The Dometic RM 2820 was working last night. This morning it was not cooling and now the front panel and interior light are not working. No smell of ammonia. Any help with this challenge? Thanks,
the thermostat is powered by the unit or batteries if batteries they may be dead if the unit you need to check fuses outside at unit or reset breaker outside depending on age of installation
I also have a YTH20K46. During last mow (last week), I tried to turn off mower and would not turn off by key. I had to put it down to choke and then stand up. It created a backfire. Today I went to start it, now won't start. It does not turn over. Hour meter has no power. Tested battery & solenoid. Power to both. Key switch works fine. Any suggestions? Just had it serviced a few months ago. Oil, gas and all other things seem fine. Checked wiring, seems fine. Nothing melted or cut. Please help!
main thermal fuse in the rear of the machine, if this tests good,, check the safety switch on the door itself you can hold it in and turn the machine on,, if it works,, replace the plunger shaft that turns it on
If it turns over but just won't fire and the timing sounds fine when it does run you might consider your ignition switch. Does it sound like it wants to fire but only just when you let go of the key?
