Question about Maytag MSD2656G Side by Side Refrigerator
Kenmore Elite Trio not cooling
My Kenmore Elite bottom freezer started making a buzzing sound every three minutes and was no longer cooling. I turned it off for a day or two and removed all the food. It seemed to work for about 5 days when I turned it back on. It is doing this again and all my food is thawing what could be the problem? It is model 75522 and I purchased it in 2/2005.
  • 534 Answers
Sounds to me as if the compressor is overheating and shutting itself down (the buzzing noise) Once a compressor overheats it throws itself into what is called thermal overload. There are several reasons that a compressor will do this. But you said you turned it off and back on and it worked for a while. If this is so then it is possible that your unit could be low on freon or the coils under the base of the fridge has a lot of debris on them. To clean the coils just purchase a coil brush from your local hardware store and using a flashlight to see, brush all of the debris off the coils. make sure to unplug the unit before doing this. If the coils are clean then you need to have the pressures check on your compressor to see if the proper level of freon is there. An appliance tech should be able to check this for you for a minimal cost. Good Luck
Dave
Posted on Jul 17, 2009
Kenmore Elite Trio Fridge Not Cooling
check the over-load/contactor on the side of the compressor,remove it and shake it if it rattles,replace it
Nov 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
1 year old Kenmore Elite Trio Refridgerator not cooling
There are a lot of things that could be the source of the problem... is there no cooling at all going on in the freezer? Is the back wall of the freezer cold? It could be anything from a fan, to the compressor, to the control board... you need a technician.
I would get on the phone with Sears, and explain the continuing problems you have been having, and they may agree to cover service.
Jul 26, 2009 | Kenmore 73503 Stainless Steel Bottom...
Kenmore Elite Trio 596.76529500 It makes a
It is the Freezer Fan, he ice maker fan. I experienced the same conditions of a two year period. The tech allows said either unplug overnight. I as you couldn't take the noise. Oh by the way it will be getting worse!!! The solution replace the Freezer Fan motor.it cost about $78.00 plus shipping. they are located behind the freezer rear wall. They are very labor intensive to replace because the electrical leads are attached just out of reach. I have a 33" arm and I had to act like a contortionist to unplug them.
Jul 24, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer quit working on '04 Kenmore Trio Elite 25' bottom
Can either be starting components for compressor, or Motherboard.
May 04, 2009 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Kenmore Elite bottom freezer making a clickbuzzzzzzclick sound
you need to check to see if you have a control board by compressor.if not change relay and overload to compressor if you have a grey box with a board in it then you need to most likely change it
Mar 14, 2009 | Refrigerators
INTERMINENT BUZZING NOT COOLING
from your description it sounds as if the compressor is not starting up. the buzzing noise usually occurs approx. ever 3-5 minutes and is followed by a click. this indicates either a bad start relay or a stuck compressor. and from the model you listed it is most likely the compressor. if the unit is under 5 yrs old it should still be in warranty thru sears.
Thanks for using FixYa Peyton
Feb 18, 2009 | Kenmore 71812 / 71814 / 71819 Bottom...
Kenmore Elite Trio Frige...Beeping three times in a row suddenly
this unit has a history of the light circuit failing and it will cause the lights to either stay on or off. if they stay on, it will melt the housing around the upper bulb area. it has a recall and should be covered by sears for no charge. it is the control board failure and has a sticking relay for the light circuit, needs board replaced.
the 3 beeps are the unit thinking it has a door open. turn off the alarm on the door control board and call sears 800 # for repair.
Dec 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Elite trio
Hello bigmikeegator
Welcome!
You said, you have the Kenmore Elite Trio Bottom Freezer. You moved your refrigerator to a new home and removed the bottom freezer door, but can not seem to figure out exactly how to put it back on correctly.
It's too much for me to tell you myself.
This is easier!
Page 9 shows you how to remove and reinstall doors.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0523115.pdf
Thank you,
Huuum,
Please remember to leave a rating!
Oct 06, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Maytag MSD2656G Side by Side Refrigerator Logo
224 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
