Question about HP Pavilion ze4300 Notebook
My laptop makes a horrible whirring noise and locks up and whirrs and clicks when I try to log on.
GE pdw9980lss dishwasher makes a horrible squealing noise when not in use.
The dishwasher control panel must be defective, nothing else would cause this.
Apr 04, 2017 | GE 24 in. PDW9980LSS Stainless Steel...
I have a Hp Pavillion a6650F. Recently the top fan in the back sometimes whirres. Is there anyway I can adjust it or lube it> Or what should I do to fix this?
There are multiple things that can cause this, I'll briefly describe them and solutions.
  • It could be having issues spinning, causing a forced spinning whirring sound. This is most often caused by dust and can be fixed by buying some compressed air computer duster.
  • It could be overheating, many laptops have this issue. When a computer heats up, the BIOS tells the computer to increase fan power, causing a more noticeable fan whirr. This can be changed in BIOS settings, but I do not suggest it, or you can buy an under the laptop fan to help cool down the laptop.
  • It could be breaking, in which case buy an under the laptop fan to prolong your laptops life, however if this is the case your laptop may only have a year or two left and I suggest you start making regular backups of important files.
Jul 17, 2011 | Computers & Internet
Seagate Momentus 500GB hard drive on a Dell Latitude laptop running Windows XP with an Excel spreadsheet open. I went away for about 20 minutes, came back and unlocked the user and then blue screen with...
This is a typical hard drive failure scenario, please check if your computer has valid contract if so get your hard drive replaced.
If you have valuable data in your hard drive and willing to spend you can go for hard driver data recovery which is an expensive process.
Jan 04, 2011 | Seagate Momentus 5400.3 Hard Drive
My laptop (sony vaio VGN-CS325J) fan makes a horrible noise
Hi kufreudokang,
The VGN-CS1xx, VGN-CS2xx, VGN-CS3xx computer models have a known issue that the cooling fan in the Computer may make continuous scraping, whirring, chriping and/or clicking noise while running. As a part of Sony's commitment to quality, Sony provides a free repair for an additional 36 months beyond the standard limited 12 month warranty (48 months total) for fan replacement.
As you're experiencing the issue, you can contact Sony Support at 1-888-476-6972 to set up a repair service at our Sony repair facility.
Hope this helps.
Please post back if you require further assistance.
Thanks for using FixYa.
Oct 11, 2010 | Sony VAIO VGN-SZ330P/B Notebook
My Dell laptop's disk drive makes a horrible noise
there is an issue in ur mouse pad/key pad...some keys are short or some keys are locked...
with respect to ur CD drive...it issue happens with the use and life of the laptop...
consult a service engineer....
or use a external USB drive...
Dec 14, 2009 | Dell Inspiron 1525 Notebook
I have spark but the engine dont turn on
If you can hear the fuel pump run when you turn your key to the on position. Then your fuel pump is alright. it makes a whirring noise for a couple of seconds. If not , then it is the fuel pump or the relay. But if it whirrs , it is not the fuel pump or relay but something else.
Apr 08, 2009 | 1994 Volkswagen Jetta
My subvoofer burs
Induced noise - running signal wire too close to electrical cables.
Faulty/damaged Input reciever (jack) on subwoofer - test by isolating PC, and attaching iPod or other device to check for noise instead.
If the noise is not present when using the isolated source, your sound card output jack is bad, or the soundcard itself.
Thank you for using FixYa - A FixYa rating is appreciated!
Jan 26, 2009 | Altec Lansing ATP 3W Computer Speakers
Whirrring?
It's normal for whirring to occur when it is first turned on and whne yuo are starting up the system
Dec 15, 2007 | Microsoft Xbox 360 Console
Printer makes extremely loud clicking noise
http://printer.konicaminolta.com/support/current_printers/mc2430dl_sup.htm#Printer_Specific_Documentation The user guide should be helpful to you to pinpoint what is causing the noise. Sounds like the belt drive or gears may be having a problem. Let me know what happens. Tim
Mar 06, 2007 | Konica Minolta magicolor 2430 DL Laser...
HP Pavilion ze4300 Notebook Logo
144 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
