Question about Sony Cyber-shot DSC-W35 Digital Camera
Flash is not coming and error code is E:91:01
I use w210 Sony Cybershot! I was taking pictures out in the sun, when I saw smoke coming out the camera and the camera become very hot. I also saw that I was using the camera bymistakely in the twilight mode out in the sun. And since then I tried intitializing it but the Error E:91:01 and flash symbol wont stop blinking. And flash Seems to have stopped working. Please help.
  • 300 Answers
Hi!
E:91 is flash error. Could be a dead flash fuse on the main board or bad flash board. Contact your local Sony service center or if they ask too much, feel free to contact me at toms.safranovs@gmail.com
I work in Sony service center.
Tom
Posted on Jul 28, 2009
I have a sony cybershot dsc w55 with error e:91:01. i have pressed the reset button and initialised the camera numerous times. the error is removed but the camera will not take a picture in auto or p mode...
E:91:01 is an error code that indicates problem with flash unit circuit in camera.
Flash unit board will be replaced to resolve this problem and temporary fix is to set flash Off quickly, before error could appear after initializing camera, hope this info will help you.
Thanks.
Oct 18, 2010 | Sony Cyber-shot DSC-W110 Digital Camera
I have a sony cybershot DSC-W210 and just recently the flash wont work when its on any mode to take a picture it has the flash symbol on the screen flashing and the code E:91:01 underneath also flashing...
Perform the following troubleshooting steps to check whether the issue is resolved.
1. Remove the battery from the Camera for 1 minute. Re-insert the battery in the Camera and check if the issue is resolved.
2. If the issue is not resolved, then try initializing the Camera.
The Initialize option is listed in Setup or Settings option in the Camera.
Aug 06, 2010 | Sony Cyber-shot DSC-W70 Digital Camera
i have a sony cybershot DSC-W210 and just recently the flash wont work when its on any mode to take a picture it has the flash symbol on the screen flashing and the code E:91:01 underneath also flashing its takin pictures as normal just without the flash it wont let me change the settings of the flash at all
Jun 14, 2010 | Sony Cyber-shot DSC-W70 Digital Camera
Problems with my Sony Cybershot W210
1) Make sure that you're not using more than 4 GB memory stick pro duo with the camera. Then try to remove the memory stick and capture 2 images in the internal memory and turn OFF and turn ON the Camera and check. If the error message comes, its the issue with the Camera itself and requires service after resetting. to reset the Camera, select Initialize under Main Settings 1 menu under Settings. if the issue persists, the camera may require service
If its working fine, transfer all the images to the Computer and format the memory stick. Formatting will delete all the contents. If the issue persists, memory stick should be replaced.
Sep 21, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
E:91:01 in DSC-W80
I can't recall all the Sony error codes off the top of my head, but I believe E:91 is that your flash is not working.
Can you take pictures at all or do you get just the error code? If you can take a picture with the flash off then your flash needs to be replaced.
If you can't use the camera you need to first press the reset button, then reset all camera settings to default.
1-3. PROCESS AFTER FIXING FLASH ERROR
When "FLASH error" (Self-diagnosis Code E : 91 : 01) occurs, to prevent any abnormal situation caused by high voltage, setting of the flash is changed automatically to disabling charge and flash setting. After fixing, this setting needs to be deactivated. Flash error code can be initialized by the operations on the HOME screen.
Method for Initializing the Flash Error Code
Initialize
Initializes the setting to the default setting. Even if you execute this function, the images stored in the internal memory are retained.
1 Select [Initialize] with v/V/b/B, then press z. The message "Initialize all settings" appears. 2 Select [OK] with v, then press z. The settings are reset to the default setting.
To cancel the resetting
Select [Cancel] in step 2, then press z.
· Make sure that the power is not disconnected during resetting.
Hope this helps.
Thomas D.
Owner, Darntoothysam com
Affordable Digital Camera Repair
Sep 07, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
I use w210 Sony Cybershot! Error E:91:01.
I use w210 Sony Cybershot! I was taking pictures out in the sun, when I saw smoke coming out the camera and the camera become very hot. I also saw that I was using the camera bymistakely in the twilight mode out in the sun. And since then I tried intitializing it but the Error E:91:01 and flash symbol wont stop blinking. And flash Seems to have stopped working. Please help me to solve this problem
Jul 14, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
How to take clear close up pics of jewelry
use close up mode on camera (flower mode). turn off flash and light jewelry with other light source like sun light or other photo lighting (like light box or photo lamps).
Apr 16, 2009 | Sony Cyber-Shot DSC-P200 Digital Camera
Dropped my Cybershot DSC-T200 & now it doesn't work
Hi Emmygrace,
Dropping it can cause a several problems inside the camera from mechanical to electrical. To try and troubleshoot that yourself can be very difficult.
There are certain issues that you can fix by "banging it" but they are a last resort and ONLY if you are ready to trash the camera.
I'm sorry, it's probably not what you want to hear, but you really ought to take it to an authorized repair shop.
Rob
Feb 27, 2009 | Sony Cybershot DSC-T200 Digital Camera
My Sony Cybershot DSC W55 "7.2 mega pixel" does not flash. Error code E:91:01 ?
Please RESET your camera , go to Menu > Initialize > OK
If problem still exist you need to replace flash unit in camera.
Let me know if you need further help.
Jan 28, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Indoor pictures
Dear Kim
Sony Cybershot works on technology of where is checks the srround light, if light is fine (like in Sun or outside) phots are fine. solution to this either replace flash or put some big light on  while taking photos
thanks
Oct 21, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cyber-shot  DSC-W35 Digital Camera Logo
472 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
