Question about Garden
Ryobi 775r gas trimmer stalling when tilted
I purchased a used Ryobi 775r gas trimmer. Used it once, it worked perfectly. I replaced all the rotted fuel lines and bulb and now it starts fine, buts the engine stops when the trimmer is tilted into position for trimming. Any advice?
    President:
  • 512 Answers
You have a air leak between to tank and motor. Could be carb gasket. When using in tilted position you dont have gravity feeded carb anymore, causing air to be sucked into carb. Take off carb and spray with crb cleaner, then blow out with air gun. Replace gasket, make sure all new lines and bulb connections are connected securely.
Posted on Jul 17, 2009
Where can I get a parts breakdown ( exploded view ) for a Ryobi 775R 16" string trimmer.
here's the link. http://www.partstree.com/parts/?lc=mtd&mn=775r+41AD775A034
Mar 17, 2013 | Garden
Ryobi CS30 - Stalls out?
Dirt or varnish in fuel filter or carburator. Change filter if there is one.
Flush out the carb with a varnish remover.
Open high speed needle valve 1/8 turn farther, then turn in while running until it just smooths out.
Jun 07, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Need a diagram that will show the tubing feeds on ryobi weed trim
If you need a fuel line diagram for ryobi 775r let me have your email address.
tony
Oct 13, 2009 | Garden
I can not start my ryobi 775r trimmer. There is fresh gas and the fuel/oil mixture is correct. I've gone thru all the starting procedures in the owner's manual including for flooded engine. I installed a...
Remove your spark plug, take a rag and dry it up shoot a little WD-40 into it reinstall. Do not prime the unit or turn the choke on just pull it should start for you, make sure you are are not leaving the choke on, that is a common mistake.
Oct 10, 2009 | Ryobi Three Trimmer Combo
Fuel line routing on ryobi 775r
One line ( the one with the fuel filter in the end of it) comes out of the fuel tank and goes to the lower port on the carburator. The second line goes from the fuel tank to the bottom fitting on the primer bulb. The third section goes from the top port on the primer bulb to the top port on the carburator. Hope this helps and best wishes.
Sep 01, 2009 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 775r won't start. I replaced the spark plug but still no go. I have never replaced the fuel line didn't know that was necessary
make sure you have fresh gas miture first, then put spark plug on housing as you pull it over (with the switch on) watch for spark if its there then its a gas problem. old stinky gas is usually what happens when it sits for months. carb may need to be rebuilt if it still won't start. also check exhaust screen to make sure its not plugged.
Jul 16, 2009 | Ryobi Garden
Ryobi 775r edger blade does not turn. Motor runs
Have you made sure the drive shaft cable is tuning and is properly installed and that there is no debris or dirt stopping the blade from turning?
Jun 13, 2009 | Ryobi Garden
RUNS AND STALL WHEN YOU GIVE IT GAS
you are right on. try richer mixture.
May 22, 2009 | Ryobi Garden
Garden Logo
477 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
