Question about Bulova Watch
How to set the date on Breil Liberty watch? - Bulova Watch
How can you get an instruction manual for this Breil Milano BW 0493 watch?
Manufacturers don't usually reinvent the wheel. You may be able to find something from one of these: http://fitness.manualsonline.com/manuals/mfg/briel/briel_watch_product_list.html
Jun 18, 2014 | Breil Milano Bw0493 Milano Chrono Lady...
Where do i send my ducati watch to be fix?
you could try your local Breil stockists most info I can find points to them being possible manufacturers
May 06, 2014 | Ducati Cw0016 Desmo Chrono Watches Outlet
I just got new watch Breil bw0484. How do I activate the watch?
It should start working by pushing the crown all way in.
if not, then your Breil needs a new battery.
www.tictacarea.com
Feb 19, 2014 | Watches
How do i reset the big hand to zero. it is the chronograph
pull crown out to second position then press start button till it gets to zero then push crown back in
Sep 15, 2013 | Briel Breil Mediterraneo Time watch...
Need to purchase a replacement rubber strap for my Breil watch. The strap # is BW0379. Where may I purchase one?
visit http://www.kkhservices.co.uk/ All Breil straps are very expensive ive just found out as i need to replace my rubber strap and was quoted £57 and £150 for a metal bracelet!!!!!
Aug 31, 2011 | Briel Breil Bw0379 Mediterraneo Chrono...
The long second/split time hand resets to 58secs and not 00secs
You have to set the long second by pulling the crown to it's third position(which you can set the time) then push the upper button until you reach 00 then push again to normal position. that's it. i hope i had helped you...
Jul 10, 2011 | Briel Breil Milano Chronograph BW0491...
How to set my breil chronograph BW0036B
have you figured it out?? If so can you help me?
Jun 28, 2011 | Watches
I need to fix the date on my breil tw0287. how can i do this?
mcdevit75 here, If your watch has a stem (winder) simply place your fingernail under the stem and gently lift the stem to it"s first notch (position) now you should be able to turn the stem (winder) to change the date push the stem back in when date is set.
Jun 23, 2010 | Briel Breil Globe BW0213 Watch for Men
Need to reset the time. Side knob will not pull
Is it a pull out or a screw? My Breil 0080 is a screw... when i first got it, i couldn't pull it out either. Try turning it counter clockwise.
Apr 06, 2010 | Watches
Bulova Watch Logo
743 people viewed this question
Top Bulova Watches Experts
Geoff
Jimmy Accardi
Are you a Bulova Watch Expert? Answer questions, earn points and help others
