Question about Sony KDL Televison & Video
Tv got a green light on but the TVs won't come on at all checked batteries in the remote all good what else can I do?
  • Sony Master
  • 6,694 Answers
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on May 10, 2016
SOURCE:
Philips digital tv won’t turn on.
unplug from electric, wait 30 seconds, plug back in. Check that you have power at the outlet (fuse/breaker shut off?) If it has a power word which plugs into the TV as well as the wall, be SURE it is tightly attached to BOTH. Make sure you aren't blocking the remote control receiver (you can turn most TVs on/off on the TV itself -- look for a power button). Be sure your remote has fresh batteries. Good luck!
Jan 14, 2018 | Philips Televison & Video
I have a toshiba tv 39al900a which was won in a raffle. When you turn it on it says please scan channels.t.
The first step is to make sure you have good batteries in the remote. The ones included tends to be cheap and you have no idea how old they are.
Here is the manual, page 12 explains how to use the remote and the next few pages cover the initial setup and scanning of channels.
http://www.mytoshiba.com.au/file/download/resource/file/23089/39al900a%20owner's%20manual.pdf
If the remote is still not working, get a universal remote to replace it. This link gets you the codes to program the universal to work with your TV. http://codesforuniversalremotes.com/universal-remote-control-codes-toshiba-tvs/
Feb 05, 2017 | Toshiba Televison & Video
Why did my screen go solid green after I tried to watch something on my DVR?
A solid green display to LCD TVs is a bad symptom. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Screen-shots to defective LCD are given. You can see and compare to that ot your TVs', and can make sure about the fault to an extent.
May 05, 2014 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Remote will not work.
The first thing you have to check is your TVs remote control. Check it for its infrared emission. If you wish to get more details, surf this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. There is a post, which will give you all details about how to check and repair a remote control. Pull up older posts. If the remote control is found OK, check and replace the infrared sensor inside the TV.
May 17, 2013 | Curtis LCD2425A TV
Tv will not work with remote remote works
Sometimes this happens, check the back of the tv of the for the light bulb sometimes it may go out and the tv won't work you may have to unscrew it your self though or get some help goodluck!
Sep 20, 2012 | LG 26LG30 - 26" Class / 720p / 60Hz / LCD...
My remote light lights up but it won't work on my
Check your remote for its infrared emission. Check this with fresh batteries. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 750 posts to different brand TVs now.
Pull up older posts there. Repair to remote control are described in detail among one of them.
Sep 15, 2012 | Televison & Video
Recommended replacement remote for 32c11ou
i would make sure you have good batteries in remote and if you have a cell phone with a camera you can point the camera at the remote control where the bulb is that you point at the tv and push a button on the remote control and the light will show up in the camera as a blue light the camera will pick up the ultra violet light that your ***** eye won't see if still bad almost all universal remotes will work but usually problem is battery or corroded battery connectors good luck
Aug 05, 2012 | Toshiba Televison & Video
Can a tv lose the ability to read codes from a universal remote cause i tried three different un. remotes and my tv doesent react to them.. thnx
If the infrared sensor inside the TV is faulty, TV won't respond to any remote controls. You can make it sure by looking into TVs standby light. If standby light on TVs front panel blinks once, when you press a key in the remtote control, make sure that the sensor inside is working properly, and the code you are trying to enter is non once for your Brand TV, If there is no blinks as such stated above, make sure that the infrared sensor inside your TV is faulty. If you want more details about codes, setup proceedings, repairing a remote & checking it, just visit this site. Th site name is "Electro-help".. Just search for it by type in 'electronicshelponline' in your browsers' search page. It is a blogspot site, in English language.
Jun 22, 2012 | RCA Televison & Video
Remote for box 1 is changing channels for remote 2 and remote 2 does not work
lieslmc
Are you getting the same picture on both TVs - TV 1 and TV 2? Depending on the receiver model, you have a mode button either on the front of the receiver or behind a door on the right side of the receiver. You also should have a green (TV 1), amber (mode), and blue (TV 2) lights on the receiver. If TV 2 is one, the blue light should be lit. The amber light should be lit under the dual mode. Press and release the mode button on the receiver to put the receiver in dual mode. The blue light (TV 2) should illuminate now and this will give you independent operation between the two TVs. I hope this helps.
Ray Calo
DISH Network
Jun 18, 2010 | DISH Network IR Remote Control
TV won't turn on
The red light instead of green is an indication that theres a voltage missing or an improper voltage in the sweep or main power supplys. This should be handled by a trained service tech. Good Luck
May 28, 2006 | Durabrand DWT2704 TV
Televison & Video Logo
70 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
