Question about Refrigerators
Is aelectrical problem
Is a electrical problem
  • Refrigerators Master
  • 1,606 Answers
Posted on Jul 17, 2009
How do i determine the rotation on aelectric clutch
The clutch doesn't rotate it locks up the pulley so it can provde power..the electrical operation is usually facing out..to figure out the direction of the spin turn the belt or shaft which ever you have and see what direction it would go to operate the blades etc..Good luck
Feb 28, 2015 | Garden
Tip
Common heating faults with Bosch HBL 455 Stainless Steel Electric double oven
For all Free appliance repair videos visit our VIDEOTUTORIALS 1, If the Bosch fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the BOSCH element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your BOSCH fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your BOSCH oven thermostat
4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Bosch HBL 455 Stainless Steel Electric...
Tip
Common heating faults with Bosch HBL8750UC double oven
on Jan 19, 2010 | Bosch HBL8750UC Electric Double Oven
Dead battery key stuck in ignition
charge car battery !!! there is more than likely aelectric solenoid that will only release key IF the transmission is in P FOR park
Jan 13, 2014 | 2005 Cadillac SRX V6
Electric main oven fan blows out only cold air
For all Free appliance repair videos visit our VIDEOTUTORIALS Nefffan oven element video1, If the fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the NEFF element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
Dec 07, 2009 | Neff Ovens
I have a Neff U1721 circotherm oven. The lights come on and the fan works but it does not heat up. What could be the problem?
Nov 13, 2009 | Neff U1421 Double circotherm Electric Oven
Shifting problem
i think is aelectrical problem, i have seen this too in honda acord , d4 gear blinking an from some time it was dificult to travel with this gear is not going up 80 km/h. so check electrical system a soon as possible, and i dont think is any relation wjith changement of your brakes , if you dont have touched any electrical wire system.
Apr 06, 2009 | 2003 Kia Rio
Brake lights
i would start with checking fusebox.then take your back lights out to check the bulbs. if neither one is it then you have aelectrical problem
Sep 15, 2008 | 1991 Chevrolet Caprice
Lens error
i just did the same with mine.. it give me aelectric shock it was funny... so dontworry about it hurtint its just like a vibrating up your arms relly:L xx
Aug 09, 2008 | Nikon COOLPIX L3 Digital Camera
Need replacement cord for rival CF153-WM
check out aelectric dryer or stove for cord or a replacement
Jul 15, 2008 | Kitchen Appliances - Others
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
