Question about HP Officejet 5610 All-In-One InkJet Printer
Paper won't load correctly into fax. when I put the papers in the topload part, it sounds like it catches somewhere and will not insert correctly. The message says "fax failed."
4 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: Printer will not catch paper in tray
The rollers need to be clean or replaced.
Posted on Feb 04, 2008
SOURCE: Paper jammed in printer - need to remove paper tray
1 This works from HP help link in error message:
Turn off the HP All-in-One.
2 Press in the tab on the rear door to release the door. Remove the door by pulling it away from the HP All-in-One. icon_caution_color.gif Caution Trying to clear a paper jam from the front of the HP All-in-One can damage the print mechanism. Always access and clear paper jams through the rear door.
Posted on Jul 29, 2008
acdr
  • 1913 Answers
SOURCE: printer errors
check there is not any paper jam also
Posted on Oct 23, 2008
We have messages in the memory but keep getting message to 'load Paper' there is paper in the machine . I hvae tried putting fresh paper in , but it comes up with the same load paper message?
first thing is you have to insert new A4 sheet in to the rec/paper tray.then press the STOP key.after machine try to feed the paper in to the printer unit and you can get print.( if the machine cant feet the paper,the machine have some paper feeding problem and you have to get technical support to solve this problem)
Mar 07, 2011 | Canon L220 Plain Paper Laser Fax
Our fax machine is sending faxes fine, but will not print in coming faxes. It keeps asking for paper (which is in the fax machine), then it sounds like it's working, then stops. We turned it off to see...
The paper isn't properly loaded. remove the paper then there should be a lever near the paper loading section that you push or pull to let the paper enter the feeding area. put in paper and return the lever to the proper position. check your owners manual. to get a manual try www.sharpusa.com .
Dec 16, 2010 | Sharp UX B700 Plain Paper Inkjet Fax
Faxes are being received as black pages, nothing readable
Long time since I used one of these, and as plain paper faxes are so cheap now I do wonder why you persist with this old technology? You can purchase an all in one printer for under £50. Pick one with a built in LCD screen and you don't even need a PC.
Getting back to your current problem, it sounds as if the paper has been inserted the wrong way around. Try taking the roll out and checking again the correct way to put in the paper. Or maybe the paper roll has been out of its plastic protection for too long causing the paper to degrade. Once it has been exposed to light it is like a film for a camera, it is no good. If this has happened you may try unrolling two or three of the outer layers and cutting them off, and then reload the paper and try again. You may be lucky and find that only the top two layers have been damaged.
Oct 01, 2010 | Sharp UX 300 Plain Paper Thermal transfer...
Sir, can anyone help me with my fax (canon fax l295)for a problem, it was always indicating that "load paper" even though i put paper on the tray once it was start feeding it makes an paper jam error and...
You either have a paper path blockage or your feed rollers are worn. You'll need to take it apart to check though. Try removing paper, turning machine off and on and re-inserting paper. Remember to fan (separate) paper before loading, it could be static causing the sheets to stick together and jam in the machine.
Jun 11, 2009 | Canon L295 Plain Paper Laser Fax
Paper missmatch
Cause The HP all-in-one has a media sensor that checks the type of paper loaded before printing a fax. If the sensor detects that the paper is not plain paper, this message will display. The message may also display when the correct paper is loaded in the all-in-one, but the media sensor cover is displaced, distorted, or covered by debris. For more information and how to resolve this issue click here.
Apr 15, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP fax 1020
try cleaning with alcohol if it doesn't work then yes it needs to be replaced
Aug 12, 2008 | HP 1020 Plain Paper Thermal transfer Fax
Panasonic Fax Phone Can't send or Receive fax
there maybe a small paper jam in the machine that you are missing. if you are handy, unplug the fax machine and look around where the paper is fed into. if you see paper trapped anywhere, try pulling it out with a pair of needle nose pliers. the machine will not work right till the jam is cleared.
hope this helps.
wg
Feb 10, 2008 | Office Equipment & Supplies
Fax does not know paper is loaded. says load paper
When you load your paper, you must press the Stop/Reset button for it to reconize you have loaded paper.
Nov 17, 2007 | Canon FAXPHONE L80 Laser
Loading paper
Hi, I had the same problem...but I fixed it. Here's how: At the very back of the calculater under the paper roller there is a very thin horizontal slot. Insert the tip of the paper roll into the slot, then press the paper advance button located on the top left hand sidw of the calculator until you see the paper. Guide the paper through the top slot and voila.
Mar 28, 2007 | Canon P23-DH Calculator
HP Officejet 5610 All-In-One InkJet Printer Logo
21 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
