Question about HP Pavilion dv8000z Notebook
HP DV8000 Pavillion Laptop
My HP DV8000 Laptop has just encountered an insuue starting Windows. I get the startup screen asking if I want to go to Safe Mode, Safe with networking, last known good configuration or start normally. Starting Normaly counts down, eventually goes to the launch screen but does not launch after 15 minutes. last known configutration same result. Will launch in Safe or Safe with networking without issue. I restored factory defaults to no avail. Attempted System restore but found no restore points available. I am in Iraq so on site tech support is limited. Hoping to avoid a re-install as some crucial programs needed are back in the states and will most likely be wiped out.
  • Robert Nyilas
    Robert Nyilas May 11, 2010
    you can tell me the error when booting windows, pressing f8 key select disabel automatic restart on system failure
Why won't my HP Pavillion G6 turn on after downloading windows 8.1 update?
try disconnecting power supply and removing battery as well then replace both and try again.Is it possible there was a power interruption while update was downloading. have you tried to access the bios on startup (press f9 at start of startup until it goes to bios)and see if all settings are ok
Sep 01, 2014 | HP Pavilion G4 G6 G4-1000 Series...
When i turn it on, its blue lights come on but nothing on the screen. I am using my sister's laptop to ask. It is an HP Pavillion.
If the computers lights are coming on and the fans are turning then the computer is receiving power. Try turning the sound on to see if you can hear the Windows Startup sounds (or Mac respectively). If you can hear the sounds then it is likely that the screen for the laptop has broken. If the laptop has a Video Card (most do not) this could also be faulty. Since you can't see anything you won't be able to fix it yourself, it will likely need to be returned to HP for laptop repairs.
Mar 14, 2011 | HP Computers & Internet
HP Pavillion DV8000 Laptop won't boot.
When your computer hardware appears to power up okay, but the Windows XP operating system won't boot properly, you have to begin a troubleshooting expedition that includes getting into the operating system, determining the problem, and then fixing it. To help you get started on this expedition, here are 10 things you can do when Windows XP won't boot.
Click here for more information
Nov 27, 2009 | HP Computers & Internet
Hp Laptop Wont Boot
Hey dear,
Your operating system got crash. Use backup CD.
Turn on yr lappy. manually open the cd rom from right side of leptop. Put CD in. then wait for few seconds. u will see the screen then follow the instruction and re install the entire windows.
Sep 13, 2009 | HP Pavilion dv6000z Notebook
How about this Pavilion dv8000 Battery for HP Laptop Battery?
You just write down the details about HP pavilion dv8000 battery, I know two websites have cheap HP pavilion dv8000 battery
http://www.cheap-laptop-battery.co.uk/laptop-batteries/hp-pavilion-dv8000-series.htm
http://sales-battery.com/laptop-batteries/hp-pavilion-dv8000-series.htm
Jun 02, 2009 | HP Computers & Internet
I have an HP Pavillion ZE2000 laptop and it will nto boot up, push button to turn it on. goes to windows page then goes black and nothing happens will nto boot all the way up to windows page with icons. is...
press f8 at startup to get to the windows startup menu, choose "last known good configuration" If that fails, you can choose "disable automatic restart" and the BSOD, Blue screen will appear and give you an error, you can also goto safe mode with the f8 key on startup, choose safe mode, and then click yes at the prompt to start the system restore, pick a date and time the PC worked, and try that.If that doesn't work, you need to restore the PC to factory default state, by using or purchasing restore disks, you would have been asked to make them when you 1st powered on the PC, if you don't have the CD's call HP and order them.
Apr 20, 2009 | Computers & Internet
Having problem with start up on Hp Pavillion dv8000
Try choosing "Last known configuration that worked" if this does not fix you problem, then reboot once more, and while it is booting up tap the F8 key and select safe start.
Ps. you may just need to do a fresh re-install
Jan 18, 2009 | HP Computers & Internet
Hp pavillion zv6000 white screen on startup
bad video maby bad ram bad screen one of them or bad power chips on mobo worse case
Jan 29, 2008 | HP Pavillion ZV6000 Notebook
HP Pavilion dv8000z Notebook Logo
322 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
