Question about Garden
Model#zth6125kaa 25 hrse kawi carb.Starts cold just cranks on war
Id#zth6125kaa 25 hrse kawi carb.Starts cold sart as should. After running 10-15 min if you shut it off try to restart warm eng it just cranks.Fuel ok there seems to be a start & run relay on this could it be a relay ?????
  • montague530 Jul 20, 2009
    ref.to fr23487 cold start fine mower will run all day until shut off wont resart warm .If rings & or valves are concern why doest mower missfire while running after warmed up
  • 130 Answers
It could be a relay;rings;or the valves,
it sound like compresstion therefor rings or the valves
Posted on Jul 18, 2009
My mower has been having problems staying running it would only run with coke out I replaced parts and it worked but now its hard to crank and it starts and runs rough for a min and shuts off
Only running with the choke out means it is lean and probably has dirt in the passageways of the carb. Clean carb and float bowl of sediment and water .
Oct 24, 2015 | Cars & Trucks
Cold start low ideling
You can in most cases repair this slow speed stall or unstable idle by cleaning the engine throttle valve and the idle speed control valve using a product called CRC Spray Throttle valve cleaner. Spray the cleaner into the air intake of the engine with the hose removed from the throttle body, the engine will try to stall so hold up the idle speed manually. Once you have used up about 1/2 can of the cleaner stall the engine out while spraying and turn the key off, disconnect the negative battery cable for 5 minutes and then reconnect and drive the car for a about 25 miles of varied driving modes. If this doesn't cure the problem you may need the fuel injectors professionally cleaned by the dealer service dept.
May 19, 2017 | Mercedes-Benz Mercedes 190E 2.3-16 Diecast...
Got a craftsman leaf blower cranks up and runs fine for about 5 mins then starts losing rpms
ITs hard to diagnose these things over the internet, it could be so many things.
Is this a gradual loss of power? If so; Im sorry to say; that it sounds like its losing compression as it warms up. It is not cost effective to repair the unit.
If the loss of power is more sudden it could be a failing ignition module. Ive even seen spark plugs that quit working when they get hot.
To test this you will need a proper spark tester, laying the spark plug against the head will not provide an accurate assesment, and a can of carb cleaner. Run the unit with the air box cover and filter removed till it fails and immediately give a shot of carb cleaner in the carb and restart. If it starts right up it could be fuel related. IF it doesnt start right up then quickly test for spark. If no spark then its likely the ignition module. If it wont run on the extra fuel and it has spark then it has probably lost compression.
Nov 05, 2012 | Craftsman 4 Cycle Blower/Vac
94 gs500e suzuki starts and runs fine for about 15-20 mins then will stall and cut off while im driven like it has no gas. Then after 25 mins it will start back up and ride fine for awhile. any answers
The fuel petcock may be the problem. It works by opening a valve to let gas reach the carbs. It does this using a vacuum diaphragm drawing vacuum from the carbs. A gs500 will not work very well without an airfilter either. The carbs rely on proper vacuum to operate and a poor or no air filter will make a gs500 run very bad. Gs500s are air cooled also. If none of this solves the problem do a major tune up. Still nothing then take it to a mechanic. Taking shots in the dark gets expensive.
Aug 21, 2011 | 1990 Suzuki GS 500 E
2004 sebring 2.7 engine, will strt when cold but not when warm
more than likely a bad crank sensor but not knowing if there are codes might also be a cam sensor,it is deffently a electrical componet problem hot soak of the motor will break down bad electrical sensors,
Jan 23, 2009 | 2004 Chrysler Sebring
Not starting
Don't pull the chock out all the way, more like 3/4. The clicking you are hearing is a low battery & or corrided contacts. The battery its self may may need to be replaced. If its a cell battery, one or more cells may be bad. Take it to a battery outlet & let them test the cells. Most do not charge for this service.
Mike
Jan 02, 2009 | 1997 Honda CBR 250 RR
Garden Logo
60 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
