My TSST corp CD DVDW SH-S225F ATA device doesn't work
Suddenly , since yesterday lunchtime, my DVD RW on Drive D:/ isn't working ..it doesn't recognize that a disc is in the drive .... I tried re-starting my machine . I even tried a roll-back to a point before luch !
I tried uninstalling and then re-installing the device . I tried updating the driver. It tells me the driver is up to date. The Windows Vista Device Manager tells me '' this device is working properly'' ...but ...it isn't !! Can anyone help ??
    President:
  • 1,314 Answers
Yes; the drive will need to be replaced.
As far as the "device is working properly"...it is a misnomer. By that, windows means that it can see and communicate with the device, but it doesn't know if the laser inside the device has failed (likely, since it can't see a disc in the drive). You just need to pick up a replacement DVDRW (around $20 or so) and replace it.
Posted on Jul 17, 2009
  • 555 Answers
Hello my friend kindly turn off your computer then unplug all the power cord connected to your power source then open your system unit and uplug your IDE or SATA cable from your CD/DVD RW then plug it properly then close your system unit then try to plug all the power cord and try to turn on your computer then go to CMOS Setting then load the default setting then restart your computer. Try to do this steps 2 - 3 times. If the result is still the same kindly ask or find a technician in computer in your place to have some assistance tand let that person help you fix your problem.
If you need more assistance kindly reply to this post.
Thank you
Suddenly DVD drive (TSST corp CD/DVDW TS-L532M) has some malfunction. It won't burn DVD until end if file size is more than 2,5GB. It stops first around 96% if I have another try it will stop 86% and so...
what can it be lets make a list.
first off
Toshiba/samsung TSST when bankrupt in 2016
so no drivers now from them.
HP does not support this PC now, ended long ago.
MS XP is a dead OS, and does not send you drivers for this XP, MS shut the drivers services off called PnP.
1: XP is infected, as all are now.
2: the drive is bad. as many are now this old
3: the driver is missing or wrong own or it is infected.
4: the XP, DVD filters are wrong in the registry,
google that, see 1 millions hits, all the same.
5: your unstated BURN app is infected or corrupted.
try imgburn (free)
6: bad media DVD-R? your drive is lightscribe version , my guess is yours is OK.
7 burn at a slower speed?, use image burn
your spec is here. 8x
8x maximum write speed (DVD±R)!
* 2.4x maximum write speed (DL DVD+R)
* 4x maximum rewrite speed (DVD+RW)
* 24x maximum write speed (CD-R)
* 10x maximum rewrite speed (CD-RW)
* 24x maximum read speed (CD)
8: the unstated file is too big. ?
but if it really is 2.7GB then it is not.
Nov 20, 2017 | HP Pavilion dv8000t Notebook
My Vista - tsst corp cd/dvdw ts-l632d ata device driver for cd unit doesn't works
From your description I understand that the DVD drive is not working .
Do not worry, run the following fix on the pc and then restart the notebook.
http://www.techiesspot.com/filez/cddvdfix.reg
Dec 29, 2009 | HP Pavilion dv6000t Notebook
Tsst corp cd/dvdw ts-652d ata device not found
your CD-ROM/DVD-ROMs require no drivers   install Nero and see if it works  if not  check the wiring  if it has IDE cables make sure the jumpers are correct for the situation  make sure they are 80 pin cables not 40 pin and that the poer is plugged into the drives  sometimes if Patin-couffin is installed it may fix things
Oct 20, 2009 | Gateway GT5435E Refurbished AMD Desktop...
How do I install a TSST corp CD/DVDW TS-L632D ATA device
It should just plug in and windows will reconize it.
Sep 25, 2009 | Computers & Internet
No valid drive/disk when dvd is inserted program tells me there's no valid drive or disc found?
say that the tsst corp cd/dvdw ts- l632d ata device
code 19 or 13 is corrupted or regestry is the problem.
Sep 20, 2009 | Intervideo WinDVD 5 for PC
TSST Corp CDDVDW TS-L632N ATA DEVICE
Try to uninstall your optical drive on device manager and restart your system.
->if that doesn't work try a firmware update.
->if that still doesn't work,replace optical drive.
that should resolve your problem
May 29, 2009 | HP Pavilion DV6700T Notebook
TSST Corp CD/DVD RW TS-L632M ATA device wont play discs. Driver is current
I also have the TSST cd/dvd with the same problem but I just realized that is a comflict between all these programs I have installed (Windows Media Player, Sonic and Roxio Easy Creator 6). WMP will not even show it, then I went to Roxio audio central an it worked perfectly. I tried to change the default back to WMP but it wont take it. I believe this happens because Roxio was the last I installed and took control of the sound. Hope this help. I will be uninstalling my WMP and installing it again so that I can keep it as my first choice.
Apr 22, 2009 | Computers & Internet
DVD drive dont work
If you have Two cd/dvd drives make sure one is set to master and one to slave to do this on the back of the dvd drives is what looks like a piece of plastic there will be two rows of 4 pins for master the plastic piece should on the right hand side next to the long slot for slave move it one pin away from the long slot keep me posted please
Jan 13, 2009 | Samsung (SH-S162L/BEBN) DVD RW Burner
Have a problem on burning dvd
Download any other burning software and use it ,so that we can come to know whethere there is a problem with your dvd writer or burner.if you dont have any other burning software let me know ,i will send you through email..........bye
May 23, 2008 | Samsung SH-S182M/BEBN DVD RW Dual Layer...
Computers & Internet Logo
552 people viewed this question
David Payne
David Payne
