Question about Motorola Mobility SLVR L7 Cellular Phone
Damaged by the charger. my brother said that my cellphone was burnt by the charger. it was true. now i can't use it.
  • 3 Answers
Gget a new phone
Posted on Jul 18, 2009
91 dodge ram charger wires on drivers side burnt were do i start car shut down
fusible links are short bits of fuse and can be easily replaced
it should have burnt before the harness was damaged
they are available at the spares section
Oct 22, 2015 | Dodge Cars & Trucks
Do not answer cellphone while charging
Salam..
yes it is true.
Do not answer cell phone while charging because of its waves might damage you.
Apr 26, 2014 | Computers & Internet
Charging hiting
what model of cellphone you have... and what heated up is it the charger or the cellphone.. we have two problem either the cellphone or the charger.. but i will tell you to look for another charger where we can check your cellphone. A charger must stop charging when the battery reaches its peak of charge... if the charger doesn't stop charging even the battery is charged then it will cause over heating to the charger or to the cellphone...
Sep 22, 2013 | Cell Phones
I have a 1992 Rascal, Model 240. The charger assembly has a burnt mark on it. Is there a schematic or picture of the board that I can get? My brother may be able to fix it, but he can't identif
The charger is a 24v 4 amp one stage device. Its an incredibly cheap charger. It consists of a step down transformer, a bridge rectifier, a filer capacitor, and a voltage regulator. Virtually all chargers are made this way. Generic schematics
http://www.simple-electronics.com/2011/10/24v-battery-charger-simple-and.html
This charger is built around the famous an popular LM317 chip it really simplifies things.
http://www.circuitstoday.com/24v-lead-acid-battery-charger-circu
I would get out my trusty multimeter and chase 24v though the device.
You may need a VOM meter only $9
http://www.amazon.com/Mastech-YG188-Pocket-size-analog-multimeter/dp/B00064CH6A/ref=sr_1_8?s=hi&ie=UTF8&qid=1339024102&sr=1-8
Set the meter to read VAC, you should get 30VAC out of the transformer. Next check the rectifier section, Set the meter to read VDC, the output should be about 29VDC. There is a fuse in there that you can check out. Then there is the regulator, if any part of that is fried, you're going to have a hard time finding parts. i really miss the 60's when there were electronic stores on every corner. There used to be a time when you could order your your TV as a kit. You could literally teach your kids something useful at the kitchen table. Quite frankly a 2 amp charger cost $14 4 amp cost $28. Not worth fixing really.
Chargers can be found here
http://www.amazon.com/Electric-Scooter-Battery-Charger-Prong/dp/B001GMTKN4
Jun 19, 2012 | Electric Mobility Mobility Electric Power...
My Power supply burned cause my brother Plugged it in the New zealand power,....Im from the STATES,...What makes me concerned is that im afraid that my console is Damaged,...Please tell me its not...
Welcome to Fixya
Looks like you have a burnt power supply. Burnt power supply wont damage the console. Purchase a new power supply and problem will be solved.
Thank you for using Fixya!
Sep 29, 2011 | Microsoft Xbox 360 Console
I plug my charger in but it wont charge and when i hold middle button it says charger connected and charges but as soon as i let go it says cahrger is disconnected.
Welcome to Fixya. Possible reason that your charger might have been damaged, or there's a wire that connects from the charger to your cellphones might be loose. Also cahrger connector on your cellphones might also damaged. If you have a friend or relatives that have the same cellphone, I suggest that why dont you try to use their charger on your cellphone or vise versa (your charger to their cellphone). In that way you, you can identify which one is damaged.
Please let me know if you have any questions.
Thank you for using Fixya,
seancarlisle
Apr 30, 2011 | Cell Phones
It used to be that i would have to push really hard on my charger for my phone to charge now it doesnt even charge. i push the on button and it wont turn on either! what do i do!
The problem is between the connection of your cellphone and the charger. I think the power has been drained from the battery already that's why it's not turning on.
I have two suggestions:
1. Check the hole in your cellphone where you put in your charger. Maybe, the hole has a problem or any sign of damages.
2. Buy a new charger. Check whether your cellphone works with the charger before buying it just to make sure that it's not your phone which has a problem.
I hope this helps.
Please rate this solution.
Jan 28, 2011 | Cell Phones
Phone not turning on
Most probably, either your charger is not working or your cellphone charging slot is damaged. Try changing your charger (if you haven't already)
Sep 05, 2007 | Samsung SGH-D500 Cellular Phone
Motorola Mobility SLVR L7 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
