Question about D-Link DI-634M Wireless Router (DI634M)
D-link router connection problems
I have installed router can see it clearly on 2 different laptops but both will not connect. I have left them open as far as security. on one computer it reads that wlan failed.
Help
  • Erek Apr 08, 2008
    I have three PC's connected to the internet via a DI-634M router plus a laser printer.
    All three connect to the internet and print no problem, but try and get any of the PC's talking to any other, impossible!! I know it is someting to do with the router, but what??? I'm sure you techies out there will solve this problem with a few key strokes, please help!!!
  • Anonymous Dec 27, 2008
    I cannot
  • 205 Answers
I'm guessing you're saying you've left the security open on the pc's, but what about the router? You can connect to most wireless routers with a TCP/IP cable. Try that and see if you can check your wireless router's settings. It may have some security settings enabled.
Posted on Nov 18, 2007
Hello, I followed the installation instructions with Wizard and was told I successfully installed the router. However, when I try to connect (wireless network connection) it tells me that Windows is unable...
Connect a LAN cable from the D-Link to your laptop/computer'sLAN port, open the browser on your laptop/computer and enter the D-Link'sconfiguration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
May 22, 2011 | D-Link Xtreme N DIR-655 Router
I have had this acer notebook for about 2 months and I can no longer access wireless internet. My 2 other laptops, hp and dell, are working and accessing the wireless router just fine. I have done the...
Connect the computer to the router via Ethernet. Navigate to acer's website and click on your country of residence. Navigate to drivers and downloads, then, click on notebook, netbook, or desktop. It will then follow the prompts to download and install your wireless driver. It should be labeled clearly. Unfortunately, I don't have an Acer, so can not direct you to an exact filename. If this isn't satisfactory, post it with a model number and type of computer and I'll get the direct link to you.
May 04, 2011 | Acer Computers & Internet
When initially setup the router worked fine. However, after a computer crash and re-install, the desktop pc cannot find the router even though it is connected by Ethernet. Laptops will connect to the...
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Dec 09, 2010 | Belkin Wireless Play Router (F7D4302)
The printers drop out the network when connected
Hello
Double check the IP Address info for both printers - ensuring the IP Address, Subnet Mask and Default Gateway are configured correctly. Printers should never use DHCP - so this info should be configured as a static IP.
Also, try moving the connections for the printers to different ports on the router. It is possible that the router may be going bad and the printer ports are the first to show the signs.
One final tip - power cycle the router. I have used D-Link for over 8 years and have had to power cycle their routers and hubs occasionally as they sometimes lock up. This typically affects all ports - so this is probably not the cause of your issue but power cycling the device may help resolve the issue.
May 04, 2010 | D-Link AirPlus DI-524 Wireless Router
We recently installed a new replacement router WRT 160N V3 and something called Network Magic keeps interupting and trying to sell their service. We keep canceling them and then the router does not work...
To clear out the problem if Network Magic has something to do with your connection.
1) Uninstall Network Magic from host computer.
2) Remove Ethernet connections to router.
3) Reset the router (press & hold reset button for at least 15 secs.)
4) Run Setup wizard on host computer and follow on screen instructions on connecting PC to router.
5) Setup wizard prompts on installing Network Magic, just ignore it.
6) if it automatically installs Network Magic just uninstall the program before you fully use your router.
Resetting router clears all settings made by Network Magic application made on the router.
Hope this helps.
Mar 13, 2010 | Linksys Wireless-G WRT54G Router
Hello, hope all is well i have just bought a new desktop computer with a DWA 520 wireless adapter... we have been struggling to get a decent signal from our wireless Dlink router. So much so we have...
try putting the wireless router closer to the computer but not right beside maybe theres interference with something, your built in wireless in the laptop is prob way stronger than the cards you got there are different ranges for different cards and if you get a low card it wont connect to high speeds or longer distances and make sure your connecting to your routers wireless and not someone elses wireless router, it sounds stupid but it happens ive did it before make sure the right drivers are on the computer for the card you installed hope one of those helps
Jul 26, 2009 | D-Link Air DWL 520 802.11b (DWL-520)...
The router is connecting me with an unknown network
your router is not connecting you to a different network.it`s your laptop which is connecting automatically to a preferred network or you can say it is connecting to whichever unsecured network is available.please clear ypur preferred network list or you`ll keep facing the same problem.i can`t explain you how you can do that because you have not mentioned the OS you are using.please use google for the same.thankyou
Jul 16, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Cannot connect DI-524 to VISTA
There is nothing on DI-524 what is Vista specific. Make sure you installed your dirivers properly. I have the same , works without problems.
Jan 22, 2009 | D-Link DI-624 Air Plus XtremeG Wireless...
Can't connect a laptop wireless to WRT150N
What you can do is remove the wireless connection profile that is saved and create a new one. Go to wireless connection properties and create a new wireless profile. If that doesn't work, what you can try is change the wireless channel of your router to Standard Mode using channel 11 the power cycle the router.
Jan 13, 2009 | Linksys Wireless-N WRT150N Router
Wireless connection problem. laptop ip address is 60.60.x.x
D-LINK WILL HELP YOU...
Set up your new D-Link networking hardware in minutes using our new Quick Setup Wizard. The wizard will guide you through an easy to follow process to install your new hardware and connect to your network. If you need additional help, visit D-Link’s award-winning Customer Support Web Site for answers to frequently asked questions, product downloads, and easy access to D-Link’s friendly customer support team.
Jul 05, 2008 | D-Link 802.11g Wireless Router WBR-1310...
D-Link DI-634M Wireless Router (DI634M) Logo
131 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
