Question about Lexmark X8350 Print, Scan, Copy and Fax All-in-One Multifunction Printer Plus Photo w/USB Printer ...
Printer dead! I have the same issue - the printer just died. The cable from the wall is good - and power pack on and fuse ok but no response from printer! Is there an internal fuse?
  • 123 Answers
Take your printer to a service centre
Posted on Jul 17, 2009
PIXMA MG5350 WILL NOT POWER UP. HAVE CHECKED THE PLUG FUSE.
Unfortunately, I believe the printer will need to be replaced.
If you have verified the power outlet is good, there are not many options. No reset for 'No power'.
Nov 30, 2013 | Office Equipment & Supplies
WON'T PRINT IN WINDOW IT SAYS INK SYSTEM HAS FAILED ERROR:OXC18A0001
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
3. Press and release the "OK" button
4. Press and release the right arrow button until the display says "System Configuration Menu". 2. Press and release the "OK" button.
5. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
6. Press and release the "OK" button.
7. Display should say "Hardware failure status: Clear. Press OK to clear".
8. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
9. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 05, 2011 | HP Photosmart C5180 All-In-One InkJet...
I have the Plug going to the wall and confirmed power at the outlet. I have the UBS back to the Computer and plugged into the printer and it will not turn on at all. Its a Year old at most and havent used...
I see a power supply issue here. Looks to me your printer power pack is gone bad. You need to confirm this by trying another similar power pack with the printer to be sure. If the printer is portable take it to the store or technical personnel to try another power pack with it. Once confirmed you may have it replaced.
Good luck & God bless!
Nov 30, 2010 | Canon MX700 Office All-In-One InkJet...
My hp officejet 4355 printer gives a msg turn off then turn on
Leave Power Cord plugged in for now.
1. Disconnect any USB, Ethernet, or parallel cable
2. Press printer power button to turn off the printer
3. Wait 60 seconds.
4. Turn on printer by pressing power button
5. If the message is still displayed check to see what type of power cord your using. If it has a large rectangle power pack make sure the part number on the pack matches the number on the printer. ( if it doesn't match you need a new power pack)
(If you only have a cord continue step 6)
6. Disconnect the cable from the wall outlet and wait 1 minutes.
7. Reconnect the power and press power on the printer.
Watch to see if the same on/off problem is occuring.
If the printer remains ON you have too many devices using the one power board or surge protector.
If the printer turns off then the problem is the electrical socket
8. Move the printer to a power outlet it can use with no other devices connected.
If this doesn't fix the issue you will need the printer serviced with HP
Sep 09, 2010 | HP Officejet 4355 All-In-One InkJet...
No power
check the wall socket power(with tester), if all is ok there then check power cable (use your computer's power cable to test).
If still its cold then most likely its internal fuse has blown or some issue in its power section.
get hold of a experienced hand to quickly check the fuse first.
May 30, 2009 | Lexmark X83 All-In-One InkJet Printer
Won't turn on?
Unfortunately this sometimes happens because the printhead has decided to die on you... There's a warning in here too so whatever you do, don't try the printhead in another printer because if it was the cause it will fry that printer too.
A couple of things to try though:
1. Locate the printer power pack in the printer... This is a module that will slide into it's slot in the printer. Removing it may require you to take the case top off (which I can't help with, sorry) but if you can manage it continue..
OBVIOUS BUT IMPORTANT: Disconnect from the power before you do ANYTHING!
2. Remove the power pack from the printer and disconnect from the cable or cables internally but make a note of how they connected so you can reconnect.
3. Re-connect these cables after a couple of minutes, replace the power pack.
4. Test the machine by plugging it back into the mains and turning it on... If it comes back to life, you're sorted... If it doesn't your options are very limited.
Oh and obviously check that the fuse hasn't blown in your power leads plug (if you're using a fused plug - ie: in the UK, etc.)
Hope that helps... and good luck.
Feb 16, 2009 | Canon MP970 Photo All-In-One InkJet...
My HP 6300 xi all in one just died.  Will not turn on.  Any clues as to what could be the problem?
Did you connect the printer directly to a walloutlet to  a power source or do you use a power surge protector. Try to connect the machine directly to a wall outlet. Try to disconnect the power cable from  the back of the machine while the machine is powered on. Reconnect the power cable after 10secs than the machine should reboot by itself. This resolve your issue. Else try to  use  a different power cable,may be the power cable is defective.
Jan 26, 2009 | HP OfficeJet 6310 All-in-One Printer...
My printer shows error C4EB8401 when switched on and wont print?
Verify that the unit is switched on. Disconnect the USB/Ethernet cable from the All-in-One and also disconnect power cable from All-in-One and also from wall outlet.
Wait 30 seconds.
Plug in the power cable to All-in-One and also to wall outlet.
[Now turn On the printer and check the functionality
if the above does not rectify it
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord.
3. Now turn On the printer.
is this is still not working then it is due to the print cartridge cradle packing up.
and you might have to face buying a new one, but I hope the above will help
Jan 17, 2009 | HP Photosmart C4180 All-In-One InkJet...
My printer is out of order. The ink system has failed. Unable to print. Error: 0xc19a0020. I turned the power off then on again but the problem is also the same. Please help me. I have a HP Photosmart...
Here is the conversation from a tech. I had the same problem.
Christina: Let us perform some steps to isolate the issue and find a fix for it.
Christina: Please perform the following steps and let me know the message that will be displayed on the printer.
Christina: A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release in sequence the “1”, “2” and “3” buttons.
CustomerName: ok
CustomerName: screen says "support" R0631M
Christina: Fine.
Christina: 2. Press and release the right arrow button until the display says “System Configuration Menu”.
Christina: 3. Press and release the “OK” button.
Christina: 4. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
Christina: 5. Press and release the “OK” button.
Christina: 6. Display should say “Hardware failure status: Clear. Press OK to clear”.
CustomerName: yup
Christina: 7. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
CustomerName: ok
Christina: 8. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
CustomerName: ok
Christina: 9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
CustomerName: done
Christina: Fine.
Christina: 10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
CustomerName: done
Christina: 11. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
CustomerName: made a buncha noise, and it didn't print a diagnostic page
Christina: Good.
Christina: Is the error message still being displayed on the printer?
CustomerName: nope
Christina: Good.
CustomerName: should I try to print something?
Christina: Let us print a self test page to check the functionality of the printer.
Christina: Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
Aug 07, 2008 | Office Equipment & Supplies
Lexmark X8350 Print, Scan, Copy and Fax All-in-One Multifunction Printer Plus Photo w/USB Printer ... Logo
127 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
