Question about Premier 500800 1 3/4" Blue Hot Water Recirculating Pump with Timer 0955800
HOW MUCH POWER
DOES THE PUMP USE WHEN RUNNING. 500800 WATT RECIRC PUMP?
  • 308 Answers
This circ pump draws .22 amps, and uses 25 watts and hour
(.025 kW/h)
Posted on Jul 20, 2009
Onao generator fuel pump loses power
Is it losing Battery power, or just not pumping? check connections, and pins on board connector. Failing that replace the board, if Battery voltage is been lost
Jul 26, 2014 | Onan CUMMINS 5.5 HGJAB-6755 - Cummins...
If i was to change headlight globes from 55 watt low/65 watt high to xenon halogen 90 watt low/100 watt high is there any problems
Most OE factory wiring is marginal as far as amperage carrying capability goes. They installed wiring fine for the stock bulbs and switch. A lot of vehicles send power to the lights..head and running...through the light switch on the dash. This causes it's own problems as switches are the weak link in the lighting system.
If you run 100watt bulbs you will need to power the bulbs via a 40 amp relay switched by the light switch so the switch does not carry the amperage load through it's contacts.
Doing so will reduce the voltage drop to the bulbs as a 2 volt drop will cause the bulbs to be only 75% as bright as they would be with the full 13.5 volt running voltage..
You run a fused wire from the battery or power distribution block to the relay that should be mounted within 6 inches of the closest h/l bulb. Then from the relay to the head light bulb/s. The front and rear running lamps can remain as factory as they are low amperage draw and original light switch will work because you now no longer run power to the h/lamps through the switch.
Search the www for schematics for relay switched lamps.
Mar 12, 2014 | Cars & Trucks
1&1/2" recirc.pump ...
If there is power to it the entire time, then it is probably overheating
Dec 07, 2013 | Laing Thermotech Laing E1 ecocirc...
Machine stopped, no light on panel with power on, wont start
This sounds like it is an intuitive ECO model? Make sure the pump is correctly plugged in as it is a vital part of the electrical circuit and the machine will not power on otherwise. it's quite easy to disturb the wires when working with the recirc valve.
Mar 05, 2012 | Fisher and Paykel Washing Machines
I have a kenmore oasis # 110.27087603 the machine stopped working. i emptied the water and it begun working until it stopped at 21mins into the wash cycle. i emptied the machine and it did the same thing....
most likely a drain pump issue or the main board is not telling the pump to run. board is pricey for a test but the pump could be stopped. if you do not hear the drain pump running, try replacing it, if the pump hums but no water moves, you need to check intake . pump is underneath washer on the right. the left is a recirc pump and is not interchangable.
Jan 03, 2012 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
I have a Homelite recirc pump AP-125. Motor runs
usual if the pump is dry you need to try bleed get some water to the pump. either pouring some in the lift pipe some pumps have a bleed screw to pour into to get it pumping. if it still wont could be the fins in the pump that are not working proper
Sep 26, 2009 | Homelite Garden
Guardian rv generator
Your control board is faulty. Try to power up the ingnition coil as well as your fuel pump. If this does not get the engine running then you have major engine problems.
May 18, 2009 | Guardian Rv Generator 4800 Watt, Gasoline,...
Not recirculating
"0d" refers to an "open door" problem. Need to chceck the lid switch to insure it is functioning properly.
Dec 30, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Change recirc pump
Yes, this is quite a hard job as the metal upper casing of the machine has to be removed from the plastic lower casing to gain acces to the pump.
Oct 23, 2007 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Premier 500800 1 3/4" Blue Hot Water Recirculating Pump with Timer 0955800 Logo
63 people viewed this question
Top Premier Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Premier Garden Expert? Answer questions, earn points and help others
