If the drive is not detected, power down the hard drive and connect the cable to a different port.
Power up the drive.
If the drive is detected but not working, check for a missing driver.
Click on the "Start" button, right-click "Computer" and select "Manage."
Enter your administrator password if requested.
Select "Device Manager" and double-click "Disk Drives."
Right-click the yellow exclamation point and install the missing driver. Close the Device Manager.
If the drive is detected but not working check to ensure it has an assigned drive letter.
Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer.
Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested.
Click on "Disk Management," right-click the external hard drive, click "change drive letter and path," and click "Add."
Assign a drive letter.
Avoid using A, B or C (C is usually assigned to the computer's internal hard drive). Click "OK" close the window.
If the drive is detected but not working, check whether the drive is in sleep mode.
Click the "Start" button, right-click "Computer" and select "Manage."
Select "Device Manager" and double-click "Universal Serial Bus Controllers."
Double-click the first instance of "USB Root Hub" or "Root Hub."
Check for the hard drive.
If the drive is not visible, move to the next instance of "USB Root Hub."
Continue checking each instance until the hard drive is located.
Once located, click the "Power Management" tab and uncheck the "Allow computer to turn off this device to save power" box, click "OK," then close the Device Manager.
Power the computer down, wait 30 seconds to one minute, and power the computer back up to ensure the drive is detected.
Hope this helps
Nov 01, 2012 | Dane Elec DANE-ELEC SoMobile 500GB USB 2.0...
How do you get the Iomega eGo Hellium 350GB hard drive to be recognized and initialized by Microsoft Vista Operating system? Have tried the instructions from Iomega and they do not work. The system...
one thing that is possible, is that you may have another drive letter assigned to the letter the iomega is trying to use.
Try this....Click on your start orb and type in Disk Management.
open the Disk Management utility in Windows and see if you see the iomega drive listed in the list of disks on the bottom.
If you DO see the iomega drive there, make sure it shows a healthy partition (It should say something like Fat 32 or NTFS as the file system type...if it shows "RAW" or "damaged" or something like that, you may need to erase and format the drive)
Then, try right clicking on the drive and choosing "Change Drive Letter and Paths..."
from there try a new drive letter in case you already have another peripheral using the drive letter the iomega drive is trying to grab. This could cause Windows to recognize the drive but still be unable to see it in your explorer.
Good Luck
May 09, 2011 | Iomega eGo Helium 1TB USB 2.0 Portable,...
Ghost floppy drive
No virus, the mb 's chipset is dying. Prepare for an imminent failure - backup all your data and save money for a new one.
Jun 20, 2010 | Biostar MCP6P-M2 Motherboard - v6.0,...
Mylacie drive is no longer connected to my computer. When it is turned on, there is a clicking noise and the LED light is alternating between red and yellow. What do you think the problem is?
when a disk makes a clicking noise, in most cases (99%) that means that the disk has crashed. i'm sorry to inform you that the data you had on the disk is lost, unless you are prepared to pay lots of money to a company that takes the disk apart to retrieve data manually.
Jun 24, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Weird clicking sounds
FOR MACINTOSH OSX:
Jun 01, 2009 | Iomega (33215) 250 GB Hard Drive
Reformatted computer, found files with GHS & GHO,how to recover?
Hi 'jen2x':
I’m Melinda and I represent Symantec’s PR Department.
Norton Ghost has the following key features:
  • Full system backup (disk image)—Backs up everything on a hard drive or partition.
  • File and folder backup—Backs up only the specific files and folders you choose rather than saving an entire drive.
  • FTP backup—Copies recovery points to a FTP site for easier offsite backup management. NEW
  • Offsite backup—backs up your files to NAS (Network-Attached Storage) devices. NEW
  • Symantec ThreatCon integration—triggers incremental backups whenever ThreatCon reaches a specified threat level. Great for computers without virus protection. NEW
  • Incremental and differential backup—Backs up only files that have changed.
  • EXCLUSIVE! Google Desktop™ integration—Makes data recovery even faster with searchable backup indexes.
  • LightsOut Restore—Restores your system with an on-disk software recovery environment—no bootable CD required.
  • EXCLUSIVE! Remote management—Controls other Norton Ghost installations (12.0 or higher) on your local area network.
  • Advanced compression and encryption—Minimizes storage space and helps keep sensitive documents safe.
To download the 14-day trial of Norton Ghost, please visit our site here: http://nct.symantecstore.com/fulfill/0184.074.
To find out more about Norton Ghost, please visit our site here: http://www.symantec.com/themes/ghost/index.jsp
Regards,
Melinda
melinda.jenkins@ar-edelman.com
http://twitter.com/MelfromSymantec
May 15, 2009 | Symantec Norton Ghost 2003 for PC
I cannot see my free agent external drive
u can see the news that the st drive has many bugs,and which cannot be detected by the pc is the most popular one,so u can update the firmware from seagate official and if still cannot repair,u can go back to me,honglake@gmail.com
Mar 15, 2009 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
Hard drive swap and repair
use a back up service for that...you can find one through this link, called Mozy @ home
May 05, 2008 | Dell Latitude D600 Notebook
O.S.
you can use windows backup facility, start>all programmes>accesories>system tools>backup, or use a third party software similair to norton ghost if you wish to back up the operating system as well.
Sep 03, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
82 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
