Question about HP LaserJet 3015 All-In-One Printer
Hp 3015 not installing
I install the hp 3015 from cd and when i click finished it said hardware not installed correctly
  • HP Master
  • 1,113 Answers
Problems seem to occur when printer cable is plugged in before software is installed.
Delete driver and software installed, disconnect printer from PC.
Download and install correct driver to suit, connect usb when software prompts to do so
Make sure the driver you are installing is correct for you system
LINK to DRIVER DOWNLOAD
Posted on Nov 18, 2007
Hp 3015 printer working fine but coudn't scan working
Check copy option, if its working well, check OS support, un install the drivers install once again with original CD..
Oct 11, 2011 | HP LaserJet 3015 All-In-One Printer
I don't know how o install the printer HP Laserjet 3015. I don't have the disk.
Click on the link below, it will take you to HP downloads page, select the operating system you are using and download the print driver. After downloading Install the same and follow the on screen instructions.
Click Here
Regards,
Shrey
May 31, 2011 | HP LaserJet 3015 All-In-One Printer
Lost my installation cd for hp laserjet3015 all in one printer what to do for installing
You can download the HP printer drivers from their supportWEB site. Please click on this link and select your model printer to download:- http://welcome.hp.com/country/us/en/support.html
Nov 04, 2010 | HP LaserJet 3015 All-In-One Printer
Tried to load HP Laserjet 3015 s0ftware with printer plugged in. That failed. Now getting "finds new hardware" when I try to load the software even though nothing is plugged in. software is not asking me...
The thing is printer is automatically detected by the system and there was no proper driver was installed and it is in device manger installed as other device with yellow mark. Just uninstall it. And click on scan for hardware changes. To go to device manager right click on my computer and go to properties then hardware in that click on device manger and check there is any other device is listed if it is there just remove it and click for scan for hardware changes when he prompt for driver reinstall the driver cd.
Don’t connect the printer usb cable first
1st you install the driver disc which is come along with the printer and when the software prompt you to connect the cable then plug the usb cable and follow the instruction.
Have a nice day and do not forget to rate please...!
Feb 15, 2010 | HP LaserJet 3015 All-In-One Printer
HP3015 All in One - new toner put in but printing very pale
Try going into the Maintnence Center, should be in Options or Maintanence and running it.
Mar 11, 2009 | HP LaserJet 3015 All-In-One Printer
I tried to install my hp laserjet 3015 several times but I failed
  • It may take a little time for the CD to begin reading. Hit retry.
  • The CD may be damaged
  • The program may not load automatically
  • Go to the Start menu and then click on "Run". When the Run window appears, click on browse. Choose the D drive (or the one that reads your CD). Look for a file that ends in setup, execute, or install (these words my be abbreviated)
  • Double click on the file and it should be displayed next to "open" in the "Run" window.
  • Click okay and the program should begin to install.
Jan 28, 2009 | HP LaserJet 3015 All-In-One Printer
Connecting the printer to a bluetooth note book
Installing the Printer in Windows Vista Using Bluetooth
Step one: Install the software
Install the software so that the appropriate choices can be made during the installation to resolve the issue.
1. Insert the printer software CD in the CD-ROM drive of the computer. The software installation starts automatically.
Tips & Tricks: If the software installation does not start automatically, click the Start icon. In the Start Search text box located above the Start icon, type D:\setup.exe, where D is the letter of the CD-ROM drive, and then press Enter.
2. On the User Account Control window, click Continue.
3. Follow the instructions that display on the screen to install the software.
Tips & Tricks: If the User Account Control window displays during the installation, click Continue.
4. When prompted to choose the connection type, select directly to this computer using a USB cable and then click Next.
5. On the Connect Your Device Now window, select If you are unable to connect your device now, click this box and then click Next to finish installing the software. You can connect your device later.
6. Click Next.
7. Follow the instructions that display on the screen to complete the software installation.
Step two: Install the Bluetooth dongle
1. Insert a Bluetooth dongle in an available Universal Serial Bus (USB) port on the computer. Windows Vista automatically installs the driver for the dongle.
2. If the printer does not have built-in Bluetooth support, insert a second Bluetooth dongle in the Bluetooth dongle port of the printer after the drivers for the first dongle are installed. (If its an HP bt300 or bt450 then the drivers can be Downloaded for the same from hp.com similarly as we download the drivers for the printers)
Tips & Tricks: This step is not necessary for devices that have built-in Bluetooth support.
3. In the System Tray, right-click on the Bluetooth icon and then click Add a Bluetooth Device . The Add Bluetooth Device Wizard opens.
4. Select the My device is set up and ready to be found check box and then click Next .
5. Click the name of the printer.
Tips & Tricks: If the name of the printer is not displayed, verify that the printer is turned on and then click Search Again . After the name of the printer is not displayed, click the name of the printer and then click Next .
6. On the Do you need a passkey to your device? dialog box, select the appropriate check box and then click Next .
7. On the Completing the Add Bluetooth Device Wizard screen, click Finish .
8. On the Found New Hardware window, click Don’t show this message again for this device .
Tips & Tricks: Multiple Found New Hardware windows might display. Click Don’t show this message again for this device each time the window displays.
9. On the User Account Control window, click Continue.
10. Click Finish.
Step three: Update the printer drivers
1. Click the Start icon, right-click Computer, and then click Properties.
2. Click the Device Manager tab.
3. Click the + sign next to other devices to expand the list.
4. Under Other devices, right-click the name of the printer and then click Update Driver Software.
5. Click Browse my computer for driver software.
6. Click let me pick from the list of device drivers on my computer and then click next.
7. Under Common hardware types, click Printers and then click Next .
8. Under Manufacturer, click HP.
9. Under Printers, click the name of the printer and then click Next.
10. On the Update Driver Warning window, click Yes. Windows Vista installs the driver for the selected printer.
11. On the Windows has successfully updated your driver software window, click Close.
12. Verify that the drivers are installed correctly.
a. Click the Start icon.
b. Click Control Panel.
c. Under Hardware and Sound, click Printers.
d. Right-click the name of the printer.
e. Click Properties.
f. Click the General tab.
g. Click Print Test Page.
13. If the test page prints successfully, the printer is installed correctly.
Tips & Tricks: If the test page did not print, verify that the correct printer was selected .
Oct 06, 2008 | HP Photosmart C6180 All-In-One InkJet...
How do i install hp laser jet 1018 printer
hi johnboy
you can download the driver from here hp 1018
select your windows to download .
riz.
Jun 09, 2008 | HP LaserJet 1018 Printer
HP 5550. Stuck in install loop
uninstall previous printer driver and resintall again the cd driver
Feb 01, 2008 | HP DeskJet 5550 InkJet Printer
HP LaserJet 3015 All-In-One Printer Logo
184 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
