Question about Freezers
It's my mother's Side by side Kenmore (4 yrs old). Iciles appear to form UNDER the icemaker unit. Filter has been changed and temp adjusted. What could be the problem?
  • 534 Answers
It is possible that the tray itself has a crack in it. The icicles tend to make me beleive that you have a cracked tray because ice accumulates in the form of a cicle by consistantly dripping, running downward and over time the freezing occures . You might take food coloring and mix with water. Pour this mixture into yhe icemaker tray with the unit off and let it sit. If the tray is leaking the food coloring will let you know, if no leaks then it has too much water being allowed into the unit or too much water pressure. Good Luck
Dave
Posted on Jul 17, 2009
GE bottom freezer stopped cooling sporadically every 1-2 days then cools again with no intervention. Unit is 5 yrs old.
Put the old board back in. See what it does, from your post, sounds like it was working correctly.
Jan 24, 2015 | GE Profile PGCS1NFZSS 20.7 cu. ft....
Have a Kenmore Elite Side by Side and there is water running down the side of the fridge which appears to be coming from the water filter. Already changed it twice.
Did you flush the system after changing the filter? Air can cause water to leak if it not flushed after each filter change. It takes about 6 to 7 minutes to get all the air flushed out. I hope that helps...
Nov 12, 2014 | Kenmore Elite Side By Side Refrigerator -...
After changing the water filter, the ice maker is not working. The water dispenser is working properly.
You may need to replace the dual water control valve due to only the water dispenser side of the water control valve being the only side that works. What is the model number of your Kenmore refrigerator? Kenmore model numbers look like this=> 321.235689 as an example. An example of the water control valve if your model number was 321.235689 is part number=> 12001414 Water Inlet Valve
Don't use this example as the correct part. Look around the fresh food section door frame for your correct model number, Thanks
Sea Breeze
Testing the Water Control Valve
Mar 31, 2013 | Kenmore Elite Side By Side Refrigerator -...
Temperature
If this unit has a control it would be located on the outer left side in the lower right hand corner. There would be a dial, the higher the number the cooler the temperature. Many of these chest freezers did not have an adjustable control.
Apr 13, 2010 | Kenmore 15 cu. ft. Chest Freezer 16542
Kenmore hotspot ice gets stuck same spot
if the cubes are small the water valve may be bad. Also pop the cover off and see if there is a plastic tab laying loose in the cover . It should have 2 holding the center plastic gear on if only one is in the center the ice maker is bad. Also make sure to change your filter ever 6 to 8 months if you have one this will stop other problems.
Sep 23, 2009 | Freezers
Kenmore Refrigerator Ice Maker
ck condensor fan motor that cools compressor under unit. yoder loop runs through center divider and causes gaskets to get hot
Aug 26, 2009 | Kenmore Freezers
Kenmore ice maker problem
the problem is an unlevel icemaker to prove this do you see little droplets of water freezing from the icemaker or a remote possibilty is do you have to an R/O system and have you change the filter if unit has one.
Aug 19, 2009 | Kenmore Freezers
Freezers Logo
77 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
