Question about Dishwashers
Newly installed dishwasher integra modwl shx98m09uc water does not drain
    President:
  • 1,136 Answers
Hi, If this is hooked up to a garbadge disposal, make sure the plug inside the disposal fitting is removed. You will need to use a something to punch out the plug.
Is this a possiblity or can I assist you further?
Thanks
Vic
Posted on Jul 17, 2009
Bosch dishwasher does not drain water and does not run
Bosch,. like many others have a "safe: cycle where the machine will always do a short pump out before it starts any cycle. If it fails to do a pump out even if there is no water in the machine, the machine will go into safety mode and will not allow a program to start. You will have to pull the machine out and check if the drain hose is blocked or kinked, and that the drain pump is not blocked or jammed. Toothpicks, bits of food and broken glass fragments are good for blocking / jamming dishwasher pumps.
Mar 09, 2015 | Bosch Integra 300 Series SHX33A05UC
My newly installed dishwasher won't drain, what could be the cause?
If the dishwasher is connected to a spigot on the waste under the sink, check that the end has been cut off the spigot (on the plumbing not the machine hose) or that end stoppers have been removed. Also, check the hose has not been crushed when installed.
Mar 04, 2013 | Bosch SHE3AR52UC Builtin Dishwasher
The dishwasher makes a noise only during the drain cycle.
If the valve opening sound & pump sound ignore it. If the sound was not there earlier and it is newly heard now check the drain water pump.
May 21, 2010 | Maytag MDB9600A Jetclean II Built-in...
Dishwasher will not drain
check the water pump this could be blocked
Apr 20, 2010 | Bosch Integra® 500 SHX46L Built-in...
I have a whirlpool gold model GU1500 diswasher. When the rinse cycle ends the water pumps out into the garbage disposal like it should, but then water backs-up from somewhere into the bottom of the...
Seems you answered your own question here. You need to make an air gap in the drain hose - take as much slack as possible and make a curve (upside down U) under you sink as high as you can go. Make sure you clip ot to back of the cabinet to stabilize it. Good luck
Jan 11, 2010 | Whirlpool 24 in. GU1500XTLS Stainless...
The motor turns on but no water is entering the dishwasher to start the wash cycle.
Hello there
Here is the most common troubleshooting tips
Dishwasher does not fill with water or it drains while filling
  • Check that the water supply is turned on. The valve may be located under the sink.
  • Check the door latch
  • Test the door switch
  • Inspect the float assembly
  • Inspect the fill tube for kinks
  • Test the float switch
  • Check the inlet valve filter screens
  • Test the water inlet valve
  • Test the drain valve lever arm
  • Check the drain valve
  • Please check each one of these out carefully ok
  • Hope this is very helpful for you
  • Best regards michael
Jan 10, 2010 | Bosch Integra 300 Series SHX43C0xUC...
DOES NOT DRAIN
HI. check the following areas for fualts.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Jul 15, 2009 | Bosch Integra® 500 SHX46L Built-in...
Bosch Integra 500 dishwasher turns on and starts wash cycle, turns off after 90 seconds and then there is no power on the button panel at all. The dishwasher is full of water. Now the unit will not turn on...
your controlboard is no good. find out if its a recall unit go to thermador.com which is the company that owns bosch and they can tell you the price if you have to oreder it or if its free for part and you pay labor to install
May 10, 2009 | Bosch Integra® 500 SHX46A0 Dishwasher
I have a newly installed Kitchenaide dishwasher. The copper pipe is secure under the sink and appears connected properly to the dishwasher. When I turn the shut off valve on, water begans to run from...
You should be able to remove the panel below the door and see where water inlet hose is connected to the solenoid valve. I'd bet that's where it's leaking since you say it's newly installed.
May 13, 2008 | Dishwashers
Dishwasher, whirlpool generation 2000+
not enough info. new house? newly purchased house? new dishwasher? newly installed?
check to see if water line was connected
see if a valve has been inserted in water line and is open
if fools day joke, thanks for my time.
Apr 01, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
43 people viewed this question
Top Dishwashers Experts
