Hello rbryan492:
From your Description it Sounds like a Blown Head Gasket between the Push Tube Galley and the Cylinder, the Valve Clearance Requires Setting or the Flywheel Key is Damaged and Requires Replacing.
>>If you Require More Assistance, then
>>Send me the Model and Type or Spec Numbers Off the Unit, Please. With these I can Locate the Proper Manual and Better Assist you. The Model Numbers May be Stamped Into the Blower Housing (metal engine cover) Above the Spark Plug. Many horizontal shaft, overhead valve engines have these numbers stamped into the OHV rocker cover. However, on certain overhead valve powered generators, the equipment manufacturer installs a decorative chrome rocker cover OVER the Briggs cover. If your engine has a decorative cover, it may be necessary to remove it in order to locate the Model, Type, and Code. If this is a Briggs and Stratton Engine, then you can Also Use this Site Addy;
http://www.briggsandstratton.com/maint_repair/BS_modeltypecode.pdf for Assistance in Locating the Model, Type and Code Numbers of the Engine.
Thanks.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
