Question about Toshiba e-Studio 232 Black and White Copier
TOSHIBA e350.ERROR C400.REPLACED EVERYTHING IN FUSER UNIT .
ALSO REPLACED POWER SUPPLY. STILL ERROR C400
  • Toshiba Master
  • 653 Answers
There is no C400 error code for E350 model. Anyway, u can try 08-400, reset the value to "0".
Posted on Jul 17, 2009
How do I remedy error SC 552?
change the main motor or clear the eroor
Sep 10, 2015 | Ricoh Aficio SP C811DN Laser Printer
Il affiche printer error service call6000
problem is with fuser,Code Error indications Contents
Check procedures/corrective measures
6000 Fuser unit error
Yes
Yes
Yes
No
No
Turn power switch off,
and remove power
cable.
Detach connector CN4
on power supply unit.
Detach connector CN1
Measure resistance
between pins 1 and 2
of the detached
connector.
Replace fuser thermistor.
See page 1-6-25.
Replace thermal cutout or
heater lamp. See page 1-6-
26 or 1-6-22.
Replace bias PWB (K0009)
or high voltage unit or power
supply unit. See page 1-6-13
or 1-6-12.
Open (infinite)?
No
No
Open (infinite)?
Measure resistance
between pins 1 and 3
of the detached
connector.
Replace harness
(2FM2601) between engine
PWB (K0010) and bias
PWB (K0009).
End.
Yes
No
Replace engine PWB
(K0010). See page 1-
6-9.
"6000" error
shown?
"6000" error
shown?
START
Feb 03, 2014 | Kyocera Mita Fs-1016 Mfp Multifunction;...
How to reset fuser unit in printer hp laserjet 4250
turn the printer off for at least 20 minutes, then cycle power. If the 50.2 fuser error occurs again, you may need to replace the entire fuser assembly OR you will need to replace the power supply.
Dec 24, 2012 | HP LaserJet 4250n Printer
TOSHIBA E STUDIO 207 ERROR C 44
All error code soloution of fuser unit Fuser Unit Error Status Counter
Purpose
When a fuser unit related error (error code C41, C43, C44 or C45) occurs, the set value of the fuser status
counter varies, depending on type of error.
Displaying and checking the set value of the fuser status counter can analyze a cause for the error. If
any of "2 to 9" is set at the fuser status counter, the fuser unit will not be operated for safety reasons.
After the fuser unit related error is resolved, if "0" is set, the fuser unit will be operated as usual. If any of
"10 to 19" is set at the fuser status counter, the fuser unit will be operated as usual, even if "0" is not set
after the fuser unit related error is resolved.
C41: Thermistor or heater abnormality at power-ON
C43: Thermistor abnormality after abnormality judgment
C44: Heater abnormality after abnormality judgment
C45: Thermistor abnormality during printing
C46 to C49: Reserved
Description
When this code is used, the current set value of the fuser status counter is displayed. Only "0" can be
manually entered, in order to restore the fuser unit to its normal operation, after the fuser unit related
error is resolved.
For further reason why the counter value differs despite the same error code, refer to 5.1.7 or 5.1.8
[Fuser unit related service call] in the Service Handbook.
0: No error 10: C47 (Reserved)
1: C41 (Once) 11: C47 (Reserved)
2: C41 (Consecutively occurs) 12: C48 (Reserved)
3: C46 (Reserved) 13: C49 (Reserved)
4: C43 14: C47 (Reserved)
5: C44 15: C48 (Reserved)
6: C45 16: C49 (Reserved)
7: C44 17: C47 (Reserved)
8: C45 18: C48 (Reserved)
9: C44 19: C49 (Reserved)
* Default: 0
Setting Timing
Use this code to resolve the fuser unit related error (error code C41, C43, C44 or C45). Resolve the
error, and set "0" (or reset the counter), in order to restore the fuser unit to its normal operation.
Caution
Remember to resolve the fuser unit related error, and then reset to "0."
Jul 08, 2012 | Toshiba E Studio 207
Error code c440. call for service toshiba studio 352
Fuser unit error code, need to replace fuser unit
BR
Feb 11, 2011 | Toshiba Estudio 200L Copier
Samsung clp-610 has an error code of ''adc slope error cycle power'' what does this mean? How can we rectify the problem?
this would be a problem with the fuser unit. the analog to digital converter, ADC, is malfunctioning or there is a problem with the heat being put out by the fuser itself. if cycling the power doesn't clear the problem you will more than likely have to replace the fuser unit.
Sep 11, 2009 | Samsung CLP-610ND + Demo Laser Printer
Error 58.04
This is from the service manual and should help you determine if you need to call in for service. If is in warranty I would anyways since the fuser would be covered if at fault.
58.04 ERROR To continue turn off then on. The low-voltage power supply has experienced an error.
1. Reinstall the fuser. Check the connector
(J1901) between the fuser and product.
Replace the cable or fixing unit if the
connector is damaged.
2. Reconnect the connectors of the fuser
control PCA (J303, J305) and the DC
controller PCA (J107).
3. Replace the fuser. See Fuser
on page 191.
May 03, 2009 | HP LaserJet 5200tn Printer
HP 8150DN I got 50.1 Error message so I replace low voltage power supply and know I get 51.1 error message now
Yes, 50.1 refers to the fuser, and that is very easily replaceable. (no tools) However, in the 8100, you have a 75% chance that it is indeed the low volt power supply. The low volt power supply powers the fuser.
As a service approach, I always replace the fuser first because it is so easy to do and we always have them in stock.
If that does NOT clear the error, then we KNOW it is the low volt power supply. That is a very straightforward repair.
Mar 04, 2009 | HP LaserJet 8100n Printer
Hp 4350 error code 50.3
I have just changed the fuser unit and the printer is still giving the
same error [fuser error and low heating] Kindly help.
Maxwell Mpundu@technet.co.zm
Apr 21, 2008 | HP LaserJet 4350 Printer
010 397 Error Message on Dell 5100cn
The following steps are the troubleshooting steps that should be followed for error code 010 397.
First, the definition of the failure is <IOT Fuser Failure>, and means a Fuser Error is detected.
1) With power off, reseat the fuser by physically removing it from the printer, then reinstalling it and locking it in place. Turn the power back on. ( if the error is still present, proceed to step 2 ).
2) If reseating the fuser did not resolve the problem, Replace the fuser with a known good fuser.
( if problem is not resolved, proceed to step 3)
3) Replace the LVPS ( low voltage power supply ). ( if problem not resolved, proceed to step 4 ).
4) Replace the PWBA MCU ( printed wiring board assembly - machine control unit ).
END of troubleshooting.........
In most cases, the fuser itself is the problem. If you tried to reseat or replace the fuser while power was still on, the LVPS could have been damaged just as if there were an electrical storm.
Hopefully this helped.
Apr 04, 2008 | Dell 5100cn Laser Printer
Toshiba e-Studio 232 Black and White Copier Logo
272 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
