Question about Konica Minolta bizhub C250 All-In-One Laser Printer
IT HAS TO BE REPLACE ,THE MACHINE GIVES US THAT MESSAGE
  • Brian Hollingsworth
    Brian Hollingsworth May 11, 2010
    It being the printer or a part? is there an error code or just this message? Does the printer in anyway indicate a part that could be the source of the issue?
    Sergeant:
  • 210 Answers
There must be a consumables supplies that need to be replace. ie, transfer belt, transfer roller, developer, or toner. If one those units reach the life cycle it will give that messages to replace.
hh
Posted on Jul 27, 2009
After repairing a cracked guide?
Did you use a remanufactured ink cart.?
Sep 04, 2012 | Kodak EasyShare Printer Dock Series 3
My 8 months old battery won't turn on any more. used it for a few minutes and it was alright but it wont turn on with the AC adapter plugged in, and it gives me the message consider replacing battery....
If happens that the machine already detects the battery is already defective it will give that kind of message, the machine will not turn on unless the battery is already been replaced to prevent further failure on the machine, so the only way to fix it is to replace the battery.
May 16, 2011 | HEWLETT-PACKARD HP Mini 2101170NR Notebook
Machine stops near end of washing cycle and gives a -60 error message.
Sep 22, 2010 | Dishwashers
Samsung washing machine gives Low Water pressure error message and interrupts cycle. Checked inlet filters. Sometimes gives leak/flood warning message. How can I turn off these messages?
You get these messages turned off by fixing the problem.
Low water pressure is basically one of the valves is not letting water pass through.
1. Do as you already did and clean the inlet filters. Any kinked hoses?
2. Adjust the water pressure in the house. Is it too high or too low?
3. Replace the valves in the unit.
4. Main board.
Dec 29, 2009 | Samsung WF448AAP Front Load Washer
How do you reset memory board for muratec f-320 . I am trying to get rid of an error message"Replace drum unit printer not useable". Installed new drum unit and still gives the same error message.
Before doing complete Memory clear try the following...
Press..PROGRAM,*,*,I(thats the letter I),then ENTER.
That should reset it. Only replace the new drum into the machine when the machine says "Replace Drum"...NOT when it says "replace drum soon".
As a last resort a complete memory clear is PROGRAM,*,3.....but be warned this will clear all memory back to factory defaults "except" the Life Monitor which has the counters.
Oct 29, 2009 | Muratec F320 Plain Paper LED Fax
When I turn on my XL-1000 machine it gives me the message that the Bobbin winding Shaft message even though it is not in that postion and will not allow me to use the machine what gives?
There may be something jammed in the sensor giving the false reading, or the sensor may have failed.
If you have miswound thread into the mechanism this may account for it.
If you can access the top and take a look it may be obvious, if not, time to call service centre.and ask for a quote.
Aug 30, 2009 | Yamata FY2600
Maytag Calypso Washer
replace the control board
May 25, 2008 | Washing Machines
STOP FOR SAFETY
My Kenmore 19606 sometimes gives me that error message when I am holding my fabric taut (on either side of the foot) and I accidentally exert pressure on the needle (that is, tug forward or back on the fabric pulling at the needle)... I found that when it gives me that message and then pauses for a while, cranking a few stitches by hand seems to "recalibrate" it if you will, and bring it back to normal operation sooner... If you're not a tugger like me... =op =o) Maybe the needle needs replaced? It might be slightly bent, or not screwed in properly..?? Don't know if that helps! Good luck!
Oct 26, 2005 | Kenmore 19030
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
90 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
