Question about Philips Pocket Memo LFH9350 Digital Voice Recorder
The display screen on my philips DPM LFH9370 seems to have split. How can this be repared?
White disply how to repar
Usually an all white display means that the connector from the screen to the main board has come loose. If you feel comfortable enough, split the case open and look for the connection for the screen. If the phone was dropped and this happened, it's likely the scenario that fits the best for an easy repair. You may need some specialty tools ( read: tiny jewelers screwdrivers ) to open it up completely to get access to the screen. Otherwise someone that advertises that they fix small electronics could check it out for you for really cheap, if they charge you anything at all.
Nov 29, 2014 | Cell Phones
Philips pocket memo LFH 9730
Hello I don't recognize that model may be you try to say Philips Digital Pocket Memo LFH9370.
Your unit charges two ways via power supply direct on the portable or via docking station, make sure you have the proper rechargeable batteries you must have the LFH9154 if you don't have this batteries you can buy them on the next link http://www.tvps.com/Products/Philips-LFH9154-AAA-NiMH-Rechargeable-Batteries---New-9154__PH-LFH9154.aspx
May 06, 2014 | Philips Audio Players & Recorders
I bought the Philips LFH 9397 dictation system a long time ago, but have only just got round to turning it on for the first time. When I turned it on the words "Philips DPM 9370" flashed on the...
You mean to say you bought a $ 300.00 recorder and didn't take the batteries out during the long time storage?
Hopefully the batteries didn't leak all over the place.
Did you at least try to use new batteries? Two good AAAs can't be very expensive.
Jun 20, 2011 | Philips LFH9370 Handheld Digital Voice...
Our 9500 series Philips digital pocket memo will not clear the old files when complete. As a result, we are unable to download new files. Any help would be appreciated. Thanks! Jill
Hello You need to Use Philips SpeechExec software for automatic
download, conversion and routing of files
recorded with a Pocket Memo dictation
recorder. How and which files are downloaded after a
recorder is connected can be configured in
the settings menu of SpeechExec or with the Configuration Wizard
Configure the download process
from the Pocket Memo
Pocket Memo is connected can be configured in
the settings menu or the Configuration Wizard.
1 Connect the Digital Pocket Memo to the PC
using the USB cable.
2 Click Settings > General Settings on the
menu bar, select DPM/DT Configuration >
DPM Settings from the list on the left side.
3 Click the Start... button. The DPM configuration
dialog is displayed in a new window.
4 Select Download in the left pane.
5 Select which files will be downloaded
(download file type):
• All files
• EOL (recordings marked as finished/endof-
letter)
• File selection (SpeechExec prompts the
selection of specific files to be downloaded)
• File with keyword 1 (specify a keyword)
6 The download settings also allow the user
to specify if files will be deleted on the
Pocket Memo after they are downloaded.
7 Click OK to save the settings and confirm
the transfer of the new settings to the
Pocket Memo.
Apr 05, 2011 | Philips Pocket Memo 9500 (256 MB 1 Hours)...
Screen cracked
http://www.ownta.com/original-ipod-touch-3-mp3-player-reparing-lcd-display-screen-replacement.html
http://www.ownta.com/original-ipod-touch-2-mp3-player-reparing-lcd-display-screen-replacement.html
Make sure you know the acutal generation 2 or 3.
Mar 26, 2010 | Apple iPod touch
Cracked screen
2nd generation is here: http://www.ownta.com/original-ipod-touch-2-mp3-player-reparing-lcd-display-screen-replacement.html
3rd generation is here: http://www.ownta.com/original-ipod-touch-3-mp3-player-reparing-lcd-display-screen-replacement.html
Good Luck !
Feb 24, 2010 | Apple iPod touch
Philips tv model 21 pt 5007/69 circuit manuel
my tv control panel is locked.there is only on screen av1.it is not changed.
Jan 19, 2010 | Philips Televison & Video
Philips DPM 9350 digital audio recorder [Digital Pocket Memo]
The spring release assembly is very cheap and should not cost you more than 25$ even if you get it repaired so i advice you take proffessional assistance..
Nov 02, 2007 | Baby Gear
Philips Pocket Memo LFH9350 Digital Voice Recorder Logo
55 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
