Question about Canon PIXMA iP4300 InkJet Photo Printer
Replaced Yellow Cartridge, Red light on, close lid, not working,
Hi, I just replaced my Canon iP4300 with the Yellow CLI-8Y cartridge, and the cartridge clicked into place easily, then when I closed the top lid and waited for the cartridges to slide to place, the info on my computer screen came up "check ink cartridges, make sure all lights are on" so I did this and have done repeatedly, when I open up lid the Yellow cartridge light is off.. I click cartridge back in easily, close lid and the same Info shows on screen again.. I have checked all, and this is the first time I have had this trouble.. All ink cartridges are Canon, suited for this Printer, never had a problem until I changed the Yellow cartridge.. Can you give me any guidance as to why this is happening please.. I cannot even print plain Black now also.. Not printing at all.. HELP! thankyou... Dianne
  • 92 Answers
Hi ...
I would suggest that you follow the below stesp to install the ink tank ..
. Ensure that the printer is on, and then open the Top Cover.
The Print Head Holder moves to the center.
Note: If the Top Cover is left open for more than 10 minutes, the Print Head Holder moves to the right. Close and reopen the Top Cover to return the holder to the center.
2. Open the Paper Output Tray.
Put your fingers in the notches in either side of the Paper Output Tray and pull down to open it, and then pull down the Inner Cover forward to open it.
3. Remove the ink tank whose lamp is flashing fast or is off.
Push the tab and remove the ink tank.
Do not touch the print head lock lever; remove only the ink tank.
Replaced Yellow Cartridge, Red light on, close lid - ip4300_remove_ink_tankgif.gif
Caution: Handle ink tanks carefully to avoid staining clothing or the surrounding area. Discard empty ink tanks according to the local laws and regulations regarding disposal of consumables.
Note: Be sure to replace ink tanks one by one when replacing more than one ink tank.
4. Prepare a replacement tank.
* Do not touch the electrical contacts on the ink tank. Doing so can cause the printer to malfunction or become unable to print.
Unpack the new ink tank and completely pull off the orange tape. Then, remove the film. Remove the orange protective cap from the bottom of the ink tank and discard it.
Important:
  • Be sure to remove the clear film from the ink tank in the exact order shown in step 4, as failure to follow this step may cause the ink to leak and stain your clothes and hands.
  • Do not squeeze the side of ink tanks as this may cause the ink to leak out and stain your clothes and hands.
  • Do not re-attach the protective cap once you have removed it.
  • Do not touch the open ink port once the protective cap is removed, as this may prevent the ink from being ejected properly.
  • Ink on the removed protective cap may stain your clothes and hands.
  • Ensure that all the orange tape has been peeled off along the perforation. If there remains a part of the orange tape, ink may not be output correctly.
5. InstReplaced Yellow Cartridge, Red light on, close lid - ip4300_install_ink_tankgif.gifsrc="http://i.fixya.net/uploads/images/ip4300_install_ink_tankgif.gif" alt="ip4300_install_ink_tankgif.gif" class="h_mi" />
(1) Insert the ink tank into the Print Head.
(2) Press on the 'PUSH' mark on the ink tank until the ink tank snaps firmly into place.
(3) Ensure that the ink tank lamp lights red.
Important: Ensure that all the ink tanks are installed in the order directed by the label. The printer cannot be used unless all the ink tanks are installed.
6. Close the Inner Cover.
Note: Ensure that the Inner Cover is closed. Printing will not occur if the Inner Cover is open.
7. Close the Top Cover.
The Print Head Holder moves to the right. The ink tank installation process is now complete.
  • The ALARM lamp still flashes orange after the Top Cover is closed if an ink tank is not installed properly. Open the Top Cover and make sure that all the ink tanks are installed in the correct order directed on the label.
  • To maintain optimal print quality, use an ink tank within six months of first use.
  • Once an ink tank has been used, do not remove it from the printer and leave it out in the open. This will cause the ink tank to dry out and the printer may not operate properly when it is reinstalled.
  • Color ink consumption may occur even when black-and-white or gray scale printing is specified.
    Color ink is consumed in the head cleaning and deep cleaning, which are necessary to maintain the printer.
  • When you start printing after replacing the ink tank, Print Head Cleaning is performed automatically. Do not perform any other operations until the Print Head Cleaning finishes. The POWER lamp flashes green during cleaning.
Don't forget to vote if this helps ... Cheers :)
Posted on Jul 17, 2009
I have a Canon Pixma ip4300. I replaced the 5 PGBK (the large non-photo black) cartridge and I went to print. A piece of paper got jammed, so I pulled that out and since then, that brand new cartridge...
Hi I think you may find a very small bit of paper may jammed under the print head, try removing the cartridge and have a close inspection, it only takes a tiny piece to cause the problem cheers Terry
Feb 26, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Hi, I have a Canon Pixma iP4300 printer and the Yellow ink is not printing. I have changed the cartridge and all other colours are working except Yellow. I would appreciate any solutions you may be able...
I have a Canon Pixma iP4300 printer and the Yellow ink is not printing. I have changed the particular cartridge and all other colours are working except Yellow. I have cleansed the printer several times and tried with new Yellow ink cartridges with new chips, but nothing helps.
What should I do?
Jan 25, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Where is printer cartridge located and replacement part number?
<!-- END PRODUCT IMAGE --> <span class="bold_text">CLI-8Bk Black</span><br /> <!-- END PRODUCT IMAGE --> <span class="bold_text">CLI-8M Magenta</span> <br /> <!-- END PRODUCT IMAGE --> <span class="bold_text">CLI-8Y Yellow</span> <br /> <!-- END PRODUCT IMAGE --> <span class="bold_text">CLI-8C Cyan</span> <br /><br />http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp600#SuppliesAndAccessories<br />
Aug 24, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Canon pixma ip4300 black ink refill. BK and PB
The correct order of install a ink tank (From Left to Right):-
1. CLI-8 Black
2. PGI-5 Black (pigment)
3. CLI-8 Yellow
4. CLI-8 Magenta
5. CLI-8 Cyan
Else you can visit this link and type "correct order of ink tank" in enter your question space.
Good luck...don't forget to rate the solution.
Feb 22, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Please help me to refill my ink cartridge, hp has complete instructions for remanufacturing but i could not find for canon. can you help?
There are catridge refill kits available for Canon catridges. Be sure to make sure that the kit will refill the cartridges for your model. Here is a link to a refill kit available on Amazon.com: http://www.amazon.com/Cartridge-Refill-CLI-8B-CLI-8M-CLI-8Y/dp/B00246MOHK
Jan 10, 2010 | Office Equipment & Supplies
Error code U071 , more than one ink tank of te following color is installed, is the message on the screen. This is not the case as each cartridge is different and correctly installed?
Error U071 : More than one ink tank of the following color is installed. U071.
Action : Confirm that the ink tanks are installed in the appropriate positions.
The machine will not print if the wrong type of ink tank is used, or if it is installed in the incorrect position.
Be sure to install the ink tanks in the correct order. The proper arrangement from the left is Black (CLI-8BK), Black (PGI-5BK), Yellow (CLI-8Y), Magenta (CLI-8M), Cyan (CLI-8C).
Hope this hepls.
Nov 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Can't find where the ink cartridges are on the cannon mp830 to replace
THE INK CARTRIDGES :
This multifunction printer is compatible with all of the following ink cartridges. Here is a list of these cartridges and how they you can get them:
PGI-5 Pigment Black
CLI-8Bk Black
CLI-8C Cyan
CLI-8M Magenta
CLI-8Y Yellow
All of the ink cartridges are easy to install and/or replace; all you have to do is keep the printer ON, then open the cover it will come in the position and then unlock the cartridge which allows you to remove and replace the cartridge.
These cartridges cost any where between $10 and $15 each. But if you want a good deal, I would suggest purchasing your ink supplies from Costco Wholesale as they provide good prices on packages.
Jul 11, 2009 | Canon PIXMA MP830 All-In-One InkJet...
MP530- Printer issue
Install recommended ink tanks in the correct order MP500 / MP530 / MP800 / MP800R / MP830
Ink Tank Order Install ink tanks in the correct order (from left to right) CLI-8BK (Black) PG-5BK (Pigment Black) CLI-8Y (Yellow) CLI-8M (Magenta) CLI-8C (Cyan) mp500_inktankorder.gif 05sj00141_08_en.gif
Jan 01, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA  iP4300 InkJet Photo Printer Logo
335 people viewed this question
old marine
old marine
