I expect you have an extra tray fitted. This error refers to this option. Turn the power off and lift the printer off the second tray .Now turn it back on and it should print ok. If so then throw away the optional 2nd tray as it has gone faulty.
Service Call
181: Error
182: Error
183: Error
184: Error
185: Error
Option unit I/F error
(181 = Duplex Unit.
182, 183, 184, 185 = Optional Tray)
Does this error recur?
Yes
Restore the power.
Check to make sure the contact points of the connector and replace the optional unit
On startup, if the machine shows a wrench-icon, press down "8" and "clear/stop" key simultaneously to show the exact error-codes. A list of detailed error-codes can be found here: http://officeimagingsystems.com/id175.html
Songs und Bilder auf CD brennen nicht mehr mã¶glich. Fehlerbeschreibung: Keine Verbindung zu Windows IMAP 12 CD Engine mã¶glich.
Above Question in English: Songs and pictures onto a CD no longer mã ¶ possible. Error Description: Unable to connect to Windows 12 CD IMAP Engine mã ¶ possible. Answer: Your quesion is not clear and full. I think: you have problem when burning cd with Media Player 12. Go to services in Control Panel > Administrative Tools or type and press enter services.msc at command prompt. Enable the following service to Automatic mode and press start button: IMAPI CD-Burning COM Service Now log off / restart. See the problem solved or not ? If the problem is not solved then - fully describe your issue here. Thanks for using Fixya. bcdalai
