Question about Apple iPod MA446LL/A MP3 Player
Do Not Disconnect is displayed
While trying to connect to my PC, I get "Do Not Disconnect"
  • 126 Answers
This is not a problem. The ipod is either syncing or backing its settings.
Once the activity is completed you can disconnect the device. On 1st Gen ipod, this 'do no disconnect' continues to appear even when the device is not syncing. However, it can be disconnected without problems. Click on the 'Eject' logo next to the ipod symbol in your itunes application window. Your device will now disconnect.
alternately you can also disconnect by removing the cable directly however please make sure that there is no activity taking place on your device. iTunes display window at the top of the application windows should be blank/clear.
Posted on Jul 17, 2009
Display ic motherboard
A> Check you Power all connection proper connected.
B> Check you SMPS power proper working or not.
C> If direct display not coming then sec option is external display card connect in mother board and check display come or not. if display come then you internal display cheap damage. If both option used or display no then you mother board problem.
D> Check you RAM, section if RAM problem then display no.
E> And finally one time mother board bios batter disconnect and few sec wait and re-connect bios batter. Remember batter disconnect before all power cut.
Thanks...
Aug 26, 2013 | Dell OptiPlex Computers & Internet
Tip
Here is how to connect your Windows 7 installed notebook to an external display
Most of the notebooks that were manufactured in the past two-three years come with a HDMI port along with the old VGA port to connect your computer to an external display. Connecting and activating an external display on a Windows 7 machine is pretty simple.
Here is how to connect your Windows 7 installed notebook to an external display:
1. Connect your Windows 7 laptop to the external display using VGA or HDMI cable.
2. Then, switch on your Windows 7 laptop and also the external display.
3. Once Windows 7 is up and running, type Mobility Center in Start menu search area and hit enter to open the same.
4. If you have connected your Windows 7 machine to the external display properly, you should now see Display connected text under External display section of Windows Mobility Center. To use the connected external display, click Connect Display button. You should now see your Windows 7 desktop in the external display as well.
5. Use disconnect button in the Windows Mobility Center to disconnect the external display. When the display is connected and active, use Windows + P keys to quickly switch between these displays
on Jun 18, 2010 | Computers & Internet
Tip
How to connect Laptop to an External Monitor?
5. Use disconnect button in the Windows Mobility Center to disconnect the external display. When the display is connected and active, use Windows + P keys to quickly switch between these displays.
on Jun 14, 2010 | Computers & Internet
N7o display fails with full charge during monsoon
disconnect the adapate +battery HOLD the power button by 30 secons aprox, by eliminated ESD. connect again the adpater and battery. and see what happen.
if the problem persist only connect the adpater, and see if the display is working. if is working try putting the battery , if failed the battery is faulty.
However if the computer doesnot turn on the display with only the adapter the ribbon cable display+gum conducter is failed, repair.
God bless you
Jun 23, 2013 | Computers & Internet
disconnect the adapter +battery, restart HOLD the power button by 30seconds, in order to eliminate the ESD.
try again connect the adapter+battery and see what happen. if worked is fine.
if doesnot connect only the adpater and try again, and see what happen. if work, connect the battery, if failed with the battery , is faulty.
Howver if the problem persist with the adpater only, the ribbon cable+gum conductor is faulty for display, repair.
God bless you
My computer will not start, when I turn the computer on it has a blank screen. How can I fix my computer?
try to go BIOS AND CHECK THE DISPLAY,IF THE DISPLAY IS OK THEN TRY BELOW
1.check the power connection of the computer
2.check the power connection for monitor or any loose connection.
still nothing is coming do the next.
turnoff the computer completely,disconnect the powercabel,disconnect all the external devices press and hold down the power switch on the tower for 30 seconds,reconnect the power restart the computer.
Sep 16, 2010 | Computers & Internet
When i power on than the PC itsef power off and don"t display the screen.
try with & with out battery. if you face same problem then replace the RAM. Thanks.
Mar 23, 2010 | Compaq NC8000 Notebook
80GB frozen with "Do not disconnect" displayed on screen.
you have to send to apple eng. or els call me i can help u sir 9177110844
Sep 15, 2009 | Apple iPod MA446LL/A MP3 Player
Speakers killed my moniter
Well as you have already tried disconnecting the peripherals from your computer, and tried restarting the computer too which did not help you, it sounds to be an hardware issue with the monitor. However if incase you have not tried this, you can disconnect the monitor completely from the tower, power on the monitor, if it powers on and you get a message as no signal, your monitor is working good. If not replace the monitor. If the message appears on the monitor screen, disconnect everything from the tower, push and hold the power button on the tower for a minute. Connect just the monitor and check for any display. If you do get display, thats good, connect one device at a time and check to see if the display appears.
If theres no display with just the monitor connected, the issue would be with the graphics card. You may need to replace it or get the system repaired.
May 27, 2008 | Dell Dimension 2400 PC Desktop
Apple iPod MA446LL/A MP3 Player Logo
160 people viewed this question
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
