Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
Won't do anything
My stcked machine fill up with water but then won't do anything. I have moved the dial all around the setting and it will not click or activcate anything. DO i need a new dial control?
  • 213 Answers
No, you need a lid switch. when the switch fails it wont do anything but fill. replace switch to fix problem
Posted on Nov 20, 2007
Why would my Amana washer not do anything but fill up with water. Nothing will function at all on all the cycles but the fill. It doesn't even click on the timer when you try to set to any setting exc
Hi Kirby
First... Caution
Because your dealing with water & electricity it can be lethal to fiddle around inside. That said...
Washing machines are controlled by a master timer unit, usually mechanical, but rotated by an AC Clock motor. If the timer is not getting voltages to the various Switches around the "timer unit" or "clock motor" then the individual selected functions won't work.
Manually Rotating to a particular function then Activating the On/Off Push/Pull switch should start things happening even if timer motor is dead. So
If your OK with AC electrical goods then open it up.
Connection wires may have fallen off or something simple. A multimeter is your best friend here. Look for the big rotary clock behind the main control dial. Listen for the clock motor running. The main Push in & out Button is the On / Off switch. Check that its got AC on the input wire & switches across to the other wire when the knob is pushed in / out. This may be the problem...
You can always call an appliance repair technician!
Good Luck
Nov 19, 2014 | Amana 3.2 cu. ft. Top-Load Washer
The problem is that the dial goes around for the setting required and water fills up, but the agitator doesn't move.
Can you provide a complete model number? If this is a top loader check the lid switch. You should hear a click just after opening and a click just before it's closed.
Jan 07, 2013 | Washing Machines
Water won't quit filling and agitator does not engage into the cycle.
Did you solve this problem -have one doing the same-feed back -please!
Mar 22, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I was going to wash a load of towels and the washer filled up but I realized it wasn't enough water in it so before I could set the dial for more water, it stopped filling up so I set the dial for more...
Look around at outlets that are close by and make sure you didn't trip one of your GFCI breakers or plug in something to the same outlet and make sure you have power at the outlet where the washer is plugged into.
May 30, 2017 | Maytag Legacy Series Top Load Washer
Have a Maytag washer LAT9635AAE. It fills with water and does not proceed. The timer seems to move the dial around but doesn't engage the washing functions. At first I thought it was simply not...
Remove the timer and get the outer skin off of it. Twist the timer around and hunt for burn marks on the barrel. I suspect it is the timer. To get it off you pop the cap on the knob and under it is a keeper and spring you remove. Then the knob and skirt will come off and you can get to the screws which hold the timer to the consolethemobilian_29.png
If the timer turns out to be ok then the motor is suspect.
Note: This washer is well worth repairing. Anything out there on the market now is trash compared to this machine. Invest in repairing it. You will be glad you did.
May 18, 2011 | Maytag Washing Machines
My washing machine Whirlpool AWM049 has just developed a fault. Whatever program it is set to the dial turns, then when the dial reaches the position where it is supposed to fill with water it just stops....
I have the same problem. The dial does not start on the setting you set it to. It just clicks around then stops. I called out an engineer who said he thinks it is the control panel panel board. Didn't know if he could get the part which would be expensive. I was hoping someone would have the answer.
Nov 23, 2010 | Whirlpool Washing Machines
Candy cs455m programe stops at about 3oclock on the dial
Yes heatr should be submerged in the water. Not expose to free air.Check the water level float switch or the pressure switch.
The replace timer should be identical in design. If there is a mismatch it will not function as designed.
If it is elctronic micro controller type the same part no and soft ware version should be used.
May 25, 2010 | Candy 17 in. CS455 Built-in Dishwasher
Washer fills but won t advance to the next setting for all cycle
Do you hear the ticking of the dial moving? if so it could be that the points aren't getting connection to cycle it threw the various cycles
Nov 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
295 people viewed this question
Dan Webster
Dan Webster
Sal De
