Question about Nokia N70 Cellular Phone
My phone always lounch media key and loudspeaker when i make call
If i make call it media key will appears on the screen
Cisco 504g will not power up
Plug out the cable from this and put in again or reset the device.
May 08, 2014 | Cisco SPA504G IP Phone
Tip
Tips & Review on Nokia 5300 XpressMusic
Nokia 5300 is a great music phone,but it can be regrated on that the battery life is so short.So I've come up with this tips and tricks that can help you save some juice out of your phone.Love the loudspeaker but don’t abuse it so much it might become unfunctional.Don’t set the volume to the maximum level when playing through the loudspeaker.I found the radio better and clearer when playing through the loudspeaker than the music player because the loudspeaker omits more treble than the bass.
Camera Tips:
1. Always set the NIGHT MODE option especially on night shots
2. Set the White Balance to Daylight – When outdoors (Day) Fluorescent – When indoors
3. For acceptable shots, set the resolution to 800 x 600.
NOTE: Using the camera will put up a big drain on your battery.
Battery Tip:
- Don’t always use the camera. Only when needed.
- Set Packet Data Connection to When Needed. Setting can be found on Settings>Connectivity>Packet Data
- Always turn on the Power Saver Feature.
- Turn off your Bluetooth when not in use.
- Turn off screensavers (These are only battery wasters)
- Always make sure that the phone has adequate signal. (If the phone is searching for signals, it drains a big part of the battery)
- I know its fun to play games, but it can decrease your battery so fast.
- The best of all,carry an extra battery if you’re a heavy user.
I think this tip can be helpful. Thank you Everyone.
on Sep 22, 2009 | Nokia 5310 Cellular Phone
I have a nokia E75 and i cannot hear anything through the earpiece but it works on loudspeaker
Full format solution for NOKIA
Switch-off your phone. 1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
Mar 10, 2010 | Nokia E75 Cell Phone
Loudspeaker
tap the speaker icon on the status bar and then tap the speaker phone check box to play sound via the speaker phone
Jul 11, 2009 | Nokia 6708 Cellular Phone
4444 problem
Such problems usually occur due to virus attacks.Either you format your phone or if it doesn't works update your phone's software with the latest firmware version.Dont forget to install and regularly update antivirus software on your phone..
Jun 25, 2009 | Nokia N70 Cellular Phone
I want to increase volume of caller.
To actually answer a call using loudspeaker, press the top-left button (options) and then the middle select button (with the option "Loudspeaker" highlighted). You can do this even when Keyguard is activated. (I just checked.) It means pressing two keys but at least it actually answers using the loudspeaker.
To make a call, the only way I can see is to dial first and then press the Loudspeaker button while the phone at the other end is ringing.
Mar 04, 2009 | Nokia 6230i Cellular Phone
Always loudspeaker
have the phone checked by a repair shop
Aug 20, 2008 | Nokia N72 Cellular Phone
Loud speaker during call
When the call will be in progress u have to see on the right handside corner of the screen of ur handset, option of "loudspeaker" will be there OR u go to "options" on the left handside of corner of screen.Press it and loudspeaker will get activated.
Oct 20, 2007 | LG KG800 Cellular Phone
Nokia N70 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
