Question about Symbol PDT 6846 Portable Terminal
How to connect the PDT6800 to computer?
I have bought the PDT6800 barcode scanner. But I have no idea to make the connection to the computer. Please help...thanks.
  • domingoaranc Jul 17, 2009
    I have follow the manaul to set up the connection, but it doesn't work, I want to connect the PDT6800 with my computer, I have download the wavelink.exe and also the hex. file. But I have no idea to install the hex. file. Please help.
    Sniper:
  • 86 Answers
Product manual can be downloaded here
http://www.barcodesinc.com/symbol/pdt6800.htm
Posted on Jul 17, 2009
Tip
How to connect a barcode scanner to your computer
<p>If you run a business, you probably need a barcode scanner to help control the items in and out of your iTunes. It is also possible to bar code reader to a computer at home. These devices connect through a USB port like most other external hardware. <br /> <p><br /> <p>1. Connect the barcode scanner to your computer via the USB port. A window showing the computer has detected a new piece of hardware. <br /> <p><br /> <p>2. Insert the CD driver installation. Wait until the installation wizard. <br /> <p><br /> <p>3. Follow the instructions to complete the installation. Remove the driver CD and replace it with a software CD is provided. <br />
on Jun 26, 2011 | Computers & Internet
Tip
How to connect barcode scanner to your pc
In order for them to be useful, barcode scanners often have to be connected to computers. We will recall that in virtually all cases, the data which gives meaning to the barcodes they read is stored in databases, which are in turn hosted on computers. What the barcode scanners are meant to do, then, is to transmit the data they scan to the computer, with the computer checking that data against the database in order to assign meaning to it. In most cases, then, scanners without computers will tend to be quite useless. For a scanner to be useful, it has to be connected to the computer. And what we are interested in, for this discussion, is gaining an understanding of the ways through which barcode scanners connect to computers (at the simple, physical, external level).
As it turns out, there are four main ways through which barcode scanners connect to the computers which host the databases upon which they depend:
1. Serial port connection: this is where the scanner comes with a pin which you simply hook onto the serial port of your computer (like where you would hook an extra mouse), and thence connect the barcode scanner to computer. It was, arguably, the first method for connecting barcode scanners to computers to be developed. Its disadvantage is that it is not a plug and play approach. You have to go through quite a lengthy installation process for the barcode scanner, when you go this way. Furthermore, should the scanner 'hang' somewhere in the middle of a computing session, you don't have the option of just unplugging it and then plugging it in again to see whether it will work. Instead, you have to restart the whole machine again, and this can be very disruptive, for instance in the midst of a shopping checkout for a hurried customer. In this system, a scanner would also need specialized software to connect to various computers, meaning that there was no universality in scanner usage.
2. Keyboard wedge connection: this is a connection method where the barcode scanners are put in somewhere between the keyboard and the computer as a 'wedge.' It is something of an improvement on the serial port connection.
3. USB connection: this is what is to be found on most scanners, today. It is where you connect the scanner to the computer using any USB port. A scanner made in this way can, therefore, be used with pretty much any computer. Should it stall midcourse, you have the opportunity to just unplug it, and plug it again, to see if that solves the problem (which it often does). It is also convenient, because in this approach, connecting the scanner to the computer becomes as easy as connecting a USB flash disk to the machine.
4. Wireless connection: this is the emerging technology in ultra-modern scanners, where using systems such as Bluetooth, they are able to connect to the associated databases wirelessly.
on Oct 05, 2010 | Computers & Internet
I dint get connection with my pc. to my USB.. it is not recognizing
Does some other USB device work properly when connected to the USB port that you are trying to use with your Transcend Barcode Scanner?
Did you try to connect the Transcend Barcode Scanner to some other computer? If so, did the other computer recognize it?
If the Transcend Barcode Scanner is "brand-new", did the packaging for it come with a CD-ROM that you need to use -before- trying to connect the Transcend Barcode Scanner to your computer?
Aug 19, 2010 | Computers & Internet
Whenever I am connecting my broadband connection to my laptop no Lan is being detected.
Hello izkho,
Your Local Area Connection network adapter may be turned off or disabled in your Network Connections.
For more assistance, please post more information and specification of your system. (operating system, computer model, connecting media, amount of network cards, etc.)
Best regards,
Ashe
PS Did you mean to post this under barcode scanners?
How do i get it to connection
You have to set-up the barcode scanner in the manual. The most common mistake is not scanning the "host" option. The scanner default is "no host" It will not work until you enable the appropriate "host" option by scanning that particular barcode. Read the manual. Contact the Honeywell Help Desk (they bought Metrologic)
Nov 03, 2009 | Metrologic Instruments MS9535 VoyagerBT...
DON'T KNOW HOW TO USE
Firstly you connect ps/2 scanner cable of ms5145 to computer.then connect keyboard to Scanner.You can open word and Scan any barcode it displays on screen
Feb 14, 2009 | Eclipse Metrologic MS5145 Barcode Scanner
Barcode scanner scans and beeps, but will not put the numbers in the computer
There is more than one way for that imager to send data to the computer. Are you using USB, serial, or is there a little box that goes between your existing keyboard and the PC that accepts the scanner connector?
Jan 03, 2008 | Symbol LS 4000i Handheld
StratosE ms2122, it scans it beeps but nothing appears.
most barcode systems will scan and beep when presented with a valid barcode (if the barcode conforms with a valid format). This just means it is powered up (it does not require any input from the computer to do this) I believe you have a driver issue, which controls how the scanner communicates with your computer. please check that you have up to date drivers and software from the manufacturer's website and that you can find the device listed (by name) in your Device listing Gareth
Jul 25, 2007 | Metrologic Instruments MS2122 StratosE...
Symbol PDT 6846 Portable Terminal Logo
495 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
