Since it is a vintage machine, be sure to clean and oil it regularly or the parts will begin to seize. Use ONLY good quality sewing machine oil and apply 1-2 drops every oil port or every place that metal rubs on metal (turn the handwheel and watch as it moves). Do not oil plastic, rubber, or leather parts. Applying heat from a handheld hairdryer will help loosen things.
It sounds like you have a broken drive gear. Most of the gears in a sewing machine are no longer made of metal, they made of hard plastic. They WILL break after time due to the stress put on them when sewing thicker material. If you have a very expensive machine, you might want to have it repaired. If your machine is on the cheaper side, you might want to look around for a replacement. Sources like EBay and Craigslist are a good place to start looking. Local yard sales are also often helpful.
Testimonial: "thank you. i figured it out. my machine is a vintage one. still learning what to do with it."
