Sewing Machines Logo
Darlene Lynn Posted on May 11, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Feed dogs up?
How do i put the feed dogs up for regular sewing as when i bought the machine the feed dogs are down and can not get them up to sew as just sews in one spot
R.A. Ellis
Level 3:
  • Sewing Machines Master 12,731 Answers
  • Posted on May 11, 2016
R.A. Ellis
Level 3:
Answers
12731
Questions
Helped
2615590
Points
59176
If the feed dog lever does not raise the feed dogs, then they are probably stuck. Probably needs lubrication. Since the make/model was not specified, would recommend taking it for service.
Bill Boyd
Level 3:
Top Expert:
  • Sewing Machines Master 53,816 Answers
Bill Boyd
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11933262
Points
172802
Move the direction setting from neutral and the feed will come up
Singer Heavy Duty 4423; I have put in a fresh needle, I have tried re-threading, feed dog lever is in the up position, there is no lint or thread accumulated in the machine, and it is oiled properly. When...
f Fabric Is Not Feeding Properly
If the machine is not feeding fabric when you start sewing, it could be that the presser foot lifter has not been lowered before stepping on the foot controller. Lower the presser foot and resume sewing.
Another reason the machine may not be feeding fabric is that the feed dogs (or feed teeth) are disengaged, so make sure that they are properly engaged for sewing. (Note: If your machine has drop feed, resume normal sewing by moving the drop feed lever to regular sewing mode, then turn the hand wheel toward you one full revolution to re-engage the feed dogs).
The machine may also not feed fabric if the stitch length control is set to "0". Increase the stitch length setting and resume sewing. Reference - Singer .com. Troubleshooting tips.
1helpful
Can not raise feed dogs
They WILL come up for you, and here's how. You see, anytime you put the feed dogs down they go down right away. But when you put them up again, you have to turn the hand wheel TOWARDS YOU (ALWAYS TOWARDS YOU FOR ANYTHING) at least one or two times before the dogs come up again. You'll hear them "snap" into place, but until you do that, they won't move at all, on ANY machine I'm familiar with.
A word about pulling the hand wheel towards you. If you turn it away from you for more than one revolution, you run the risk of throwing off the timing. I was told this by a technician of many years experience many years ago.
1helpful
The fabric isn't moving and the bobbing thread isn't coming up.
when the fabric doesn't move then the feed dogs need to be checked
here is a link for a free manual, if you don't have one
http://www.singerco.com/uploads/download/1132_white-2200-x-.pdf
check in the manual to see if it show where the feed dog lever is, if the feeddog is in the up position or down, it must be up for regular sewing, if it doesn't show the feed dog then the machine would have to be taken in to a sewing machine shop to have the feed dog checked
try changing the needle
make sure the bobbin is inserted correctly into the bobbin case
and make sure the bobbin is turned the right way in the bobbin case
Feed dogs not advancing fabric, only moving up and down
Normally it's good form to give us the make and model number of your machine.
Sounds to me your problem began with operator error. Get in the habit of grasping the threads and holding them as you take your first few stitches. Also make sure your take up lever is in the UP position before you take your first stitch.
Now, look to see if your feed dogs are lowered... if they are put the back up. If this happens again... you've got a warn or broken part.. and you should return the machine. Clearly your "repairman" sold you a lemon.
1helpful
Feet not feeding and thread bunching up
the presser foot or what ever foot your sewing with does not feed the
fabric,, the feed dogs in the needle plate are what moves the fabric
to be sewed, the feet only hold the fabric against feed dog so the
machine can use the needle to sew the fabric.
if the fabric is not moving then the feed dogs have to be checked
can you see the feed dogs in the needle plate area are the up or
down?
do you have a manual for the machine?
a manual help to know where the feed dog lever is, I'm sending
you a link for a manual for the machine, so you can look for the feed
dog lever, if the feed dogs are up then there is something wrong
with the feed dogs & they need to be checked.
but if the feed dogs are down then look in the manual & see where
the feed dog lever is & put it in the up position & see if that brings
the feed dogs up to the sewing position, if the feed dogs do not
come up then the feed dogs need to be checked.
http://www.sewingpartsonline.com/instruction-manual-necchi-6015.aspx
The dog feed stuck in the downward position.
Have you turned the machine off and then back on?
The switch may be broken and you will need to find a sewing machine repair shop that repairs all brands of sewing equipment.
If you decide to purchase another machine try a different brand. This one seems to have on a lot of issues.
2helpful
When you set the switch for the feed dogs to be in the up position, turn the handwheel 1 complete revolution and they should come up.
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
