Question about Lexmark F4270 Plain Paper Inkjet Fax
Cant send a fax
I can send a fax i have a dial tone but cant fax i have a lexmark x4270 all in one i can get a fax but not send one .
  • troykirchner Jul 17, 2009
    I can hear a dial tone i also hear it dial up but it does not connect .
    I can get a incoming fax thou
    Sniper:
  • 86 Answers
Confirm dialing the correct fax number?
Any 0s to get an outside line, any special area codes?
What happens when you try to send a fax, can you hear a dial tone? can you hear the fax ringing? can you hear a response from the recipiant?
Posted on Jul 17, 2009
  • Gillian Horwood Jun 17, 2013
    Right Fax No. Fax ringing, then wipes no off telephone, but transmission report says everything is OK, but it has not gone through the machine still sitting in tray.
Fax will not work--no dial tone--copier works ok/phone line is ok
Make sure your phone line for the fax is correctly plugged into the Line Port of the printer and not the EXT port. For a more comprehensive guide on how to setup the Lexmark X4270 for faxing, please refer to the Lexmark X4200 Series User's Guide.
The user's guide also contains some fax troubleshooting steps for your reference.
If you still need assistance, please contact Lexmark Technical Support Center.
Aug 24, 2011 | Lexmark X4270 All-in-One Multifunction...
How do you set up lexmark x4850 printer to send fax (do I plug a phone line in)
You have to use a fone line to send a FAX out of a printer, make sure the line has a dial tone on it first.
Jul 06, 2011 | Lexmark X4270 All-In-One InkJet Printer
Fax machine will not let me send fax out or come in. x4270
make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility and line is working.go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 18, 2010 | Lexmark X4270 All-In-One InkJet Printer
LEXMARK PRINTER
change the dialing mode from tone to pulse
Jul 24, 2009 | Lexmark X4270 All-In-One InkJet Printer
Hi i cant send a fax
First thing is to ensure that you have dial tone by picking up the handset on the fax machine and listening for dial tone.If there is no handset take a standard house phone and plug it into the jack where the fax machine was inserted. If there is dial tone on the phone then I would advise you to turn the power off the fax for two minutes then power back on. If there is no dial tone on the phone line contact your vendor or local phone carrier and report NO DIAL TONE
May 30, 2009 | Lexmark F4270 Plain Paper Inkjet Fax
No dial tone on my Lexmark X4270
There are two outlets in the back where you plug in your phone line. I had the same problem when I
was plugged into the far left plug (as you are facing the front of the all in one). I switched to the other
outlet and it worked fine. But still once in a while it seems to loosen up and I have to push it back in
farther. Today I got a dialtone but could not send a fax. I got a dialtone but still wouldn't send. So I
checked the outlet and sure enough, it was just loose enough to prevent the machine from registering
the fax number, but connected enough to get a dialtone.....go figure. Good luck
Apr 10, 2009 | Lexmark X4270 All-In-One InkJet Printer
Can't receive or send fax on my lexmark X4270
In this case first we need to chk whether there is any dial tone on ur fax machine for that u need to Hit the Options button till u find an option saying On Hook Dial now hit select and it should give u a dial tone if it doesnt check the Phone Line Connections........... If it gives u a dial tone........... Unplug the Power Supply from the Printer........ Press and hold the Stop/Clear button and while holding the Stop/Clear button insert the Power Supply back to the Printer........ It will say clearing and then display a page where u need to Selct ur Country and the other details........ and as soon as this is done u can send and recieve faxes....... Thanku
Jan 12, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmark x2470. Fax solutions not working after going high speed
Please check that the Phone line for faxing is connected to a seperate NON FILTERED phone line. Not to the dsl line. You can use a line splitter for this. Also the dial up modem may need to remain in your computer for the fax software to dial out. Hope this helps.
Dec 07, 2008 | Lexmark X2470 All-In-One InkJet Printer
Problems with lexmark 1270 sending fax
See if you are getting a dial tone from the phone.
-> If you can't, check the line.
-> If you can get a dial tone and successfully call out. Make sure you are not running on a digital phone system, IP phones, using DSL, etc. Fax machines have problems on digital lines and many either won't work without a line scrubber or work intermittantly.
Jul 13, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark F4270 Plain Paper Inkjet Fax Logo
270 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
