Question about Sanyo PLC-XF46N LCD Projector
When we start the projector. its on and shows blue screen with sanyo log with seconds but after few second it goes blank. and in projector power led goes blinking orange
  • 115 Answers
Check lamp, Ballast and the Air filters
Posted on Jul 17, 2009
Sanyo pro xtrax projector
Lamp LED should be lit when the projector is in Standby. However, the problem you are describing sounds like one of two issues. Either the lamp is bad and needs replaced, or there is a power supply fault. If you have tried replacing the lamp already, make sure you reset the lamp counter or the projector may still not function properly.
does the temp warning light come on when the projector shuts off? if so you may also try cleaning the air vent filters and ensure there is proper air flow around the projector. if that checks out then have the projector serviced as the power supply is likely suspect.
Dec 09, 2013 | Sanyo Office Equipment & Supplies
VPL-HS50 shuts down after few seconds
It must be a problem with electric connection. you should check whether it is OK or not. If it is okay, read instruction manual.
Jun 27, 2012 | Sony VPL-HS50 LCD Projector
Hi I have a Sanyo PLC-XP18 projector and it has recently developed a problem. I was watching a film the other night and the projector just cut out. Now when i try and turn the projector on the the fans...
READY light is green when the projector is ready to be switched on
LAMP is dim when the projector is ON, but goes bright when it reverts to STANDBY.
Check that the lamp cover is fully down and the cover switch is activated
Feb 28, 2011 | Sanyo PLC XP18 Multimedia Projector
My projector will not power on. I've replaced the cables, the power source, and the bulb but still nothing. The red standby led on the control unit turns blue when power button is pressed but goes right...
The ballast unit has most likely failed. Replace the ballast unit, unless the lamp exploded and in which case, there may be glass fragments stopping a fan from turning.
Feb 03, 2011 | Optoma HD81 DLP Projector
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Sanyo PLC-XF46N LCD Projector Logo
260 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
