The thing was stuck at 4.4% and said 1h57mins remaing for about 45 mins and I was getting very annoyed- i turned power off and turned on- when I keeping trying to continue update- it says installation error- what do I do? :( Would appreciate any advice, thanks
SOURCE: my zumo won't power on
This sometimes happens if the cradle is owered while you connect the zumo...i guess it hits some wrong contacts first and goes bonkers. I'd advise th zumo users to pack a small allen screw bit to unscrew the battery, just in case it freezes or blacks out again....better safe than lost in the middle of nowhere!
SOURCE: DMR-ES15 Stops after 45 Min.
U88 means the unit has detected an error while recording or playing and has entered its recovery process to restore the unit to normal operation. You could try using a DVD-RAM disk or a different make of DVD-R but, as you say the unit is new, you should probably return it to the retailer for exchamge, repair or refund according to unit age and retailer's return policy.
SOURCE: keep gettin error code 80710723 when updating system on ps3
mae your playstation 3 wired then download it. once downloaded then go back to wireless.
SOURCE: SISTEM SOFTWARE MISSING on my Garmin NUVI200 GPS
All Garmin users,
There is no easy solution for this except to return your unit to the nearest Garmin outlet. You need to have very special equipment called an E-Prom burner or writer which only Garmin have. With this equipment they re-programmed (restore) the operating system back on your specific Garmin unit and model.
The problem why anybody can't do it is because there is no way you can access your Garmin unit from a pc or mac if the operating system is lost or damage on your Garmin, for the simple reason your pc or mac can't reconize the device that is pluged in, because there are no communication platform between the two devices.
As simple as that, life with it or send your Garmin gps to an autherized professional Garmin dealer.
Marius Oosthuizen
Garmin dealer
South Africa
SOURCE: Garmin Nuvi 265 W 'system software missing' message
The system bootloader software got scrambled when you did the update. You can escalate it to a software tech and they may be able to give you the bootloader image file. If not, you'll have to get an RMA and send it back for a unit swap.
