Question about Watches
My sonata watch was day and date are changing differently one day it was 9 pm another day it was 10 pm how to reset it
escapement
  • 2334 Answers
SOURCE: unable to set day/date/year &time
Follow this link and download instructions for your watch:
http://www.armitron.com/watch_instructions.asp
Do not forget to rate, please.
Posted on Mar 11, 2009
  • 4 Answers
SOURCE: Seiko Diamatic Day Date Automatic Watch No: 219050
I have a Seiko Diamatic 780632. To set the day and date, pull the crown once and wind it upwards (away from you) to set the date; winding it downwards (towards you) will set the day. To set the time, you have to pull the crown twice and wind it towards you.
Posted on Nov 14, 2007
  • 14 Answers
SOURCE: Watch has correct day and date only 1/2 each day
The watch thinks at Noon it is really midnite, so you must scroll 12 hours ahead to repair this. There are usually 2 "clicks" on the stem of the watch when you pull it out, 1 will set time, 1 will set the day/date, be careful to pay close attention to which is happening when you pull out the stem, and setting should go well after that.
Posted on Dec 01, 2007
SOURCE: HOW TO CHANGE DATE
I have an old analog quartz Timex watch with a mechanical day and date display. The stem pulls out to only one position which moves the hands. As the hands are rotated past the midnight (not noon) position the date changes first and then the day.
The simplest way I found to adjust both the day and date is to advance the hands forward through the midnight positions until you reach the desired day. As soon as the day clicks into the desired position back up the hands through the midnight position to about the 10 pm position. This resets the mechanism to set the day/date. Then advance the hands towards the midnight position carefully until the date changes and before the day changes. Again back up the hands through midnight until about 10 pm and then forward to advance the date, stopping before the day changes. Repeat the last two steps until you get the correct date. Then rotate the hands back to the correct time, if it's a morning time be sure to rotate all the way back through 12 noon to the correct time. Hope this helps.
Posted on Aug 26, 2008
  • 37 Answers
The Skagen watches have  two-step stem; fully pulled out will change the time and partially pulled out will change the date (only goes one way so try turning it counter-clockwise or clockwise - I forget which is correct).  It's easier to find the date length by extending it all the way and then go back toward the case.  It won't change the date if you run it through a 24-hour cycle - you have to do the half-way thing.  Hope this helps.
Posted on Nov 24, 2008
Why does the date on my seiko sne881 change at 12 noon?
probably because you have it set to 12 pm midnight and not 12 noon so at 12 noon it is actually midnight when the date will change
reset the time of the day to am or pm and any pm settings will change the date at 12 midnight.
Aug 30, 2015 | Seiko Watches
Tip
How To Set The Time/Calendar For Your Seiko Watch
<span style="font-weight: bold;">Time Setting for Models Without Calendar</span><br /><span style="font-style: italic;">Note: When setting the minute hand of a quartz watch, advance it a few minutes ahead of the time and then turn it back to the exact time.</span><br /> <ol> <li>Pull out the crown all the way. <span style="font-style: italic;">Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.</span></li> <li>Adjust the time by turning the crown in the desired direction.</li> <li>Push the crown back in to the normal position.<span style="font-style: italic;"> Note: If your watch has three hands, push the crown back in to the normal position in accordance with a time signal for "00" seconds.</span></li></ol><span style="font-weight: bold;">Time/Calendar Setting for Models With Calendar</span><br /><span style="font-style: italic;">Note: The date will change gradually between 9:00 PM and 4:00 AM. For some models, however, it will change instantly when the hands pass the 12 o'clock marker at midnight.</span><br /> <ul style="font-weight: bold;"> <li>For models with date calendar</li></ul> <ol> <li>Pull out the crown to the first click.</li> <li>Turn the crown until the previous day's date appears in the calendar frame.</li> <li>Pull out the crown to the second click, and advance the hour and minute hands until the desired date appears. <span style="font-style: italic;">Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.</span></li> <li>Adjust the time by turning the crown in the desired direction.</li> <li>Push the crown back in to the normal position.<span style="font-style: italic;"> Note: If your watch has three hands, push the crown back in to the normal position in accordance with a time signal for "00" seconds.</span></li></ol> <ul style="font-weight: bold;"> <li>For models with day and date calendar</li></ul> <ol> <li>Pull out the crown to the first click.</li> <li>Turn the crown until the previous day's date appears in the calendar frame.</li> <li>Turn the crown in the opposite direction until the desired language (bilingual) for the day before the desired day appears in the calendar frame. <span style="font-style: italic;">Note: For Cal. 7009 and 7019, push the crown back in to the normal position and then push it repeatedly to set the day.</span><br /></li> <li>Pull out the crown to the second click, and advance the hour and minute hands until the desired date and day appears. <span style="font-style: italic;">Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.</span></li> <li>Adjust the time by turning the crown in the desired direction.</li> <li>Push the crown back in to the normal position.<span style="font-style: italic;"> Note: If your watch has three hands, push the crown back in to the normal position in accordance with a time signal for "00" seconds.</span></li></ol><span style="font-weight: bold;">Note:</span> Do not change the calendar between 9:00 PM and 4:00 AM as it may not change properly. If it is necessary to set the calendar during that time period, first change the time to any time outside those hours, set the calendar and then reset the correct time. When the day shifts automatically to the next day, the other language will temporarily appear.<br /><br /><span style="font-weight: bold;">Note:</span> When setting the hour hand, check that AM/PM is correctly set. The watch is designed so that the calendar changes once in 24 hours.<br /><span style="font-style: italic;">Turn the hands past the 12 o'clock marker to determine whether the time is set for the AM or PM period. If the calendar changes, the time is set for the AM period. If it does not change, the time is set for the PM period.</span><br />
on Feb 15, 2011 | Watches
Date changes at mid day not at mid night.
Your watch is 12 hours out of step.The date changes ever second rotation of the hour hand.
If you advance the time 12 hours, the date will change at midnight.
You may have to re-set the date.
Sep 16, 2011 | Tissot PRS 200 Wrist Watch
My timex 1440 sport watch has buttons that are slightly different than any manuel I can find on line. the buttons are as follows going clock wise from top left mode, stop/start,adjust,and indiglo. I just...
Try this:
To set time and date:
1) With time and date showing, press SET.
2) Seconds ?ash. Press START/STOP to round time to nearest minute,
setting seconds to zero.
3) Press MODE. Hour ?ashes. Press START/STOP to change hour,
including AM (no symbol) and PM.
4) Press MODE. Minutes ?ash. Press START/STOP to change minutes;
hold button to scan values.
5) Press MODE. Month ?ashes. Press START/STOP to change month.
6) Press MODE. Date ?ashes. Press START/STOP to change date.
7) Press MODE. Day ?ashes. Press START/STOP to change day.
8) Press MODE. Time format ?ashes. Press START/STOP to select
12- or 24-hour time format. 12-hour format has AM/PM.
9) Press SET, at any step, to exit and save settings.
Date (day of month) appears in upper part of display in Time mode.
Press and hold START/STOP to see month and date in large digits.
Jan 19, 2018 | Timex 1440 Nylon watch
The date adjusts at 1am. any solution? thanks
mcdevito75 here, That sounds about right, each watch is slightly different, some watches, have the date change at 10:30 PM and some at 11:00 PM, and if your Tag also has the month or day to change along with the date, this could account for the date changeing kind of late. I don"t think it"s anything to worry about.
Aug 13, 2010 | Tag Heuer Formula 1 Date Quartz Stainless...
Setting day and date - the day and date change at the wrong tome of day
To sync the correct 12 hour with your day you need to set the date to the day before (if today is Wed 21, then make sure the day window reads Tues 20). Then spin the analog hands until the the date window turns to Wed 21. At this point your watch is reading 12 AM (midnight). Then keep turning to set the correct time. If it is 9 am then stop the hands the first time you hit the 9 marker. If it is 9pm, then keep turning until the SECOND TIME your hour hand meets the 9 marker. This is now set for 9 pm. The day (Mon thru Sun) sometimes needs to be set seperately from the day; it may take a couple of tries but use the directions above and patience and you will achieve your goal.
That's how you do it. If you need more clarification let me know.
Oct 20, 2009 | Seiko Watches
Need instructions for Timex 1440 Sport watch
TIME AND DATE
1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
2. Press ADJUST to set SECONDS to zero.
3. Press START/STOP to select MINUTES.
4. Press ADJUST to change.
5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
6. Press MODE when done.
7. To display DATE from Time display , press START/STOP.
8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
4. Press ADJUST to change.. Press MODE when done.
5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
2. With time displayed, press MODE to select Chrono Mode.
3. Press START/STOP to start.
4. Press ADJUST to view lap time. Press again to sesume lap timing.
5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
6. Repeat for successive laps.
Nov 22, 2008 | Timex 1440 Nylon watch
Date setting of Frederique constant
hi
never change week or date when day is on "sun" or "mon" also never change date or week or day when time is between 9 pm and 5 am.
to change day, move time back and forth between 10 pm and 2 am.
moon will change only after 24 hr round (not during quick day change)
hope this helps
eli
Oct 17, 2008 | Watches
HOW TO CHANGE DATE
Nov 18, 2007 | Skagen 355LSSM Wrist Watch
Date changes wrong time
thats because analog watches don't know the difference between AM/PM. First reset the time, moving the hour and minute hands another 12 hours will let you know exactly what mode its in (am/pm) first allowing you to set the date correctly.
Nov 12, 2007 | Watches
Watches Logo
427 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
