Question about Whirlpool Washing Machines
Duet sport fabric softener not dispensing - Whirlpool Washing Machines
    Problem Solver:
  • 5 Answers
Remove the soap and softener dispenser and wash out thouroughly, ensure softener discharge hole is clear of gunk.
Posted on Jul 17, 2009
jsrock516
  • 5911 Answers
SOURCE: Fabric Softener Won't Dispense
The fabric softener dispenser is notorious for clogging. Liquid fabric softener is essentially a liquid form of wax. After a period of time it begins to gunk up the inside of the fabric softener dispenser. If you remove the dispenser drawer and look into the cavity, there should be a series of holes in the upper part of the compartment where water sprays into all the dispenser trays. These holes get gunked up and clogged and water will not dispense properly. As a result, the washer goes through a complete cycle, but the dispenser stays full. If this is the case, you can take some cotton swabs and/or toothpicks and clean these holes real good. It may be a bit meticulous, but it should take care of the problem. Post back and let me know if this helps.
Posted on Feb 11, 2008
  • 220 Answers
SOURCE: fabric softener dispenser won't drain the fabric softener.
Not sure if you already did this, but try pulling the face plates off inside the dispencer and take it to the sink and run very hot water into the "stand pipe" that projects off the back of the face plate to make sure they are clear and no old crusty products are in the hole.. Then put them back in and push down hard and make sure they are fully seated.
If the plates are loose and not seated or clogged, there will be little or no siphon effect to draw the fluids out of the dispenser. At least thats how it seems to work
Also, if you pull the top off the washer, there is an adjustment on top of the dispenser to adjust the dispensing ratios I believe.
I just did that procedure the other day on my machine and the wife said it works good now.
Let me know it it works for you, I was wondering if it was just a coincidence.
Posted on Jan 16, 2009
SOURCE: Whirlpool Duet dispenser problem
I had the same problem my fabric softener would not dispense.Close shut-off valves and take off the water hoses off the back of the washer and look for blockage on the screen.Mine was plugged up and after cleaning it off it works like new.
Posted on Apr 03, 2009
barkencoa
  • 3463 Answers
SOURCE: fabric softener dispenser no longer works on my Bosch
Remove soap drawer completely from washer, and thoroughly clean all parts of it, paticularly the conditioner compartment..
Get a piece of stiff wire, and make a right angled bend in the end of it, then poke the wire into all the holes in the top of the soap drawer compartment to clear any possible blockage.
This should solve the prob.
Please rate my solution.
Thankyou.
Posted on May 20, 2009
SOURCE: remove and replace fabric softener dispenser on kenmore model 20952992
I just did it. All you do is pull up on the blue part -- put the fingers of both hands under the rim and pull. It isn't screwed or bolted on. If there's a lot of gunk built up, it's all the harder to pull up. Be prepared for some yucky stuff. It would be nice if that whole section would come out, since you have to clean the area below with Q-tips.
Posted on Jan 09, 2010
Whirlpool duet sport, fabric softener is not working
you probably have a clogged tube from some old softener that dryed up inside it
Feb 25, 2015 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool duet washer fabric softener dispenser does not empty
Hi there
I wonder why, mine does though I never use a fabric softener, the water just runs through. It must be clogged somewhere, the only solution I have is the old one. The needle and the thread,try puting a needle through then pull the thread back and forth.
I hope it works
kolbrun
Mar 24, 2012 | Whirlpool GHW9150 Duet Washer
My Whirlpool duet sport machine occasionally has "stained" laundry. I can't figure out what causes it since I don't wash colors and whites together. The stains appear to be blue. Could this be a fabric...
Make sure you are diluting the fabric softener before putting it into the dispenser drawer. Full strength softener will sometimes stain clothing that's why in the owners manual they always tell you to dilute it first before adding ,plus it last a lot longer and is just as affective... Hope tis helps
Sep 16, 2010 | Washing Machines
The soap dispenser works but the bleach and softener dispensers do not
Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
heatman101
Sep 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Fabric softener is not dispensing
drain tube stopped up with softener needs cleaning
Feb 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Fabric softener won't dispense
Have you tried thinning the softener with water? It's what I used to do on my older washer, it wasn't the new Duet, but it seemed to help. Hope that helps. (PS I don't use softener anymore as I have developed a terrible skin allergy to these newer longer scented softeners! )
Jun 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The fabric dispenser does not release softener into the tub
it may be the water supply to take the fab cond in is either blocked (holes) above the dispenser or the water valve is faulty.
Mar 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Soap Dispence problem on GHW9200LW
In applications with low water pressure, insufficient water
volume is introduced during the fabric softener dispensing
portion of the cycle to flush the dispenser.
RESOLUTION:
The holes in the dispenser housing were enlarged to allow
a greater volume of water to flow through the fabric
softener dispenser to properly dispense the fabric softener.
Order and replace the dispenser housing, Part
#8181719, to correct the condition
Feb 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Fabric softener leaks out at beginning of wash
I have a 9200SQ Whirlpool duet.  It might be similar.  I think the bleach and fabric dispensers work on the siphon principal--once the level gets above a certain point they will then siphon out until almost nothing is left.  They should not start to siphon until extra water is directed into them during the correct cycle.   It is possible that they are starting to siphon early because 1. the washer is not level, 2. water is being added to the dispenser during the wrong cycle 3.  You put too much liquid into the dispenser and it started the siphon.
Note:  You should not peek in the dispenser during the washer cycles because it might interrupt the "siphon"action and leave residual bleach or fabric softener in the dispensers.
Oct 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
442 people viewed this question
Dan Webster
Dan Webster
Sal De
