Question about Transcend T.sonic 610 MP3 Player
2004 jeep grand cher. trans will not shift too low
The car will drive it wont shift too low gear not even if i manule shift it is a v6 and i cant find a presure switch or nothing can u help me please
  • 8,596 Answers
Re: 2004 jeep grand cher. trans will not shift too low - Transcend T.sonic 610 MP3 Player MP3 & Digital Media Players
Wrong section
Posted on May 23, 2008
0 characters
3 Points
What makes my 2009 santa fe gear shift sorta stiff to move
This condition is usually caused by the transmission gear shift tower
seizing up in the inhibitor switch. To correct this, the gear shifter cable will have to be taken off at the transmission end which is fasened to the shift tower. Then remove the inhibitor/range switch and unseize the shift tower, working it back and forth with antiseize lub. Once the tower is cleaned, lubbed and has free movement, install a new range switch and reinstall shift cable if it is okay. Note: reinstall range switch in the same position as the old part so the start settings for park and neutral are good.
Feb 22, 2015 | Hyundai 2009 Santa Fe
Vr3 vrvd630 wiring
This page might help:
And this page will provide you with several pages to visit:
Stuck in drive
This problem is sometimes caused by a defective brake light switch. It provides power to the shift lock switch to enable gear shifting. There is a TSB for this issue so it can be fixed at the dealer for free.
Thanks for using Fixya.
Mar 15, 2013 | Hyundai 2009 Santa Fe
My GO gear Mp3 player wont be detected on any computer. even if you install the hardware, it wont still detect.
if your player don't detect . also don't detect with Philips Device Manager
try to download this driver for it usb 2.0 ADFU Driver .
i worked with 7 and in system device manager show "uknown usb device" but in XP show this "usb 2.0 ADFU Drive" and also the Xp itself install it . if your windows dosent have this so go on to download it manualy . then use philips device manager to repair it . i do it myself and it worked
Dec 13, 2010 | Philips GOGEAR SA6045 MP3 Player
Wont charge
Have you tried to reset? The reset button is right by the lock switch. It's small so use a pin or something small like that.
Apr 11, 2009 | Philips GoGear SA3020/37 MP3 Player
Cant hear songs from my mp3
its internal hardware prosser is froze ...cant fix it, manufature defect
Oct 30, 2008 | Insignia Sport MP3 Player
Wont charge
make sure the hold/lock is not engaged
then:Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Jul 06, 2008 | Philips GoGear Flash MP3 Player
Frozen solid
i have the same promblem i was listening to my music and it had full batteries and it just shut off this is so bull like i think i have to return it and buy something else!!
May 06, 2008 | Philips GOGEAR SA6045 MP3 Player
Volume not loud enough
Actually there is a way. If you re-encode the file using an mp3 conversion utility, you can adjust the volume there
Jan 19, 2008 | Philips GoGear SA178 MP3 Player
Go gear in the car
If your jeep has a casette tape player, you can buy a casette adapter that will plug into your GoGear headphone jack.
-Tha Mp3 Doctor
Jan 03, 2008 | Philips GoGear HDD1830 MP3 Player
Transcend T.sonic 610 MP3 Player Logo
26 people viewed this question
Top Transcend MP3 & Digital Media Players Experts
Gyula Lacz
Are you a Transcend MP3 and Digital Media Player Expert? Answer questions, earn points and help others
