Question about Motorola Mobility Bluetooth Hands Free Headset Wireless Headset
Problems with passkey bluetooth MB Phone system
    Guru:
  • 395 Answers
Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Posted on May 06, 2010
4 Suggested Answers
SOURCE: need passkey to reconnect bluetooth
Use this link to get installation instructions! http://web.jabra.com/JabraCMS/NA/EN/Misc/GettingStartedBT350
Posted on Jun 22, 2007
ILikeBMW
  • 117 Answers
SOURCE: I need the passkey for my H350 Motorola Bluetooth. I am trying to set it up with a new Samsung phone. Can you please provide the passkey
Hello there
The universal pass key that all of these leave the factory with is 0000 (four zeros).
Hope this helps, please don't forget to rate me.
Thanks
Posted on May 20, 2009
SOURCE: need passkey to connect my tb20el bluetooth to my phone
for tb-20el:
1. ensure that your phone's bluetooth feature is on
2.Ensure that the headset is off(press and hold button on your headset (called multifuntcion button) for 2-4 sec, teh indicator light will flash red)
3. press and hold the multifunction button for 6-8 seconds until the indicator light alternately flashes blue and red
4. set your phone to find new device
5. Ente rpin '0000' (four zero) then press OK or yes
6. this should complete the pairing.
Posted on Apr 01, 2010
I cant turn on the bluetooth on my zte sonata phone to listen to my music on my LAX MAX bluetooth speaker.
  1. Before you begin, place the Bluetooth device in pairing mode . Open the Notifications panel and tap Bluetooth . Or, from the home screen, tap > System settings and slide the Bluetooth switch to the On position to turn on Bluetooth . When Bluetooth is on, the icon will appear in the status bar .
  2. Tap Bluetooth .Your phone will automatically search for Bluetooth devices and will show all visible devices in range .
  3. Tap the device you want to pair with .
  4. If necessary, confirm that the Bluetooth passkeys are the same between the two devices and tap Pair . Alternately, enter a Bluetooth passkey and tap Pair .
    Pairing is successfully completed when the other device accepts the connection or the same passkey is entered .
Dec 28, 2014 | Cell Phones
How can I on the bluetooth on my laptop aspire 4743Z?
Connecting your Bluetooth wireless phone with your laptop is called pairing, and I'll use a Blackberry Curve to show you how it works. I'm assuming your laptop comes with a built-in Bluetooth adapter (or you can also get a Bluetooth adapter that plugs into one of your USB ports).
First make sure that Bluetooth is enabled on your phone. For Blackberry phones, that means selecting the "Set Up Bluetooth" application from the main screen, and then selecting "Enable Bluetooth" after clicking the menu button.
Next, set up your computer to allow Bluetooth connections. If your computer comes with Bluetooth, then you'll see a Bluetooth icon in your Control Panel (Start button -> Control Panel from Vista):
control-panel-bluetooth.jpg Double-click the Bluetooth icon and you'll see a Bluetooth Devices dialog. Click the Options tab and make sure the options to "Allow Bluetooth devices to find this computer" and "Allow Bluetooth devices to connect to this computer" are both checked
bluetooth-devices-options.jpg Next, click the Devices tab and then click the "Add" button. This will open the Add Bluetooth Device Wizard, and after verifying that your device is set up and ready to be found (ie. Bluetooth has been enabled on your wireless phone) it will try to find your phone.
add-bluetooth-device.jpg Select the Bluetooth device and click Next to set up a passkey, which is a number that associates your computer with a Bluetooth enabled device. For security reasons, most Bluetooth enabled devices (with some exceptions, such as mice) require you to use a passkey. Using a passkey helps ensure that your computer is connecting to the device that you intended and not someone else's device that is nearby.
You can choose your own passkey or let Windows choose one for you. Click Next and then pick up your phone, which will prompt you to enter in the passkey. After entering the passkey in your phone, Windows will finish the pairing process and your phone will be connected via Bluetooth.
May 10, 2011 | Acer Aspire 5742Z-4200 Notebook
What's the passkey for my bluetooth ? Than you !
If you are looking for the passkey for your bluetooth headset, by default, it is usually 12345,1234.0000 or 00000.
If you need the passkey for your phone's bluetooth connection, you have to set this one by yourself. There is no default passkey for it.
When you want to pair with another phone, you enter the same key as you entered on your phone on the phone you want to pair with.
Hope this helped you? Please comment for more information
Jan 30, 2011 | Cell Phones
Trying to connect jabra BT2080 to phone. says enter passkey?
  1. Bluetooth device A looks for other Bluetooth devices in the area
  2. In order to find other Bluetooth devices, Bluetooth device A must be set to discoverable mode. When set to discoverable, Bluetooth device A will allow other Bluetooth devices to detect its presence and attempt to establish a connection.
    You may set your discover setting off if you like (It is recommended that you turn it off when not using the Bluetooth). When the discover setting is off, no other Bluetooth device will be able to find it. Undiscoverable devices can still communicate with each other but they have to initiate communication themselves.
  3. Bluetooth device A finds Bluetooth device B
    Usually the discoverable device will indicate what type of device it is (Such as a printer, cell phone, headset, etc.) and its Bluetooth device name. The Bluetooth device name is the name that you give the Bluetooth device or the factory name that originally was programmed.
  4. Bluetooth Device A prompts you to enter a password (PassKey)
    With advanced devices (i.e. computers, smartphones), both users must agree on the Passkey and enter it into their device. The code can be anything you like as long as it is the same for both Bluetooth wireless devices.
    On other devices, such as Bluetooth headsets, the Passkey stays the same. Refer to the product's manual for the default passkey. Most often, the default passkey is "0000".
  5. Bluetooth device A sends the Passkey to Bluetooth device B
Jan 26, 2011 | Jabra BT2080 Bluetooth Headset
Have a dell studio 1555 with bluetooth configured into the system. Have tried sinking a Palm phone using 0000 and 1234 as passkeys when requested to provide one , but neither passkeys have worked. Are...
I would recommend calling the manufcturer and explaining the issue. They should be able to reset the passkey for you and give you a default one.
Nov 08, 2009 | Dell Studio 15 Laptop
Need passkey for the pairing for bluetooth with
The passkey in the Phone prompts up only when you are trying to pair your device to another device,
So, you can provide 1234 as the password and another user who is pairing with you should also provide the same,
Incase if it is not working under Generic key or if you are facing any other problem related to Bluetooth pairing, Please contact your Service Providor and check..
Oct 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
Need a passkey for samsung omnia
hi, default passkey is 0000. Enter this passkey in the asus notebook when it asks for passkey.
Both the passkey should be same to enable file transfer through bluetooth.
Sep 19, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Need à passkey to browse my USB Bluetooth Dongle
the out of the box passkey for most bluetooth devices is usually 0000
The passkey has to be entered on both devices so they can pair.
Aug 04, 2009 | Acer Computers & Internet
Passkey
The passkey is 0000. If you have a problem, reset the headset. Turn the headset off and hold down the call button for 8 seconds until the headset flashes blue and red signaling that it is in pairing mode for the next 120 seconds. While the headset is in pairing mode, use the phone menu to search for Bluetooth devices and select "220Plantronics." (If the headset is already listed in the Bluetooth menu, delete it before searching to pair the device.) When prompted for a passkey, enter 0000. Headset will falsh blue when paired successfully.
Nov 14, 2008 | Plantronics Explorer 220 Bluetooth Headset...
Motorola Mobility Bluetooth Hands Free Headset Wireless Headset Logo
655 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
