Question about Cisco PIX 515E Firewall
Hi when ever i configure the pix it take al comand and at link is up when i save all the confregation and boot it then act link get down plz tell me the solution
  • 39 Answers
I would check negotiaion on the port that goes down if you are sure the cabling is correct
Posted on Jan 24, 2010
Reset password Catalyst 4006 Ethernet Switch
Depending on the Supervisor Module model, most likely it's a standard Cisco's "password recovery procedure":
Connect to the console
Reboot the switch (power cycle)
Start pressing Ctrl-C till you get to the BOOTROM
Change boot configuration register to 0x2142 (confreg 0x2142)
Boot the switch. It will ignore confuguration and boot "empty".
Go to "enable mode".
Copy startup configuration to running configuration ("copy start run")
Change boot register back to 0x2102 (conf t -> conf 0x2102)
Write config (write mem)
Reboot
Good luck,
Mike / CCNP, CCDP, CCSP, CCVP
Headset Adapters for office phone system
May 03, 2016 | Cisco Catalyst 4006 Chassis ( 4006)
Confreg command
Try just typing confreg from rommon mode and going through the dialog.
Or from the CLI in configuration mode:
Router(config)#line con 0
Router(config-line)#speed 115200
Dec 02, 2013 | Cisco 2801 Router
I cant connect with the router because i forgot the password
Default admin username, cisco. Default admin password, cisco
Jul 28, 2011 | Cisco (1841) Router (cisco1841)
1840 cisco router is not booting only cursor blinking not going ahead
HI,
It May be the problem with the IOS in the router Flash
  • Try hard reboot of the router If it is not soled proceed next.
  • while the router reboot press Pause button continuously, it will enter into the ROMMON mode.
  • using the Xmodem option upload the correct IOS, for refer Please refer the link
  • Please check the configuration Loading by confreg or config-register command and change into confreg 0x2142 to load from the Flash and reboot the router.
Jan 20, 2011 | Cisco (1841) Router (cisco1841)
Hello, I tried the steps you have mentioned in the link below: http://www.fixya.com/support/t3932749-password_recovery_cisco_catalyst_4506 and the other similar resolutions on the cisco website but...
Please make sure you have only one supervisor module installed on your switch or else pull out the backup sup module and do this activity .
In the last step of reset it will ask to save the config.
do you wish to save this configuration? y/n [n]: y
You must reset or power cycle for new configuration to take effect
do not forget to type in y there.
Jan 01, 2011 | Cisco Catalyst 4506-E Cat4500 E-series...
Replacing a PIX 515E with an ASA 5510
Best way to migrate is to take the configuration of the old PIX and TFTP it to a PC or other server for safe keeping.
Then boot up the ASA in a lab environment and TFTP the configuration to the new unit and reboot. There will be some commands that don't translate correctly, but you can compare the configurations to each other to make sure all the access lists and NAT statements get transferred across.
Keep in mind that the PIX and the ASA name their interfaces differently, so there may be errors when you transfer the configuration. You can edit the configuration offline with something like Notepad and change the names of the interfaces to have it work.
Jan 29, 2010 | Cisco ASA 5510 Firewall
Sony vaio v2m will not start up windows
Hello
some of the files are corrupted on your windows installation, To solve this press F10 when your computer as soon as it shows you vaio screen keep on taping F10 and it will boot in recovery parition and then you can reimage your harddrive from there.
Thankyou
Nov 25, 2008 | Sony VAIO VGN-N250N/B Notebook
Boot
turn on pc...immediately press n hold down delete key on keyboard...BIOS opens....navigate to boot configuration menu....select the order of the boot devices as per ur choice...ie...ur memory card as first boot device...save and exit....restart pc with the memory card connected....it'll boot..
Sep 14, 2008 | Video Game Consoles & Games
Cisco 1721 router problem
Does the router boot to rommon mode everytime you turn it on?
There are two reasons why the router could be booting to rommon mode
1. There isn't a valid ios image loaded in flash memory
2. The configuration register is set to a number that ends with '0'
Change the configuration register setting to a number that ends in '2'. (i.e. 0x2402)
You do this with the command: confreg 0x2402 <hit enter key> (in rommon mode)
Reboot the router and it will first search for boot system commands in the startup config, if none found it will boot to the first valid ios image in flash memory.
If there isn't a valid ios image in flash memory, the router will continue to boot to rommon.
Apr 12, 2008 | Computers & Internet
Cisco PIX 515E Firewall Logo
55 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
