Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
The water during the cycle does not heat up. Has the heating element gone? Regards Zika
  • 534 Answers
There is a way to test the elementy to see i f the element is indeed burnt out. You will need to get a continuity tester. First shut off all power to unit. Once you have shut off the power, remove wiring from both posts of the element. (remember to mark the wires as to replace them correctly when finished) once you have removed the wiring take your tester and touch one probe to one post the other probe to the other post. If you get a signal from the tester your element isn't burnt out and your problem lies elsewhere. Good Luck
Dave
Posted on Jul 17, 2009
Kitchenaid KUDS02FRSS0 dishwasher. Stops mid-cycle, sometimes wash, sometimes rinse, sometimes dry. Must restart 4-5-6 times to get it to finish. When finally done dishes are clean, hot & dry....
Hi Dennis.
If the dishwasher is hanging on in the middle of the cycle it is usually the heating system. If the temperature of the water is going up after filling, then the element may be working. The element is tested using a multi meter set on Ohms to read impedance across the heater element contacts. If impedance is infinity (open-off limit), then the element is gone. If the element is OK, then the bi-metal thermostat or the fuse must be replaced. The heating assembly is located at the base of the appliance, behind the kick panel.
Behind the kick panel you should also find the tech sheet illustrating how to run the diagnostic cycle for this model. Run a diagnostic cycle to confirm that the problem is with the heating system. Drain, water sensor and inlet problems sometimes may also result in cycle not finishing.
You can find parts and diagrams for your dishwasher in this page.
Regards.
Ginko
Dec 08, 2011 | Dishwashers
Get error message F5 about 3 minutes into the cycle, have to reset multiple times to override
F-5 Water temp sensor failure
If during the water heating step in the wash cycle, the water
temperature sensor (NTC) value is out of range, the "F/05" error code
will be displayed. Possible cause/procedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Refer to the
"Water Temperature Sensor" section. Check
connections to the water temperature sensor.
3. Check resistance of heating element, if present on this
model. (abnormal = infinity)
I have a service manual and some repair photos HERE
Feb 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F-05 error
F05:
Water Temperature Sensor Error
If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed.
Potential Causes
Check the Water Temperature Sensor, Heating Element and Element Relay • Check connections to the Sensor, Heating Element and Relay
Feb 05, 2011 | Washing Machines
AEG Lavamat 76400 during spin cycle blows a fuse
its not the heat element its the water pump i would say it has gone to ground try disconnecting the water pump if the fuse does not trip then replace the water pump
Jul 03, 2010 | Washing Machines
Heated dry cycle does not work.
IS ELEMENT HOT DURING DRY CYCLE, DROP SOME WATER ON IT. CHECK FOR VOLTAGE TO ELEMENT DURING DRY CYCLE, IF VOLTAGE AND ELEMENT DOESN'T HEAT THEN IT IS OPEN/DEFECTIVE. IN THE CONTROLS OTHERWISE.
Mar 10, 2010 | Whirlpool Dishwashers
I have a Kenmore elite he3t washer. It flashes f5 at the beginning of a cycle
F/05 Water Temperature Sensor Error
If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed.
  • Check the Water Temperature Sensor, Heating Element and Element Relay
Feb 04, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
F-05 flashing on the display screen
Hi There
I have this for to read and hope this helps out. Let me know how this works out.
Thank you for writing to fix ya.
Best Regards Richard
Dec 28, 2009 | Washing Machines
What's wrong when on display I've got f05
hi there
Here's what you looking for.
Hope this helps. TY for writing to fix ya.
Best regards Richard
Dec 10, 2009 | Washing Machines
What does a thermometer symbol with up arrow mean on an shx68
Hello Jsg5,
That symbol means that the dishwasher is heating the water, bringing it up to the required temperature to properly sanitize your dishes.
This symbol can appear during the wash and rinse cycles. It is nothing to worry about. Most dishwasher will heat up the wash and rinse water, it's just that Bosch decided to add an indicator, so users would know that any delay in the wash/rinse cycle, is a result of getting the water up to the proper temperature (typically around 140 degrees F)
Even if you've got your hot water heater or hot water supply set to a very low temperature, the dishwasher will use the built-in heating element (the drying element in the bottom of the dishwasher) to heat the water.
Hope you find this Very Helpful and best regards!
Dec 10, 2009 | Bosch Integra 800 SHX68M0xUC Dishwasher
Water level below heating element and element does not appear to heat
Make sure the drain hose high loop is installed properly, normally you have this in the sink cabinet high up. Otherwise the water inside the machine may drain "by itself", leaking through the inactive drain pump during the wash cycle and cause this and other troubles.
May 24, 2009 | Kenmore Dishwashers
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
133 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
