Question about Apple PowerBook G4 Mac Notebook
When i boot it up it makes a type of spinning sound in the computer then a screen pops up and shows a question mark flashing
  • Apple Master
  • 2,404 Answers
Sounds like the hard drive may be bad. Kind of like the heads are banging together, try a different hard drive in there and reset the laptop back to factory defaults. If you have the disks, i'll walk you thru it.
Posted on Jul 17, 2009
What does flashing globe on white screen on mac meanmacbook pro
If by flashing globe you mean spinning globe (often a colored beach ball), there are several possible reasons. The spinning beach ball happens when a operating system command cannot be completed. The computer is frozen/stuck in a process that it can't complete.
Most often the cause is faulty or missing information on the hard drive. Running Disk Utility will often fix it. You may need to start the computer from your OS install disk and rather than install find Disk Utility in the pull down menu and run it on your hard drive.
The spinning ball could also be caused by insufficient RAM memory to even run the operating system. It could also be caused by hardware problems which can be diagnosed with the Apple Hardware Test found on the disks sold with the machine.
If you truly mean a flashing round globe, I have never seen such a figure. Flashing question marks or flashing circle with a slash through it means the mac cannot find a bootable hard drive. Your hard drive may have died or become corrupted. To see if you hard drive is defective, again run Disk Utility by booting off an install CD or another hard drive with a compatible MacOSX operating system to diagnose.
Try running the repair disk program under the general tab of the Disk Utility program.
Aug 11, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Tip
Password at boot up (when starting) Windows 10
Windows 10's native installation makes you sign in while the computer is booting up. This is a waste of time. In order to stop the requested sign in, press the and the key at the same time. You will see the run window pop up in the lower left corner of your screen. Type . Another little screen will appear. In the upper right half of the screen there is a check box that says "Users must enter a user name and password to use this computer." Click on that box to remove the check mark. Click OK or Apply on the bottom, and reboot. It should not ask you for it again.
on Jul 28, 2016 | Microsoft Windows Vista Ultimate Edition
Computer won't boot up
Does it sound like the computer booted up except the screen is black. Do you hear fans running, the hard drive spinning? Maybe the system booted up, but the screen has an issue.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
May 15, 2012 | Computers & Internet
Blank screen
Did it boot all the way? Do you hear the fan running, disk drive spinning? If it sounds like it booted but the display is black, try this:
When you press the power button do you hear fansrunning, hard drive spinning, lights on the computer, hear any beeps or lightsconstantly blinking, hear the DvD/CD drive click and the light on the drawer ofthe DvD/CD turn on for a second or two? If so the laptop is trying toboot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Apr 14, 2012 | Computers & Internet
Flashing green lightbulb
Do you hear the fans running? Do you hear the hard drive spinning? Did anything ever appear on the monitor?
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 09, 2012 | Acer Veriton Computers & Internet
After the start up bar finishes, it will go to a black screen with a flashing underscore in the top left hand corner, kind of like a DOS screen but I cant type anything. And after I push about 13 keys then...
sounds like your operating system is corrupted...try turning on the computer and after the initial startup screen shows(the one with the make or manufacturer) press the F8 key...this will give you a list of options...scroll down through the options(or up) till you get to the one that says "safe mode". Highlight this and press ENTER. You may or may not have another screen pop up that asks which operating system to use.(not on all machines). when you get to safe mode you can try to change whatever you did to make it stop working..sometimes the computer will stop loading the operating system if you add hardware or software...safe mode allows you to uninstall these so you can boot up your system
Dec 18, 2010 | Computers & Internet
Booting from a USB Stick
Here you go:
Download the Ubuntu Live ISO (if you dont have it already) and burn it to CD
Restart your computer (booting from the Ubuntu Live CD)
Insert a 1GB or larger USB flash drive
Open a terminal window and type sudo su
Now type fdisk -l to list available drives/partitions (note which device is your flash drive Example: /dev/sdb). Throughout this tutorial, replace all instances of x with your flash drive letter. For example, if your flash drive is sdb, replace x with b.
Type umount /dev/sdx1
Type fdisk /dev/sdx
type p to show the existing partition and d to delete it
type p again to show any remaining partitions (if partitions exist, repeat the previous step)
type n to make a new partition
type p for primary partition
type 1 to make this the first partition
hit enter to use the default 1st cylinder
type +750M to set the partition size
type a to make this partition active
type 1 to select partition 1
type t to change the partition filesystem
type 6 to select the fat16 file system
type n to make another new partition
type 2 to make this the second partition
hit enter to use the default cylinder
hit enter again to use the default last cylinder
type w to write the new partition table
Type umount /dev/sdx1 to unmount the partition
Type mkfs.vfat -F 16 -n usb /dev/sdx1 to format the first partition
"Alternately you can try mkfs.vfat -F 32 -n usb /dev/sdx1 (doesn't always work)"
Type umount /dev/sdx2 to ensure the partition is unmounted
Type mkfs.ext2 -b 4096 -L casper-rw /dev/sdx2 to format the second partition
Remove and Re-insert your flash drive
Back at the terminal, type sudo apt-get install syslinux mtools
Type syslinux -sf /dev/sdx1
Restart your computer, remove the CD and boot back into Windows
Using Windows to prepare and move the files to the USB Stick:
Create a folder named USB on your computer
Download UBconvert.zip using this link - http://www.pendrivelinux.com/downloads/UBconvert.zip
Now, extract the files to the USB folder
Move the Ubuntu  ISO downloaded earlier to the USB folder
Click fixu.bat from the USB folder (follow on screen instructions)
Move all files from the ubuntu directory to your memory stick
Reboot your computer and set your system BIOS to boot from USB-HDD or USB-ZIP. Also set the "Hard Disk Boot Priority" if necessary.
You should now be booting into Ubuntu Linux from your USB drive!
Dec 28, 2008 | Toshiba Satellite R15-829 Tablet PC
Monitor flashes on and off!
Sounds like you have a bad connection from your monitor to your computer. First check and make sure the connection between them is tight. Does your computer boot up and run though? If your computer is not booting up the monitor will default back to the flashing green power light
Nov 29, 2007 | Dell E173FP 17" LCD Monitor
TECRA 740CDT
Try taking the battery out and use only the AC. If everything turned out fine, it could be a problem on the battery or on the port.
Oct 07, 2007 | Toshiba Tecra 740CDT Notebook
Tmobile mda device
Ask the manufacturer or service provider for another software CD to use on your set. Make sure to have your device available for any codes they might need off of it for security purposes... It sounds like it might be either a computer issues, or a software issue...
Sep 17, 2007 | Kodak EasyShare C330 Digital Camera
Apple PowerBook G4 Mac Notebook Logo
152 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
